Likes Likes:  5
Thanks Thanks:  1
Results 1 to 3 of 3
Thread: Valkyrie Forks rebuild with Goldwing 1800 progressive springs
    90+ Posts
    Sep 2012
    Magnolia, Ms USA
    Default Valkyrie Forks rebuild with Goldwing 1800 progressive springs
    My right one has been leaking a while and was trying to hold out till my rake kit arrives. Anyway pulled the right side down and found oil seal had been damaged I guess by someone attempt . All sliders and bushing bad both sides. The right side that wasn't leaking only had about 10 oz of oil in it. Before I rebuild them I had 3 1/4 on my forks and didn't take much to bottom out. Both stock springs was out of spec. Love the progressive springs I put 22 oz in the right one and 24 oz in the left one. I used ATF dexron/merc fluid. Rides so much better and now has 5 3/8 free play in the forks. Also found bad wheel bearing and I had ordered some new ones with dust seals. Had to replace brake pads due to the fork oil had soaked them. All is better now and rides like a new trike.
    David
    good job nice when it all works out
    5250+ Posts Pegasus1300's Avatar
    Spring City,Utah, USA
    there is nothing like the feeling of enjoying the fruits of a job well done.
    Happy TRAils/NSD
    Paul
  1. Progressive springs for front forks?
    By brianl in forum Honda Trikes
    Last Post: 08-02-2017, 06:00 PM
  2. Progressive springs with 6* rake??
    By wanderingbear in forum Honda Trikes
    Last Post: 10-21-2011, 11:20 AM
  3. Replies: 23
    Last Post: 06-24-2011, 11:39 PM
  4. Progressive front fork springs
    By DeerWrangler in forum Honda Trikes
    Last Post: 03-05-2011, 11:40 AM
  5. progressive springs
    By jim peacock in forum Honda Trikes
    Last Post: 08-28-2010, 04:05 AM
