Likes Likes:  284
Thanks Thanks:  16
Page 8 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 141 to 160 of 219
Thread: 4th generation of my trike
  1. #141
    150+ Posts
    Jan 2011
    Osceola Mills,PA,USA
    Thanks everyone for the likes , comments , and following along.
    Today I took my wheels and got new tires on them.
    I really wanted a more aggressive pattern but to get that in the size I need I would have had to go to a winter tire. The compound would have been a lot softer and I think the summer heated roads would have torn them up. These are all- season ones.
    I'll probably start to put the front end together next. That will put some weight up front so I can begin to hang stuff on the back like the transmission and shocks. I really need to get a front tire so it's all stable.
  2. #142
    150+ Posts
    Jan 2011
    I put the front end together as far as I can without a tire.
    I brushed the chrome on the shocks with a Scotch Brite to take the shine off.
    I mounted the shocks, transmission, and axles in the rear.
    I can now start to put the plumbing for the clutch and brakes on. You have to think a couple steps ahead so the stuff you need is painted and dry when you need it.
  3. #143
    100+ Posts
    Dec 2017
    Chauvin, La
    Default Progress
    I keep peeking in on your progress. It's really, really nice. I especially love the front forks. I'm currently trying to get my and my wife's Yamaha's converted to trikes and in fact removed the second fender from the mold today. Once they are done I'm pulling my friends VW trike out of the corner and start on it. Your build is giving me ideas I can do for little to nothing using what we have lying around. Of course, I need to first see if the engine case can be saved. Thanks for the inspiration.
  4. #144
    150+ Posts
    Jan 2011
    Thank you. I've been following your builds too. Very impressive work. On mine I've found that you can do complicated stuff if you break it down to the basics and do one thing at a time. The main thing is get out there and do something.
    Keep up the good work.
  5. #145
    150+ Posts
    Jan 2011
    Brakes and clutch all plumbed and bled.
    I got the shifter assembled and put on and adjusted too.
    This is my clutch and brake setup. Dune buggy master cylinders, about 8 to 1 ratio on the arm, and the pedals came from Walmart. They were the pegs the kids put on their BMX bikes on the axles to do stunts with.
    When I went out to get the paper my new front tire was out side my door. I guess that will be next.
    I can't believe it just passed 50,000 views on this build. Thanks everyone.
  6. #146
    We are all amazed at your mad metal skills ...
  7. #147
    450+ Posts
    Mar 2018
    Fernley
    I am glade I got to keep an eye on your work. This thread has a lot of good idea's and awesome metal work, thank you for sharing with us.
  8. #148
    150+ Posts
    Jan 2011
    Thanks, I'm not sure about mad metal skills, my wife thinks I talk and act like a mad man most of the time.
  9. #149
    Quote Originally Posted by irondad01 View Post
    She could think worse of ya ... at least you are easy to find ... not running around wild ... ... I'll bet she loves your passion for your trike ...
  10. #150
    150+ Posts
    Jan 2011
    She's a roller.
    I got the front tire mounted and on. It's a Continental TKC70. I also cleaned the engine some and put it on. Now that it's hanging on the back I will change the oil and set the valves and a few other things.
    I did a little painting on some front end stuff so it can cure while I work on the engine. I'll soon have to get my paint for the body ,tanks ,and fenders.
  11. #151
    2000+ Posts trikeman's Avatar
    Oct 2010
    Jackson Tn. Madison Co.
  12. #152
    450+ Posts
    Mar 2018
    Fernley
    Over the months I have watched this project go thru the stages, wow, it is going back together and looking so good each day. We do a lot with what we have or know we can get, it has been a real pleasure watching you work and share with others.
  13. #153
    150+ Posts
    Jan 2011
    Thanks, posting it here helps to keep me motivated. I've learned so much from others that I'm glad I can pass a little on.
    I bolted a few more things on.
    Handle bars, light, and fender brace. I can't put the light bulb in until I get the wiring in there.
    This might be hard to see but this is the trailer hitch/ body mount frame.
    Then I spent a bunch of time with a scraper getting rid of old white paint. I was impressed with how well it was stuck on. It was Valspar paint that I had bought at Tractor Supply years ago.
  14. #154
    150+ Posts
    Jan 2011
    I spent some time with my paint room. The tanks are in primer and I coated the underside of the fenders with bed liner.
    Next I dug out my do it yourself wiring kit in a tote.
    There really isn't much to it. Not many wires on an old VW. I feel like I'm cheating compared to some of you guys building a more modern trike with fuel injection and all that other stuff.
    I have to make a different mount for the speedometer. The angle was wrong and I could just see it before. Now I raised the seat so it will be worse.
  15. #155
    Meme Master
    Jan 2014
    Farmington, NH USA
    Lookin good Carl...
    I'm with you on keeping it simple.
    This is in no way directed at anyone in particular: If someone were to "inherit" a project with too much electronic tech added on it could create a huge headache for the one working on it, or trying to work on it!!!
    K.I.S.S.
  16. #156
    150+ Posts
    Jan 2011
    My body and fender paint was due in today at Home Depot and when we checked on it they said it was damaged in shipping. It had to be reordered so it will be towards the end of next week when it comes in. I still have things to do like put body filler on the joints of the body and primer so it won't slow me down much.
    I'm thinking if my order was damaged that probably means there was paint all over some other stuff too. Hopefully it wasn't something someone was waiting on.
  17. #157
    150+ Posts
    Jan 2011
    I worked on putting bed liner in the storage compartment and body filler on the body joints today. Nothing worth a picture.
    Friday I made a new mount for the speedometer. It's now adjustable.
    The old one is on the left. It was aluminum and held the speedo. in one position. It wasn't the right angle to see at night. I'll be able to set the new one, on the right, where I need it.
    Looking through my scrap pile I found some old floor boards I had made and had on the trike for a while.
    They fit my feet just right. Maybe because I used my boots for a pattern?
  18. #158
    150+ Posts
    Jan 2011
    There sure is a lot of sanding involved with getting a body ready for paint. And I'm not even going for a show type finish, just something good enough for WWII.
    I also started to put the wiring back on.
    I have to wait on the dash until the tanks are bolted on.
    This is my fuse setup.
    These are Caterpillar type fuse holders. The one on the rag is broken so I have to replace it. The panel is just below the front seat, easy to get to. I ordered a new holder and a battery disconnect switch.
  19. #159
    150+ Posts
    Jan 2011
    My paint came in at Home Depot and this can was dented but still sealed.
    The color is a little more tan than I wanted but it still looks military and I don't have anything I have to match exactly.
    Paint cans drive me nuts. You would think over the years they could come up with a better design for pouring. The paint always ends up in the lip at the top of the can.
    Sometimes when you are so bad at something it turns out kinda cool. Like I said before, I'm no painter so I approached the tanks with a lot of stress. I have an air gun but the tip is too small for this paint. They recommend you don't thin it. I bought a Harbor Freight electric sprayer that you use to paint fences and stuff. When I started spraying it went splat and put gobs all over. I thought . The more I looked at it the more I liked it. It looks industrial. Now if I can replicate it on everything else.
    I'll let it dry over the weekend before I bolt them on. I also got the front fender painted.
  20. #160
    500+ Posts LarryA's Avatar
    Jun 2016
    milnor n.d. usa
    Color and texture look great.....maybe some military stensiling in black or tan?
  1. Motor Trike 3rd Generation Driveshaft zerk fitting
    By tndragonrider in forum Honda Trikes
    Last Post: 05-22-2016, 02:19 PM
  2. Need help with my 1st generation CSC drive shaft
    By michael2480 in forum Honda Trikes
    Last Post: 08-11-2014, 06:50 PM
  3. Next generation Gold Wing
    By Papa Zook in forum Honda Trikes
    Last Post: 03-14-2010, 11:51 AM
