Likes Likes:  2
Results 1 to 9 of 9
Thread: Temperature Gauge
    20+ Posts
    Oct 2017
    Spartanburg,SC,29307
    Default Temperature Gauge
    The temperature gauge on my 16 Trike always reads several degrees higher than radio reports or Bank signs show? Is this something that is a problem with them all or is there a way to improve its accuracy?
    I think it has a lot to do if the sun is warming the area where the sensor is. Also at times the sensor can be getting heat from the motor.
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    In my experience those bank signs are often quite inaccurate. And as for the radio the temp reading could be from a weather station miles from where you are. I do think the digital temp readout on the Rushmore bikes may be a few degrees high but it is a whole lot better than the old style analog gauge in the pre-Rushmore models. Doubt there is any way to calibrate it.
    Quote Originally Posted by Vtrod View Post
    Radio reports and bank signs are reading low......-...Because they aren't sitting near a heat pump...AKA...Engine......
    100+ Posts TrainingWheels's Avatar
    Aug 2019
    Amarillo, Texas, USA
    My 2010 was like 15 or 20 degrees high. I finally got the Dealer to relocate the sensor and it didn't cure the inaccuracy but it brought it to with 3 or 4 degrees of being accurate.
    50+ Posts onebadeagle's Avatar
    Nov 2013
    Fredericksburg VA
    Default Temp Gauge
    Quote Originally Posted by TrainingWheels View Post
    All moco Air temp gauges are Trash. Have an oil Temp gauge installed, much more helpful than Air Temp. If it's Hot Outside You already know it
    Aug 2019
    Quote Originally Posted by onebadeagle View Post
    That's true when it's hot. When it's hanging around freezing I want a little more accuracy than, "It's cold outside." I've always tried to ride 12 months a year and it get's cold in Iowa. That's why I retired to Texas 4 years ago. Not so important around here
    Riding almost always in mountains (Rockies), I like having the temp gauge, even with it's inaccuracy to give me a basic idea I I should be looking for Ice on the roads.
    20+ Posts Pappy49's Avatar
    Apr 2018
    San Marcos, Texas, USA
    Under the Texas sun the temp on my '02 Classic always read 15 - 20 degrees too high in the summer. When I did the conversion I used the stock bezels to install a VDO PSI gauge for my air bags.
    Name:  DSCF0849 (640x480).jpg
Size:  212.0 KBName:  Pressure Gauge and Switch.jpg
  1. Replace air temp gauge with oil temp gauge
    By gamechngr in forum Harley Trike Conversions
    Last Post: 03-04-2014, 12:09 AM
  2. Riding Temperature Chart
    By rmrc51 in forum General Discussion
    Last Post: 01-31-2013, 08:50 AM
  3. Gerbing - Permanent Mount Temperature Controller
    By Alan Oakley in forum General Discussion
    Last Post: 07-14-2011, 09:58 PM
  4. oil temperature dip stick
    By cannonball in forum Honda Trikes
    Last Post: 03-08-2011, 07:36 PM
  5. oil temperature gage
    By greyfang in forum Harley Trike Conversions
    Last Post: 01-28-2011, 11:42 PM
