Likes Likes:  2
Results 1 to 8 of 8
Thread: Torsion Bar
    100+ Posts sonny8l3's Avatar
    Oct 2014
    Livingston (Colyell ), Louisiana, USA
    Default Torsion Bar
    Hello, My trike has a ground clearance of just under 3". The machanic and I discussed ways to raise it a little. He is arguably the best VW mechanic in this part of the state, but he doesn't do much with trikes and mine is a little unusual. he said that I could turn the torsion bar up one notch, but it would raise my frame "a bunch". But since it has no body, he doesn't know how much. Anyone have any experiance adjusting the torsion bar? I would appreciate any educated guesses on how much it would raise my frame. It weighs 1060 lbs. full of fuel with Mabel and I. Thanks for your time.
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    It will be similar.
    This is also in tech thread.
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    It will be similar.
    It can be tedious to keep up with where you are and where you have moved it.
    If you study the chart you will see that the inner and outer splines are different pitch. So it takes a combination of skipped teeth.
    Oct 2014
    Thanks. The charts are way over my head. I talked to the mechanic today and he said he would research it. He didn't sound too crazy about attaching it, he does more motor work than any thing else. If he's not interested in doing it, I don't think that there is any place within a couple hundred miles of me that does this type of work. I've had the trike about 4 years like this, I reckon I can do as many more as we have in us. And Mabel really doesn't care one way or the other, as long as she gets to go. Thanks for your time,
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    Air shocks would help that situation.
    Oct 2014
    Hello, If I can't talk the mechanic into it, that may be my best option, thanks.
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    The mechanic should be able to understand the chart.
    The chart itself is the easy part. Keeping up with where you are and how many teeth you are skipping is the hard part.
    600+ Posts TomyJ's Avatar
    May 2016
    Hemet, Ca. USA
    Default Lowrider
Size:  288.9 KBBefore I made the body I went to a off road VW shop and they lowered the torsion bars for me...
    JakeJacobsen@Pinterest.com
  1. broken torsion rod!
    By chavistownrider. in forum Honda Trikes
    Last Post: 09-16-2022, 08:56 PM
  2. new torsion bar cover
    By Fowler in forum VW Powered Trikes
    Last Post: 01-25-2016, 06:38 AM
  3. Bar Stool Racer...School Project
    Last Post: 08-12-2010, 11:09 PM
  4. Great Bar-B-Q....K.C. Jones...PICS
    Last Post: 08-03-2010, 11:44 AM
  5. Newbie question on sissy bar.....
    By dxerebl in forum Honda Trikes
    Last Post: 07-08-2010, 08:39 PM
