SSpoon9Marc HNew Member Introduct...Hello from VA
SSpoon9ZammyNew Member Introduct...Hello from VA
SSpoon9Uncle FesterNew Member Introduct...Hello from VA
SSpoon9rhino 2New Member Introduct...Hello from VA
SSpoon9trike ladyNew Member Introduct...Hello from VA
SSpoon9SullyNew Member Introduct...Hello from VA
SSpoon9Jack KlarichNew Member Introduct...Hello from VA
SSpoon9GorillaNew Member Introduct...Hello from VA
SSpoon9SSpoonNew Member Introduct...Hello from VA
Likes Likes:  284
Thanks Thanks:  16
Page 9 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 161 to 180 of 219
Thread: 4th generation of my trike
  1. #161
    150+ Posts
    Jan 2011
    Osceola Mills,PA,USA
    Yes , I was planning on lettering. TP30 on the fenders for tire pressure and 73VW4G for ID number. 1973 VW and fourth generation. Maybe star on the tank? I was toying with the idea A45200, that was Merle Haggard's number at San Quinten. Most of the lettering I've seen was in white. It might show up better.
  2. #162
    Dec 2014
    Grand Junction, Co. USA
    I know this is a day late and a dollar short ... but ... did you give any thought to some kind of vent to help cool you and the engine in the lowers panels in front of your legs?
  3. #163
    150+ Posts
    Jan 2011
    If you remember my engine is in the rear so I don't get any heat from it. On the body, beside the passenger's seat, are 2 channels that will direct any trapped air back to the engine.
    Looking from the front, the panel isn't much wider than the front end.
    The panel will mostly keep any rain or mud from being thrown on me from the tire.
  4. #164
    Meme Master
    Jan 2014
    Farmington, NH USA
    Big Merle fan too.
    Not sure many would recognize his prison # though, unless you did a face pic nearby to go with it?
    Isn't it weird that in AMERICA, our flag and our culture offend so many people...but our benefits don't???
  5. #165
    Dec 2014
    Quote Originally Posted by irondad01 View Post
    WOW ... It looks so much "bigger from the side ... the vents don't seem so necessary now ... guess my brain is stuck in the "Harley Heat Mode"
  6. #166
    150+ Posts
    Jan 2011
    A splash of color was added.
    I have all the wiring done except the tail lights on the body. The front brake line is a little long because I had ape hangers on it before. I may try to reroute it a bit on the top to hide it better. The throttle cable is hooked up. I need to get some retro looking hand grips.
    This is a trick I learned for fastening things.
    Use a piece of plastic tube the length you need and thread the zip tie through it. When tightened it makes a stand off so things aren't rubbing.
    I made this dash before. I piled plaster paris on the tank and shaped it the way I wanted then put fiber glass over it. When it cured I knocked the plaster out of it. Those are marine switches so they are water proof. I didn't have a horn stamp so I used an 0 a V an I and an I. The speedometer is an Acewell. It's worked great for 12 years.
    The body is primed, probably paint it tomorrow. This paint takes a long time to cure. That's what I read about it but they say it's super tough after it's cured.
  7. #167
    600+ Posts TomyJ's Avatar
    May 2016
    Hemet, Ca. USA
    Default Handlebars
Size:  9.2 KB I love apes tall and mini, BUT! not on this, It is looking so cool this time around, Please re-think the handlebars???
    JakeJacobsen@Pinterest.com
  8. #168
    150+ Posts
    Jan 2011
    I think you're probably right. I had those handle bars hanging around so I put them on but they bothered me because they didn't look old enough. I'll have to shop around a bit.
    I've been mostly waiting for paint to dry. Always exciting. I did get the gas line run and a few other small things done. I think I'll get the body on tomorrow then I can mount the tail lights.
  9. #169
    150+ Posts
    Jan 2011
    I got a bit done these last couple of days.
    Body is on, tail lights wired, seat on. If I put a little gas in it I could fire it up and go for a ride, not legally with out fenders.
    Battery is bolted down. The battery disconnect switch is hooked up. It will be hidden when the rear seat is on but easy to get to.
    I have the tail lights wired so they are the turn signals too. While the fenders and lids are drying I'll break out my wife's sewing machine and work on the rear seat.
    New handle bars and grips are on their way.
  10. #170
    2000+ Posts trikeman's Avatar
    Oct 2010
    Jackson Tn. Madison Co.
    Looking Good
  11. #171
    150+ Posts
    Jan 2011
    Thanks everyone.
    I mounted a breather box for the engine inside the engine compartment then I worked on the seat.
    That's carpet padding from Lowes. My brother had a roll left over and gave it to me. It's 1/2" thick so I glued 8 layers together to get the 4" I needed for the bottom. The back is 1 1/2" thick. It's pretty stiff. About like a Corbin seat. Softer foam lets you bottom out. You can't bottom out the stiffer stuff so there is still some give when you hit a bump.
    The handle bars and grips just got here so I guess UPS is still working.
  12. #172
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    WOW I'm impressed. It is coming out very nicely.
  13. #173
    150+ Posts
    Jan 2011
    The rear seat is done. I have a lot of respect for people who sew seats for a living.
    I used a dimpled material for the top and plain stuff for the sides to match the front seat. I was going to do the double stitching to match but didn't think I could pull it off without messing up. It's really pretty comfortable.
    I got the storage lid and the engine lid on too.
    When I was changing the handle bars I stripped the banjo bolt hole for the brake line in the master cylinder so I'll be repairing that. The handle bars are supposed to have the same bend as older Harley big twins. I like them a lot better, thanks TomyJ for the suggestion to change bars.
    Fenders mounted probably tomorrow. There isn't a lot more to do to finish. Lettering whenever I can get to someone who does that. This whole Shelter in Place is sure putting a crimp in a lot of things.Oh well, we have to do what we have to do.
  14. #174
    May 2016
    Hemet, Ca. USA
    "This whole Shelter in Place is sure putting a crimp in a lot of things. Oh well, we have to do what we have to do". I hear ya Carl my wife will not let me out for anything but food, Sure am glad I am retired with steady SS income...
  15. #175
    400+ Posts
    Feb 2020
    Washington Pa USA
    you have skills looks great
  16. #176
    150+ Posts
    Jan 2011
    These are the latest basement photos.
    I have a fitting ordered for the front brake and I have to get some lettering done. Everything else is complete. Once I get that done and we get some nicer weather I'll pull it outside and take some better pictures. I have a 1/4 mile mud pit for a driveway so hopefully that will dry up and these travel restrictions will go away. I think it would be hard to practice social distancing riding this because people would want to talk about it.
  17. #177
    500+ Posts LarryA's Avatar
    Jun 2016
    milnor n.d. usa
    I'd say you definitely nailed " the look", a machine the Desert Rats could only wish for!
    The length and heavier front should make for good riding and handling.
    Well done, my friend!
  18. #178
    800+ Posts Motorcycle Mike's Avatar
    Jul 2014
    Lawrenceville, Ga
    I've really enjoyed watching this build, I'm kinda sorry it's over.
    Nice work building a true one of a kind.
    You don't quit riding because you get old.
    You get old because you quit riding.
    Mike & Shirley
  19. #179
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Thumbs up
    Looks darn good, thanks for putting together this thread with your build
  20. #180
    20500+ Posts
    Zammy's Avatar
    Jan 2015
    W. Florida
    Looking good Carl, I thoroughly enjoyed watching the build, almost there !!!
  1. Motor Trike 3rd Generation Driveshaft zerk fitting
    By tndragonrider in forum Honda Trikes
    Last Post: 05-22-2016, 02:19 PM
  2. Need help with my 1st generation CSC drive shaft
    By michael2480 in forum Honda Trikes
    Last Post: 08-11-2014, 06:50 PM
  3. Next generation Gold Wing
    By Papa Zook in forum Honda Trikes
    Last Post: 03-14-2010, 11:51 AM
