Likes Likes:  6
Results 1 to 16 of 16
Thread: Highway Peg Adjustment Help
    Sep 2019
    Frankfort
    Default Highway Peg Adjustment Help
    Hey all. Just bought a 2006 GL 1800 with new Motorttrike kit installed. The highway pegs are too far forward on the engine guards but cannot figure out how to loosen the brackets to slide them back. At thought they were socket head bolts but the look rounder. Trying to attach a pic to show what I mean. Anyone have any ideas? Thanks for helping a noob!
    PS not able to post pic from mobile.
    200+ Posts
    NC Triker's Avatar
    Jul 2012
    Supply, NC
    Need a pic to understand what you are talking about
    Sep 2019
    Frankfort
    Hopefully this worked. Thanks.
    Sep 2019
    Frankfort
    They look like hexes but the bit that fits just spins with no flats to grab onto.
    Aug 2019
    Glasgow, Ky. 42141
    You're using the wrong size allen wrench if it turns in the hole.
    Barney
    Sep 2012
    Lakeland, FL
    What Barney said, the hexes do not appear to be rounded off.
    The pictures are a little fuzzy (no pun intended) ... but the bolts appear to be Torx ... it's a different type of "hex" ... takes a special wrench to get them loose or tightened ... Harbor freight sells a decent set for like $10 ... these are like Allen wrenches with the torx heads.
    In this pic you can see the sockets look like the screws your trying to get loose. IMHO.
    I got that picture from an eBay search.
    Jun 2010
    Indianapolis, In.
    Pic is out of focus but, I also believe those to be Torx head bolts.You need Torx head bits. Available at your local Home Depot or Lowes.
    Now the question becomes, what do you mean by "slide them back"? I also have an 06 and the front tip over bars are vertical. They have no horizontal portion to slide anything "back" on!!!!
    Can you post another pic taken farther away, in focus, so we can see the whole area to determined what adjustments are available to you
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    Sep 2019
    Frankfort
    Thanks guys! I was not able to get under the bike last night to actually examine the parts - took pics with my camera phone on selfie mode which is why they are fuzzy.
    I have a set of torx bits so will crawl under with those and my hex bits this evening and get a real look at the situation.
    As far as adjustment, the pegs are mounted on the horizontal portion of the engine guard but more to the front of that bar. My plan is to slide the mount back along that same horizontal to put the pegs closer to the saddle. I will post up a pick of the whole setup in just a second.
    Thanks again all!
    Sep 2019
    Frankfort
    Attached is a pic of the right side. Not sure if you can see but there is about an inch and 1/2 of the horizontal guard at the back that I am hoping to use to slide the peg brackets back a bit.
    80+ Posts Wingrider55's Avatar
    Oct 2015
    Kingston, Illinois
    I can see that they are Kuryakan highway pegs. The bolt head may be metric allen hex head.
    1500+ Posts
    Oct 2012
    Batavia Ohio
    Quote Originally Posted by Wingrider55 View Post
    If they are Kuryakan, and it sure looks like they are, I think you are 100% correct.
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Miles, you have Kuryakyn pegs.
    Kuryakyn sells extension for the that will either move the peg closer or further away.
    Jim Murphy
    Iron Butt Rider 2001
    Sep 2012
    Lakeland, FL
    Good job deputy dawg, think Torx.
    20+ Posts GLtryker's Avatar
    Jul 2016
    Tyler, TX, USA
    When I bought my 2010 the previous owner had Kury pegs on the short arms like yours. I'm 5'10" and could reach them, but wanted something more comfortable. Kury offers 6" and 4" extensions. I found a set of clean used 4" arms and they work great for me. I just checked the mounting and found that the bracket that mounts to the crash bar takes a 3/16th allen wrench. Peg is mounted to the arm and angle adjustment using 3/8th and 5/16th allen wrenches.
    Name:  20190921_164636 (Medium).jpg
Size:  62.2 KB Name:  20190921_164957 (Medium).jpg
    I love "helmet hair" because it means I've been riding!
    Sep 2019
    Frankfort
    Thanks for the help y'all!
  1. DK Custom highway peg mounting options
    By DK Custom Products in forum DK Custom Products
    Last Post: 04-09-2020, 09:56 PM
  2. Ciro 3D adjustable Highway Peg Mounts
    Last Post: 08-20-2018, 01:32 PM
  3. Rivco Highway Peg slippage
    By MMH in forum General Discussion
    Last Post: 08-27-2014, 07:33 AM
  4. One-off Horse Shoe Highway Peg For TG Rider
    By DK Custom Products in forum Harley Tri Glide
    Last Post: 11-22-2013, 02:58 PM
  5. Highway Peg Mod
    By Jim Smyth in forum Honda Trikes
    Last Post: 04-09-2013, 11:48 AM
