Likes Likes:  3
Thanks Thanks:  1
Results 1 to 18 of 18
Thread: Trunk lock issues ....
    20+ Posts
    Mar 2019
    Columbus, GA, USA
    Default Trunk lock issues ....
    I have a 2010 Tri Glide that I bought used and I have replaced the worthless plastic sleeve and the silly little clip that is supposed to hold the lock in. I cannot tell you how many times during the 2 months I've owned this trike that I have been flagged down by other traffic because the trunk was open. EVEN when I locked it and pulled on the handle for all I am worth to ensure that it's closed!
    Suggestions on this forum were to make minor adjustments in the locking pins. When I took it to my local Harley shop to get any adjustments needed that would make the trunk latch more firmly, I was told 'don't slam the trunk lid shut.' Well after $150 at the local Harley shop for adjustments, a new plastic sleeve and the REALLY annoying little metal clip, the trunk STILL comes open even when it's locked!
    So, I have begun researching a proper solution this this ill-designed and even poorer execution for the trunk lock.
    I was wondering if anyone else has had the time and energy to research or make this change?
    USAF PJ, '64-'72, 3 Tour Vietnam Vet.
    Old Trike - 2002 Sportster with Lehman Bandit conversion
    New Trike - 2010 Tri-Glide Ultra Classic
    1000+ Posts Texan's Avatar
    Jun 2013
    Texas
    I've got a '13 and have never had a problem. Was told right from the beginning to NOT slam the lid. To push on it until I heard a click then push it hard again until I heard a second click. Then I lock it. Like I said have never had a problem doing it this way.
    8~\o
    "Anybody can become an American but ya have to be born a TEXAN"
    "Ya know I haven't been everywhere but it's on my bucket list"
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Quote Originally Posted by RDinGA View Post
    I had that happen a lot with my 11 Tri-glide I Took a very small bungee cord (an eighth of an inch thick by 9 inches long) wrapped it around the two cables that hold the Trunk door and that little bit of tension squeezing the two cables together on the door stopped it from popping open ...
    2019 Tri-Glide.......
    20+ Posts
    Mar 2019
    Columbus, GA, USA
    Default WELL ......
    Quote Originally Posted by Texan View Post
    8~\o
    You must be a better man than I am! I have pushed on the center, not slammed it. Pushed on both corners where the latches are and THEN tugged my butt off to see if it would open, THEN locked it. Within 2 miles, people started honking and waving. I thought it might be that I just looked cool, BUT alas I was mistaken. The trunk was hanging open.
    Maybe I wasn't holding my tongue just right!
    2500+ Posts GARYD's Avatar
    Oct 2011
    GLEN ELLYN, IL. USA
    I'm beginning to wonder if the act of locking it is making it open. Sounds crazy, but everyone is saying they lock the door.
    I have NEVER had a problem with my lock and I'm on my 3rd TG. I have never locked the door except while in a motel parking lot.
    I would imagine if 90% of the locks are failing, Harley would be doing something about it. Especially if it's covered under warranty.
    Good luck to all.
    IBA#61162
    PATRIOT GUARD
    USMC
  6. DKCustoms postbit
  7. #6
    450+ Posts arnie's Avatar
    Dec 2011
    camp grove,il.usa
    just my 2c. if the trunk isn't latched, closed properly it doesn't matter if it's locked or not. With your trunk open, look at the hole where the mechanism is. When you push the button it should move up & down freely. Take a lil wd40 & give it a lil squirt. push the button in & out several time to make sure it is moving without binding. Once you do that then close it gently & see if you can hear it latch. You may need to adjust it now.
  8. #7
    20+ Posts
    Mar 2019
    Columbus, GA, USA
    Default Been there, done that!
    Quote Originally Posted by arnie View Post
    When I first got the trike, I used graphite lock lube on every lock on the bike, ignition switch, tour pack lock and the trunk lock. I spent a few years as a locksmith after leaving the military and the guy that taught me swore by the stuff. So I lubed the lock before, and after, putting the new plastic sheath on it.
    Sorry, but no cigar!
  9. #8
    2500+ Posts trikermutha's Avatar
    Oct 2010
    USA
    When you close the trunk use the key and lock it , I found when I did that the trunk stayed closed. But sounds like yours opens no matter what.
    Press both corners of the trunk lid and make sure it seats good. But sure you tried that too. May sure the lock is lubricated good too.
    I am sure I fiddled with other things too at the time..
  10. #9
    100+ Posts TrainingWheels's Avatar
    Aug 2019
    Amarillo, Texas, USA
    I locked mine last week and when I stopped the trunk lid was open. My flags were till in the trunk. I'll wait and see if it happens again. I will also check closer to see that it's closed tight.
  11. #10
    Oct 2011
    GLEN ELLYN, IL. USA
    Now that I think about it, I have never lubed the lock. Go figure.
    It's not like I open/close it hourly or even daily.
    The only thing I do to the rear door is apply silicone to the gasket twice a year.
    IBA#61162
    PATRIOT GUARD
    USMC
  12. #11
    1500+ Posts ShapeShifter's Avatar
    Aug 2018
    SW, Arkansas, USA
    Link to Other Trunk Lock Post.
    2016 Tri Glide Billet Silver w/Pinstripes ["Hi-Yo, Silver! Away!"]
    • "There is so much good in the worst of us, and so much bad in the best of us, that it ill behooves any of us to find fault with the rest of us." ..... James Truslow Adams
    • 2nd BN 33rd Armor "The Tiger Battalion" "1972 - 1974"
  13. #12
    550+ Posts
    520fd's Avatar
    Aug 2010
    Davenport, Iowa USA
    The way I open my trunk is, I insert my key in the lock, turn it counterclockwise, push the button in, (with the key still in the lock). The trunk pops open. I move the key back to center, pull the key out, and open the trunk. Moving the key back to center leaves the lock in the locked position. As said earlier, don't slam the trunk, but push it up to the lip and gently push on the door. Works great for me.
    2022 Tri-Glide Black.
  14. #13
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    I've seen more locks ruined by using WD40 than any other product out there. It will wash away any factory lube and gum up whatever it didnt. I use Dri Slide on all my locks.Semi auto pistols too.
  15. #14
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by Old Road Dog View Post
    Very good product for clutch and throttle cables
  16. #15
    1+ Posts
    Feb 2019
    Wentzville Mo USA
    Default trunk
    My brothers poped opened ,we replaced the hinges . No problems after that.
  17. DKCustoms postbit
  18. #16
    Oct 2011
    GLEN ELLYN, IL. USA
    Curious. What does the hinges have to do with the lock working? Some kind of alignment problem maybe?
    IBA#61162
    PATRIOT GUARD
    USMC
  19. #17
    1+ Posts
    Feb 2019
    Wentzville Mo USA
    Default trunk lock issues
    My brothers kept coming open . Checked it out and found that the hinges were wore out .
    This allowed the lid to move sideways . He replaced them and it seems to have solved the problem .
    2012 Tri-glide.
  20. #18
    Oct 2011
    GLEN ELLYN, IL. USA
    Quote Originally Posted by oldblue View Post
    2012 Tri-glide.
    Good post. I would never think of looking at that.
    IBA#61162
    PATRIOT GUARD
    USMC
  1. Trunk Lock
    By Deeman in forum Harley Trike Conversions
    Last Post: 11-28-2016, 10:41 AM
  2. Trunk lock handle
    By adventurer 08 in forum Yamaha Trikes
    Last Post: 12-03-2013, 09:16 AM
  3. Trunk lock on Hannigan kit
    By motoadvrider in forum BMW Trikes
    Last Post: 04-24-2013, 08:04 AM
  4. TG Trunk lock
    By Bones in forum Harley Tri Glide
    Last Post: 12-06-2011, 10:13 PM
