Likes Likes:  8
Thanks Thanks:  1
Results 1 to 16 of 16
Thread: Oil Leak
    100+ Posts
    May 2019
    England
    Default Oil Leak
    Hi all
    After fitting the Arlen Ness Method Clear to my freewheeler, I’ve noticed oil on the floor after riding.
    Ive watched a bit on good old YouTube to try and diagnose the fault, but I trust you guys better.
    Am I correct in thinking I need to fit a crank case breather?
    Is this normal behaviour after changing the air filter? I have also fitted new Cobra 909 mufflers, and the FP3. If this helps.
    As always if anyone has any advice for this novice I’d really appreciate it.
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Quote Originally Posted by AR198 View Post
    Hi all
    Are you sure it isn't blow-bye......And a little less oil in the crankcase will cure the problem.........Very common problem with some bikes....I had that with my 11 Tri.. and i solved it by using less oil [1/2 Qt] in the crankcase..
    2019 Tri-Glide.......
    100+ Posts
    May 2019
    England
    Thanks Rhino
    sorry mate i’m no mechanic and this is my first Trike/bike. Can you explain what blow by is please.
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Thanks Rhino
    Sometimes if the crankcase [Engine oil] is filled to the top of the full line on the dipstick oil will blow back out the air box and then seek its own level.....The early Can-am Spyder's were notorious for that...
    So much so the air box was nicknamed ''Oil box''...[I had one]..And Harleys have been doing it for ever...Some call it .''Puking''...
    100+ Posts
    May 2019
    England
    Rhino
    once again many thanks.
    Ill keep an eye on it then, and fingers crossed it sorts itself out.
    Ive checked the level and it is at the upper end.
    If it makes any difference, I didn’t notice this until I changed air filter. It may be a coincidence as I’d not really ridden it much prior to that.
  6. #6
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    Rhino
    Just a thought I'm not familiar with that air cleaner but make sure you installed the gasket correctly. There is a breather hole in the gasket that aliens with a hole in the throttle body. I believe there is only one way to alien the gasket but in case check it out.
  7. #7
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Rhino
    Mechanics 101........Go back to the last thing you changed....
    The new filter is less restrictive and lets the oil drip out....Or with the new filter you might run the engine a little harder ..Higher RPM's.....We all tend to do that when we first add performance equipment......Voom-Voom........
  8. #8
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    Just remove the air filter cover & air filter & look for oil by the throttle body & inside the cover.
    From the factory the 2 crankcase breathers are routed via rubber hoses to drain back to the intake.
    You can clean everything up & the air filter can be washed, if oil soaked.
    On my 17 Freewheeler, I keep the oil level right in the middle of the dipstick marks when checked cold.
    If overfilled, you can remove some oil with a big syringe & small rubber hose.
  9. #9
    100+ Posts
    May 2019
    England
    Thanks for the advice MDO
    ill remove it tomorrow and have a good look at everything.
    Ill let you all know how I get on.
  10. #10
    100+ Posts
    Feb 2019
    Olivette, mo. usa
    Dk custom's external breather system should help you quite a bit. Look at what they have to offer.
  11. #11
    100+ Posts
    May 2019
    England
    Hi Harrison
    i have seen those.
    Im in the U.K. and I couldn’t find them over here.
    i wanted to see if it was anything els before paying out for something like that.
  12. #12
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    It is nature of the beast for these engines to puke some oil from the head breathers into the air filter
    Some puke more than others
    As already said try running your oil a bit lower in the oil pan
    Also get a hold of D K Customs for a EBS for your trike, Read here http://www.dkcustomproducts.com/external-breather-systems-ebs-dk-faq-ebs
    You probably did not see this with your stock set up, the hose from the head breather was routed into the intake, the oil would have been getting sucked back into the engine along with water vapor
  13. #13
    100+ Posts
    May 2019
    England
    Jack
    I’m just glad it doesn’t look like it’s something I have done. As advised by others and yourself, I’ll drop my oil down a bit, after checking the correct fitting of everything.
    if I need a breather system, ill have a good look on uk websites for an equivalent version to DK Customs.
    Not sure why they don’t build them with the similar set ups to stoke with a direct return pipe.
  14. #14
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Jack
    Most after market air cleaners still dump the oily mist back into the intake
    I was surprised to see the Ness air cleaner with open bolts as you have
    The oily mess has no clear path but to saturate oil and eventually drip out
    Not a very well thought out set up IMO
    Hope you get it sorted out and keep us posted
  15. #15
    300+ Posts RedOregon's Avatar
    Aug 2015
    south of San Antonio
    Jack
    Because that direct return pipe spits oil into your intake air, which is about the last thing you want in your combustion chamber.
    2024 Tri Glide! Only modifications so far - transferred Rider backrest from old 2015 Freewheeler, just added highway pegs!
  16. #16
    100+ Posts
    May 2019
    England
    Hi all
    As an update, I need to hold my hands up and say this rookie has found the oil leak.
    I changed the derby cover and missed off the gasket. Only realised when cleaning the trike.
    still putting the external breather on, but glad I found the problem. Got a manual coming which will teach me how to do things properly.
  1. My Champion rear axel oil leak
    By saab9k in forum Champion Trike
    Last Post: 08-23-2012, 10:47 AM
  2. Another oil leak!
    By rwhgme in forum Harley Tri Glide
    Last Post: 03-28-2012, 08:21 PM
  3. Oil Leak
    By Roundabout in forum Harley Trike Conversions
    Last Post: 07-21-2011, 10:48 AM
  4. Oil pan leak tri glide
    By trikermutha in forum Harley Tri Glide
    Last Post: 07-12-2011, 06:54 AM
  5. Oil leak at 3500 miles
    By sarge7882 in forum Harley Trike Conversions
    Last Post: 09-09-2010, 07:23 AM
