Likes Likes:  2
Thanks Thanks:  1
Results 1 to 4 of 4
Thread: FW Rear Brake Pads
    50+ Posts
    Apr 2018
    Ogden, Utah, USA
    Default FW Rear Brake Pads
    How much of a challenge to put new rear brake pads on a 2017 FW?
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    Quote Originally Posted by Moegy View Post
    If you have done car disc brakes before, they are about the same. While your back there, after changing them, I would flush the brake lines also to save you same time.
    I do believe you need to back off the parking brake adjustment before you push the caliper piston in
    1000+ Posts
    nucseal's Avatar
    Jan 2012
    San Antonio, Texas
    +1 That is absolutely correct. Learned that lesson installing brake pads on my Tri Glide.
  1. Rear Brake Pads
    By FRR in forum Harley Trike Conversions
    Last Post: 03-31-2014, 11:43 PM
  2. rear brake pads
    By arnie in forum Harley Trike Conversions
    Last Post: 02-23-2014, 08:40 AM
  3. Rear Brake Pads 2013 Tri Glide
    By JJHog in forum Harley Tri Glide
    Last Post: 07-23-2013, 07:37 AM
  4. Rear brake pads
    By tri glider in forum Harley Trike Conversions
    Last Post: 03-13-2012, 08:43 AM
  5. replacing pads on rear brake
    By wriddle in forum Harley Trike Conversions
    Last Post: 02-14-2012, 08:03 AM
