AriNV3Jack KlarichRider Safety Discuss...Maybe silly but serious question, s...
AriNV3AriNVRider Safety Discuss...Maybe silly but serious question, s...
AriNV3cycle7447Rider Safety Discuss...Maybe silly but serious question, s...
Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Likes Likes:  5
Thanks Thanks:  1
Results 1 to 19 of 19
Thread: Stallion Front Caliper rebuild 101
    Default Stallion Front Caliper rebuild 101
    Hello to all. Well my wife's front calipers need rebuilding. Noisy and they were dragging to the point it was hard to spin the tire while jacked up.
    Removing the calipers is straight forward. You remove the front hemi joint that holds the caliper mounting plate from rotating. Remove the brake line from caliper. Then remove the 2 caliper mounting bolts. The caliper will swing down to the bottom and is easily removed leaving the pads in place. You might have to pry the pucks in a little to get it loose.
    Take the calipers to your work area. You will need compressed air to blow the pucks out of the caliper housings. Mine were really stuck but they finally came out.
    I took the parts to my buddy at NAPA and he advised that hardly anyone sold the parts for calipers any more just the rebuild kits. Now without knowing an application for the calipers you are kind of out of luck. The calipers I hear from TBMS were custom built.
    So now the research started. There are 2 O-rings for each piston. The inner is to keep the fluid in and the outer to keep dirt out.
    So I took my trusty micrometer and measured the piston diameter and the o-rings cross section.
    The inner seal is a square o ring with a cross section of 1/8 and an inner diameter of 1 1/8. This is o-ring size 216. The outer is a regular o-ring 1/16 cross section and same inner diameter of 1 1/8. This is o-ring size 024.
    So went on line to see about finding replacements. First thing I discovered is there are a lot of different rubbers used to make O-Rings. There is ONLY ONE recommended rubber for brake fluid (EPDM).
    Next issue was they have phased out square o-rings. There are replaced with what they call Quad or X o-rings. Could not find any in the rubber (EPDM) and size needed.
    After many more hours of research I found that a regular O ring of the right material (EPDM) should work. The only reason they use the Square o-ring is to help with the piston pull back when the brake pedal is released.
    So I ordered the EPDM rings on line and re-built the calipers and they work great. By the way I had to order 4 sets of o-rings to meet a minimum order. So if anyone wants a set of o-rings you need 4 of each size I will sell you a set for $3.00 plus shipping priority mail envelope I think that's like 5 or 6 dollars not sure that's about what I paid for them. I am a moderator so you can "PM" me.
    250+ Posts
    Dec 2010
    oly,wa
    Good job
    i rebuilt my calipers 3 years ago, got the kit from tbms. don't know if they still offer a kit.
    Dragon
    450+ Posts rocket1lf's Avatar
    Dec 2013
    Hot Arizona, USA
    Great info. Thanks. I only have 45000 on mine, but I have done a bunch of mods and put new stuff on it. Anything you suggest that I need to do with this amount of mileage would be appreciated. Rick
    Stallion #378
    Suzuki Burgman 650
    1000+ Posts tomg's Avatar
    Oct 2009
    Titusville, Florida
    I thought that the front brakes were from a Toyota FJ as that is the brake pads I have bought to replace mine? I'd call Richard at TMS and ask him to verify and if I was correct you can get those parts at about any parts store. Tomg
    Good job
    Dragon
    last word from richard i read they were not available.
    Quote Originally Posted by tomg View Post
    tom yes they use that pad but the calipers are not fj cruiser. right off that caliper uses one piston and the stallion has 2 pistons
    Jul 2015
    fairfield,Il 62837
    Default Slshort2001
    Mr Gorilla,having caliper problems. Who has the o rings ?
    250+ Posts
    Dec 2010
    oly,wa
    Hi Ted
    do you still have extra o rings for calipers if not would you mind telling where you ordered them
    Dragon
    Hi Ted
    Dragon
    I will check and advise
    250+ Posts
    Dec 2010
    oly,wa
    Hi Ted
    I know this is an old thread but do you know where you got your o-rings
    Thanx
    Dragon
    Hi Ted
    Thanx
    Dragon
    sorry was not able to locate invoice
    try search by the part numbers
    Aug 2023
    100 Berlin RD jeannette Pa 15644
    Default 2009!Stallion
    soures =Hi just wondered if you found out were i can by 2 sets for mine
    Hi Ted
    Thanx
    Dragon
    Quote Originally Posted by 2009 ! Stallion View Post
    Earl, Welcome to Trike Talk on your first post..👍👍..
    Earl Welcome aboard. The best I can suggest is use the info provided in my post from 2019 and see if you can find "O" rings to match. Good Luck
    Hi Earl, to Trike Talk and your first post
    If you disassemble the calipers a good parts guy can match the o ring seals up for you
    I would try a Napa or Car Quest jobber first
    Aug 2023
    Thanks !!
    Aug 2023
    Will Do Thanks for the info!!
    250+ Posts
    Dec 2010
    oly,wa
    welcome i got my set at grainger size 216 comes 5 to a package and the other size 024 comes 50 to a package material was viton. i could not find the square seal at napa or around here. don't know price was not expensive.
    good luck
    Dragon
  19. #19
    good luck
    Dragon
    The square seal was not found by me either back in "19" but I used a round one of the same size and it worked well.
  1. Chrome caliper bolts or covers?
    By scuba1954 in forum Harley Tri Glide
    Last Post: 03-20-2015, 02:45 PM
  2. caliper destroyed
    By russg0515 in forum Harley Trike Conversions
    Last Post: 09-02-2013, 05:00 PM
  3. Harley Front Caliper parts needed!
    By TrikerJohn60 in forum Harley Trike Conversions
    Last Post: 01-10-2013, 10:39 AM
  4. Lehman Rear Brake Caliper
    By Ultraclassic in forum Lehman Trike
    Last Post: 05-09-2012, 11:14 AM
  5. Sticky caliper
    By whitewood in forum General Discussion
    Last Post: 04-11-2012, 04:44 PM
