Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Likes Likes:  10
Thanks Thanks:  3
Page 2 of 2 FirstFirst 1 2
Results 21 to 25 of 25
Thread: fuses and breakers for reverse?
  1. #21
    250+ Posts RJS's Avatar
    May 2018
    Navarre Ohio USA
    Default Reverse motor problems
    Hi Everyone
    I have had an on and off time with my reverse motor on my 2014 Tri Glide for the last year or so.. last week it finally went out completely.. I have read on here and on other sites, that the best place to send the motor for repair is a place called Performance Starter/Alternator in Canton Ohio.. Well seeing that I work 6 blocks from this shop, I removed the motor and took it to see what they had to say.. I have found out a lot of info on this little guy.. such as when Harley first started making this motor, there was a small slot on the end that was open to the elements ( such as rain... they could have siliconed it shut )
    there was no way for it to run out.. this caused the inter workings to rust and corrode ( such as mine ) later they added a little tube for the water to drain out, this works but it still is not the greatest.. another thing that also happens is ( and they... Harley... don't tell you ) we tend to lay on the button to long or give it a lot of little bursts in order to back up.. both or no no's..
    the most is a 10 second button press and then let it cool for at least 2 minutes.. then press again if you have to.. Try not to back up on an incline.. or with a passenger onboard.. they rebuilt my motor and I installed it yesterday.. works excellent again I will definitely heed their info.. the cost to rebuild it again is not in my budget.. I thought I would pass the little info I got on so that it may help others
    My wife Debbie of 47 yrs passed away Jan 15th 2020.. I will now ride with a broken heart
  2. #22
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    Would you mind posting the price to rebuild the motor?
  3. #23
    May 2018
    Navarre Ohio USA
    For my Tri Glide it was $314.00 with out shipping.. everything is all new though..
  4. #24
    100+ Posts MontgomeryLittle's Avatar
    May 2011
    Murfreesboro Tn. USA
    The condition you describe sounds exacly like what I experienced with my wifes 2011 Tri-Glide. The breaker was all good, no fuses popped, only fuse I can imagine would affect it would be the Maxi fuse. Trike would start and otherwise work fine but found the battery was bad after load testing the battery. New battery still reverse motor no go.
    Did some searching online and found a couple of options: ebay rebuild swap can't remember price, J&P rebuild kit about $250, new reverse motor, different vendors, about $1800 to $2000. That was about mid to late May. My mind is in a jumble sometimes but I think the prices are close. Of course the motor went out when I was backing it out of the garage to remove her Harmon Kardon radio unit. It went out just prior to the reverse motor. She decided she could wait on the reverse so I didn't spend to much time with it and got the radio repaired instead. This winter I'll get into the reverse motor but the wiring, breaker, fuses, and the now new battery are all good according to my Fluke and load tester. Also read that bad or low battery could ruin the reverse motor. Always on a tender that showed green. Been bit by that bug before too.
    I put LED bulbs in her headlight and she swore that was when the radio started acting funny. Coincidence I told her, but that was my fault too, LOL. But then I got to wondering if I had done something, after all it had worked fine since new. Anyway I sent it to:http://www.ironcrossaudio.com/ . Its all good now. Found out there was damage from the handlebar clamp bolts not having enough clearance. There are bolts with shorter heads to allow for clearance. Funny I never got that bulletin. And there is a bulletin for it.
    [SIGPIC][/SIGPIC]
  5. #25
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Quote Originally Posted by MontgomeryLittle View Post
    With my 11 Tri I got tired of monkeying with the reverse motor and had a mechanical reverse in worth every penny 👍..
    2019 Tri-Glide.......
  6. DKCustoms postbit
  1. Reverse gear for a reverse trike
    By elwirth in forum General Discussion
    Last Post: 05-23-2019, 10:30 AM
  2. Replies: 8
    Last Post: 04-01-2019, 05:46 PM
  3. Replies: 6
    Last Post: 10-31-2017, 12:55 PM
  4. Reverse Or No Reverse?
    By GETRDONE in forum Harley Trike Conversions
    Last Post: 09-05-2015, 07:37 PM
