JTJersey2JTJerseyHarley Freewheeler /...Removing Trim Around Oil Cooler
JTJersey2rhino 2Harley Freewheeler /...Removing Trim Around Oil Cooler
Jarhead17751Jarhead1775Harley Freewheeler /...paint job
AriNV12AriNVNew Member Introduct...New to trike
AriNV12Phu CatNew Member Introduct...New to trike
AriNV12ol' schoolNew Member Introduct...New to trike
AriNV12hardwickbvNew Member Introduct...New to trike
B SMITH9rhino 2Harley Tri GlideTrailering Tri Glide
B SMITH9CasperHarley Tri GlideTrailering Tri Glide
TomyJ7TomyJSidecar ForumHackHer
Speed Bleeders
AriNV121dn5upNew Member Introduct...New to trike
AriNV12SullyNew Member Introduct...New to trike
Too Pa Pa Zook
Too Pa Pa Zook
ken g9Old Road DogHarley Tri Glidereverse not working
AriNV12trike ladyNew Member Introduct...New to trike
AriNV12GorillaNew Member Introduct...New to trike
AriNV4GorillaCan Am Spyder Trike...I'm a total newbie ... Is the Spyde...
Grandpot9Papa ZookHonda TrikesFront tire?
Grandpot9tourmanHonda TrikesFront tire?
AriNV12Marc HNew Member Introduct...New to trike
Burnerboy4pawsRoadsmith Trikes
Too Pa Pa Zook
AriNV12Uncle FesterNew Member Introduct...New to trike
Jack Klarich2Jack KlarichGeneral DiscussionMY first guitar
Jack Klarich2ZammyGeneral DiscussionMY first guitar
Too Pa Pa Zook
Hdsteal4Jack KlarichSuzuki - Kawasaki Tr...Completed MS Trike Pics
Noodles1078Jack KlarichHarley Freewheeler /...Very Nice Gloves
Noodles1078Papa ZookHarley Freewheeler /...Very Nice Gloves
Noodles1078LadyonaMissionHarley Freewheeler /...Very Nice Gloves
Hdsteal4oldschoolSuzuki - Kawasaki Tr...Completed MS Trike Pics
oldschool6oldschoolHarley Trike Convers...Any Completed DNA Trike Kit Owners?
Jack Klarich1Jack KlarichGeneral Harley ChatDiagnostic Trouble Codes for Harley...
Likes Likes:  3
Results 1 to 12 of 12
Thread: Missing "O" rings Motor Trike rear end
    500+ Posts
    Feb 2008
    Planet Earth, Alpha Quadrant
    Default Missing "O" rings Motor Trike rear end
    2005 Spyder 2+2 straight axle
    This weekend I replaced my slightly leaky real axle seal on my Motor Trike spyder 2+5 2005 kit.
    I followed the instructions carefully.
    However there was one hiccup.
    The service manual states (Kjix) that there should be an "O" ring on the ends of the driveshaft where the "C" clip holds the axle in the differential.
    I HAD NO SUCH "O" ring.
    Should I order some "O" rings and tear it all apart again to install them.
    Should I not ride the trike until I install these "O" rings.
    Seems like i have been riding it for the past 14 years and havent had any issue that I should be ok now...
    What say you all
    Rake...
    Never had it....
    Never will...
    2000+ Posts trikeman's Avatar
    Oct 2010
    Jackson Tn. Madison Co.
    If it ain't broke don't fix it.
    Apr 2010
    Shenandoah Valley of Virginia
    Quote Originally Posted by cjmitch View Post
    2005 Spyder 2+2 straight axleThe service manual states (Kjix) that there should be an "O" ring on the ends of the driveshaft where the "C" clip holds the axle in the differential.
    All C-clip retained axles I ever fooled with …. you opened the rear up, removed the cross shaft and the two spider gears, then push the axles inward and pulled the C-clips, then you could pull the axles out.
    To reinstall, slip axles in all the way, then put C-clips on inner end in grooves, then move axles out a bit and side or "axle" gears surrounded the C-clips, then reinstall spider gears and cross shaft …. thus trapping the C-clips in place.
    Never saw one with O-rings there?
    Make Courtesy Your "Code of the Road" too!
    3250+ Posts bikerbillone's Avatar
    Sep 2012
    Lakeland, FL
    I gotta stay tuned to this thread, I've missed something, what is a Spyder 2 x 2? Guess if don't know, I can't add much to the discussion. Just trying to learn something here.
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    This weekend I replaced my slightly leaky real axle seal on my spyder 2+5 2005 kit.
    What say you all
    Pretend you never read the service manual .....And then Forgetabout the 'O' rings...
    2019 Tri-Glide.......
  6. #6
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    2
    Quote Originally Posted by bikerbillone View Post
    The OP is referring to his Motor Trike "Spyder 2+2" trike conversion model. I edited the OP's post for clarification.
  7. #7
    500+ Posts
    Feb 2008
    Quote Originally Posted by trikeman View Post
    I like your thinking
    Rake...
    Never had it....
    Never will...
  8. #8
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Ford has used this O Ring for many years on their axles as an assembly line tool to keep the C clip in place while finish assembling the axle cross to lock it in
  9. #9
    500+ Posts
    Feb 2008
    THANK YOU!!!!!
    Rake...
    Never had it....
    Never will...
  10. #10
    Apr 2010
    I can see how it would work to hold them in place on a assembly line where axles were pushed in in one step, then c-clip added in next station, then the overhead moves it to a stage where axles are pulled back out so side gears hold C-clip captive. Guess some C-clips dropped out and a robot missed it? Once the rear is assembled, there is absolutely no purpose for rubber O-rings in the assembly, besides, …. how would you ever know if they survived 5 miles or not? You wouldn't of course. Like cheap rubber bands, they'll eventually just be rubber dust ground up in gears.
  11. #11
    500+ Posts
    Feb 2008
    Quote Originally Posted by CrystalPistol View Post
    Just got a im from motortrike... some axles had the o rings, some didnt... its ok if it didnt
    Rake...
    Never had it....
    Never will...
  12. #12
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    The O rings are a plus to keep the C clips in place but not needed
    In the Automotive end I have had thousands of rear axles apart and never had a problem with dropping or losing the c clips, Ford got it right @ the factory putting the O rings on their axles
  1. LED Light Rings
    By hocnsoc in forum Harley Trike Conversions
    Last Post: 01-18-2015, 04:53 PM
  2. Rings
    By jcolson in forum Harley Trike Conversions
    Last Post: 01-19-2014, 02:08 AM
  3. Loose Crash Bar rings
    By Las Vegas Biker in forum Stallion Trikes
    Last Post: 11-06-2011, 09:53 PM
  4. changing o rings in front forks
    By newtriker in forum General Discussion
    Last Post: 02-22-2009, 02:49 PM
