Likes Likes:  2
Thanks Thanks:  7
Page 2 of 2 FirstFirst 1 2
Results 21 to 25 of 25
Thread: Help - Lost a sidecover!
  1. #21
    Oct 2010
    USA
    Quote Originally Posted by GladAlice View Post
    "Unfortunately this seller is not able to respond to your question. We suggest reviewing the item again to see if your answer is in the seller's listing."
    Not sure but you click on contact seller and then use other, then you should be able to type a message?
  2. #22
    Jul 2019
    Albuquerque, NM USA
    My wife has a 2010 FLHXXX Street Glide Trike. I have a new 2019 Tri Glide.
    I removed both left covers and compared them. There is a slight difference in the way they are molded at the top rear of cover. Unless you are looking at both covers you wouldn’t notice the difference. There is metal piece that is glued to the cover on the inside for mounting on the FLHXXX. The mounting points on the Tri Glide are molded into the cover and are plastic. The mounting points on the frame for both covers are different, but the same. Let me explain, both the FLHXXX and the Tri Glide frames have exactly the same mounting points. They are just utilized differently.
    The grommets that hold the cover on are different as well as the rest of the parts.
    FLHXXX parts.............................................
    83364-09DH cover, Left, Vivid Black (FLHXXX)
    83483-09 grommet (FLHXXX)
    83482-09 insert (stud, FLHXXX, front top)
    2019 Tri Glide parts.....................................
    57200083DH cover, Left, Vivid Black (Tri Glide)
    11650 Grommet Side Cover, 3 needed (Tri Glide)
    In closing, if you can’t find an original FLHXXX cover, you can use a cover from a newer Tri Glide.
    I hope this helps. If you have any questions let me know and I will do my best to answer them.
    Respectfully,
    Mike
  3. #23
    Jun 2008
    Lovington, NM, U.S.A.
    You may want to contact Barnett Harley Davidson, they ship international and they're a reputable dealer. https://barnettharley.com/ I have no affiliation with this company.
    Retired trike builder
  4. #24
    Nov 2017
    AUSTRALIA
    Quote Originally Posted by blkout50 View Post
    Respectfully,
    Mike
    Wow, Mike, thats awesome. Thanks so much for going to the trouble to do that. Much appreciated, you may have saved my sanity!
  5. #25
    Jul 2019
    Albuquerque, NM USA
    You're welcome!
    If you go with a newer Tri Glide cover, you will need to remove the the original FLHXXX mounting stud (top front mounting point) and replace with the new Tri Glide grommet. You will also need to replace the original FLHXXX grommet at the top rear with a new Tri Glide grommet. You can leave the original FLHXXX grommet at the lower rear in place or remove, your choice. You will need to add a third Tri Glide grommet in front of the original FLHXXX grommet at the lower rear mounting point.
    Respectfully,
    Mike
  1. darn, lost gas cap
    By geraldlanc in forum Honda Trikes
    Last Post: 01-14-2012, 10:41 AM
  2. Lost headlights on trip
    By Jerry126 in forum Stallion Trikes
    Last Post: 10-13-2011, 10:26 AM
  3. We lost a family member....sad!
    By Papa Zook in forum General Discussion
    Last Post: 12-29-2010, 05:04 PM
  4. Lost in translation
    By The Wolf in forum Honda Trikes
    Last Post: 09-14-2010, 04:52 PM
