Likes Likes:  12
Thanks Thanks:  6
Results 1 to 20 of 21
Thread: 2008 GL1800 30k Seal Leaking in Transaxle
    Sep 2019
    parkers lake, ky, usa
    Cool 2008 GL1800 30k Seal Leaking in Transaxle
    Hello from the Hills of Ky/Tenn.... I have a Transaxle Driveshaft Seal leak. I am wondering ifthis could be a sign of this dreaded CSC Driveshaft problem. I have not had a driveshaft failure, but, have always had some play somewhere in the drive line. New to this problem of driveshaft issues .... Or is the Seal Leaking a sign that I have other issues?..... Thanx fer ya time.....
    Dan
    :zombie:
    1500+ Posts ShapeShifter's Avatar
    Aug 2018
    SW, Arkansas, USA
    Smile Hello!
    Dan, Welcome from SW Arkansas.
    Can't help with the transaxle seal leak, but there are two other forums here where you can post questions.....the Honda Forum and CSC Forum, both have knowledgeable owners who can most likely help you get it sorted. Wish you the best.
    2016 Tri Glide Billet Silver w/Pinstripes ["Hi-Yo, Silver! Away!"]
    • "There is so much good in the worst of us, and so much bad in the best of us, that it ill behooves any of us to find fault with the rest of us." ..... James Truslow Adams
    • 2nd BN 33rd Armor "The Tiger Battalion" "1972 - 1974"
    33500+ Posts
    David357's Avatar
    May 2015
    Hobe Sound, FL.
    Hi Dan,
    to our Trike Talk Family.
    If you contact the CSC technical department directly, They may be able to help you out more effectively.
    Dan.......Welcome to Trike-Talk...........And as previously posted, Try shouting out on the Honda and or the CSC Forum here on Trike-Talk....
    Again.....Welcome........
    Dec 2013
    Clarion PA USA
    Welcome to the forum from Western Pennsylvania lots of help around here surely someone will chime in soon. Travel safe Fred
    Jun 2008
    Lovington, NM, U.S.A.
    Hello and to Trike Talk, glad to have U with us.
    Retired trike builder
    May 2018
    Angleton, Texas
    To the Trike Talk Family! FROM SOUTH Angleton, TX
    Howdy Dan!
    Welcome to Trike Talk
    Contact CSC here https://californiasidecar.com/contact
    Welcome to the Gang from Western Colorado.
    When broaching this issue in other areas. you might consider giving out some more info. Miles on bike, miles on conversion, which CSC conversion, and some mantenance history. Those type of info will help to diagnose the issue more completely.
    4250+ Posts
    Marc H's Avatar
    Dec 2011
    Evensville,Tn.
    Welcome to Trike Talk Dan!!! The models that had the driveshaft issue had a shaft with the stock front u joint and a rubber coupler on the rear.It also had a gearbox that effectively moved the input shaft to the right to allow the shaft to run straight.This style was only used a few years if I remember right.The replacement removed the box and the shaft had joints on both ends.
    1989 GL1500 Goldwing (SOLD)
    2006 GL1800 CSC
    450+ Posts
    Dec 2018
    Perry, Georgia, United States
    Welcome to the forums from Middle Georgia Dan!
    1500+ Posts Ray Paige's Avatar
    Aug 2018
    Bitterroot Valley, MT, USA
    Welcome From Montana
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Cool
    Dan, Welcome to Trike Talk from West Virginia.
    Jim Murphy
    Iron Butt Rider 2001
    16500+ Posts
    ol' school's Avatar
    Sep 2015
    Mercersburg, PA
    Jun 2010
    Indianapolis, In.
    Been watching this thread. Help me understand "transaxle"?????
    I have never known of any trike that has the transmission as part of the rear end?!?!
    So, I am assuming the OP has the conversion that included the gear case that attempted to align the drive shaft with the output of the Wings transmission to straighten it up, which it still didn't quite get perfectly straight!
    If this is correct, the OP could check out the drive shft conversion from https://www.mtn-motorsportstn.com/.
    Have not heard of any failures using this drive shaft.
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    30+ Posts
    Dec 2013
    Polson,Montana
    Is this my old buddy from Indiana? Lee here from Montana. (W7AX) Sorry about the hijack...
    Sep 2019
    Thumbs up CSC Reply
    Hi All,
    Thanks for your helpful response on this Transaxle leak problem... After talking with (will) CSC he had the fix on the issue . The oil seal is not leaking, the leak is coming thru the yoke spline shaft. If I had looked more closely I would have seen that the oil was being thrown from the yoke and no oil on the housing seal area. The fix is simple! Will instructed me to use Blue ATV sealer and apply to the Shaft and the yoke spline. I let dry over night and test drove on 100 mile test run. I left the pan cover off till problem was solved. After test run, no oil leak and a very happy customer!
    If anybody having any CSC issues, call Will at ext 30 from CSC 800 number.... He is a very nice guy and knows his stuff. CSC is lucky to have a man with his knowledge .
    Thanks everybody for your responds!
    Goldwing307
    :zombie:
    Jun 2010
    Indianapolis, In.
    Quote Originally Posted by Montana Lee View Post
    Yes it's me.
    Tried to send you a private message but, for some reason it tells me I can't!
    Patriot Guard
    Was a LEO
  19. #19
    30+ Posts
    Dec 2013
    Polson,Montana
    I tried to send you a private message also. Apparently that feature doesn't work here.
  20. #20
    Jun 2010
    Indianapolis, In.
    Seems both parties must be Gold Club members to exchange private messages.
    Patriot Guard
    Was a LEO
  1. Leaking rear transaxle seal
    By KeithK in forum VW Powered Trikes
    Last Post: 03-29-2019, 09:10 PM
  2. Fork Seal leaking again HELP
    By RUMRUNR in forum Honda Trikes
    Last Post: 10-01-2017, 11:47 AM
  3. Catching an axle seal prior to it leaking
    By GoldWingrGreg in forum Honda Trikes
    Last Post: 06-24-2017, 06:17 PM
  4. Leaking Left Fork Seal
    By Muleskinner in forum Honda Trikes
    Last Post: 08-11-2010, 11:18 PM
