14TG114TGHarley Tri GlideInstallation of a new Fuel Filter &...
BigN693GorillaEnabled TrikersFull length floorboards
Likes Likes:  13
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 30
Thread: Look What I Found
    Dec 2014
    Grand Junction, Co. USA
    Default Look What I Found
    I was routing around the area of the garage that I haven't cleaned ... I found these. A pair of Saddleman bags designed to be mounted on the saddlebag protectors of an Ultra type bag. I had cut the "ears" off and was trying to figure out how to mount these on the 08 Gold Wing trike I had ... never go to that project. Thinking now that they might make a great addition to the Fat Bottom Girl.
    Front:
    Back:
    I also have a set of the Harley type ... these are much more water resistant since they have a zip up top, and the flap that has a turn type snap.
    Now ... how do I mount them?
    Option 1) I do have a snap kit that would allow me to add new snaps, one to the top flap and three to the bottom flaps. I don't have black snaps so I would change them all to chrome. I would drill 8 holes in each fender and put the male part of the snaps there.
    Option 2) I could easily drill four holes in each fender and use bolts with fender washers on the inside of the bag.
    Option 3) Seems to me there wes some kind of "film" that allowed mounting these type bags without it being "permanent".
    I'm not sure what I'd put in them ... probably gloves and arm sleeves, maybe my wallet, when Harley goes, I could put his leash and some snacks ... since I removed the armrests from the passenger area, I don't have a spot to put the credit card anymore, so, getting gas means opening my tour pak ... LOL. I know ... pretty lazy ...
    So what do you think ... am I crazy for putting these on the fat bottom girl? I also thought about mounting them on the little trailer ... but making holes in that would lead to leaks ... on the FBG it's just into the fender.
    1000+ Posts
    nucseal's Avatar
    Jan 2012
    San Antonio, Texas
    Drilling holes into my TG, is definitely not at the top of my list. Always turns out ugly and is permanent!
    HOW CAN YOU HELP THE TRIKE TALK FORUM? Become a GOLD CLUB MEMBER!
    A veteran - whether active duty, retired, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to the 'United States of America', for an amount of 'up to and including my life.'
    Dec 2014
    Nice find ... I considered screws ... but, when you screw into plastic ... it usually cracks, even if pilot holes are used. I was thinking maybe pop rivets with backing washers. Or nylock nuts on bolts.
    5750+ Posts BillR's Avatar
    Aug 2015
    Gloucester, VA
    How about this location?
    Maybe use wide Velcro to attach them. The Velcro wouldn't be permanent.
    Bill
    R I P MANDY
  6. DKCustoms postbit
  7. #6
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    You best use fender washers on the inside of the fenders
  8. #7
    Dec 2013
    Clarion PA USA
    Fuzz don't you have a trailer? I have owned a trike for 6 years now and I have never needed more storage than adding a windshield bags for sunglasses. However good luck I would only consider industrial velcro. Just sayin Fred
  9. #8
    Dec 2014
    The more I think about this ... the less I like the idea of mounting them ... The Kuryakyn ones look promising. Might look into those. The bags I have are like 1 1/2 times the size of my hand ... not gonna fit on the lowers.
  10. #9
    150+ Posts kodiak198's Avatar
    Oct 2018
    Johnson City, TN, United States
    Any way to attach them inside the tourpak or trunk? Maybe inside the side covers as a semi hidden storage bag?
  11. #10
    Dec 2014
    Quote Originally Posted by kodiak198 View Post
    These things are pretty good size ... they are bigger than the Harley version. They measure 8" x 8" x 5" deep. Definitely not gonna fit under the side cover. Putting them in the tour pak or trunk doesn't seem like a good idea. Take space from them to add space. The side cover idea has a little potential ... maybe mount them on the side covers. If the plastic cracks, replace just a side cover.
    Doesn't anyone remember the name of the Sponsor we had here that used some kind of special bra material to mount the bags?
    UPDATE: It was seethroughbraz ... I read some of their reviews and like everything I tried to mount with double sticky tape etc, they start to peel off in the heat.
  12. #11
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Trailer mounted. Use flex seal around the hole for what ever mount you descide to use.
  13. #12
    4250+ Posts
    LadyonaMission's Avatar
    Feb 2015
    San Antonio
    Just because you have them, doesn't mean you must use them.
    My mission in life is not merely to survive, but to thrive; and to do so with some passion, some compassion, some humor, and some style. – Maya Angelou
  14. #13
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    To me, the interesting part of the entire thread is post #1, where you mention there's a section of your garage you haven't cleaned out.
    ​Would that be the section between the front & the back.
  15. #14
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by MDO View Post
    Maybe he is in the neighbors garage
  16. #15
    Oct 2018
    I know it isn’t my garage. It is Pristine front to back. Left to right looks like a tornado came through and decided to visit awhile.
  17. DKCustoms postbit
  18. #16
    Dec 2014
    You obviously missed the post about cleaning the entire front.
    Not a chance ... My neighbor's garage is worse than mine ... Just Saying ... He's a wood worker and everything is covered in sawdust ... mine is clean ... just cluttered ...
  19. #17
    Dec 2014
    Default New Possibility
    I found this in my save box in the garage.
    If I trim a tad off the width, and cut it in half, they would be nice backer plates. I could make both of them (two after cut in half) identical and use them as templates to make holes in the trike and saddlebags. Add some washers and I think this would eliminate the fear of cracking. I'll yak with Don this morning, he has a saw blade that cuts plastic without "burning it".
    Another benefit to using these as backing plates (inside the body of the trike, is that I could line them up on the body, get them perfectly aligned, drill the holes in the trike body ... then mount the bags on them. They would be cut to the exact width between the seems on the saddlebags. so aligning would be easy.
    Also, I could trim the flap above and below the bag and eliminate the snaps all together. I think it would be a cleaner install and they would look more professional.
  20. #18
    1000+ Posts Texan's Avatar
    Jun 2013
    Texas
    Check with www.seethroughbraz.com They have a saddle mounting kit with military grade velcro. I mounted the same type bags with their product 4 yrs ago and have never had a problem.
    https://www.seethroughbraz.com/Tri_G..._10427908.aspx
    8~\o
    "Anybody can become an American but ya have to be born a TEXAN"
    "Ya know I haven't been everywhere but it's on my bucket list"
  21. #19
    Dec 2014
    Quote Originally Posted by Texan View Post
    8~\o
    Thanks for that link ... Looks like that would be an option ... I did look at their site, and read some of the reviews ... but didn't see this section ... reviews on this look good. If your's don't loosen in Texas heat ... I think this may work.
    I did get the backers made and was contemplating mounting them ... I was playing "Devils Advocate" with myself and realized that if I mount these with screws, getting the side covers off might be real tough or maybe even impossible.
    Name:  Backer Mounted.jpg
    I may reverse the bolts so the counter sunk screws are on the outside and mount the velcro stuff to the backers. Not sure the velcro will stick to the "felt" like stuff on the back of the bags.
  22. #20
    1000+ Posts
    Aug 2016
    Des Moines IA US
    Use a high grade velcro and get that 3M stuff that pop in, don't remember the name of it but it is very durable and people that have used it with good success, just wish I could remember it, seen it on here quite some time back, please don't drill holes, someday you might regret it.
    All for now Trampas
  1. Look what I found on the net
    By FuzzyWuzHe in forum Harley Tri Glide
    Last Post: 04-04-2019, 09:10 AM
  2. Look what my wife found
    By oldnslow in forum General Discussion
    Last Post: 11-04-2014, 12:28 AM
  3. Hey Look what I found! Dancing NANA!
    By Papa Zook in forum General Discussion
    Last Post: 10-06-2013, 08:45 PM
  4. Replies: 10
    Last Post: 02-04-2009, 09:25 AM
  5. What to look for?
    By Wayne Harmsen in forum General Discussion
    Last Post: 01-10-2009, 06:31 AM
