Gernerwa10Jack KlarichNew Member Introduct...New Member from Bellingham, WA
Gernerwa10trike ladyNew Member Introduct...New Member from Bellingham, WA
Gernerwa10GorillaNew Member Introduct...New Member from Bellingham, WA
Gernerwa10rhino 2New Member Introduct...New Member from Bellingham, WA
Gernerwa10Marc HNew Member Introduct...New Member from Bellingham, WA
Gernerwa10Uncle FesterNew Member Introduct...New Member from Bellingham, WA
Gernerwa10ZammyNew Member Introduct...New Member from Bellingham, WA
Gernerwa10hardwickbvNew Member Introduct...New Member from Bellingham, WA
Gernerwa10ol' schoolNew Member Introduct...New Member from Bellingham, WA
Gernerwa10GernerwaNew Member Introduct...New Member from Bellingham, WA
Speed Bleeders
Too Pa Pa Zook
Likes Likes:  5
Results 1 to 14 of 14
Thread: Racking my brain
    1+ Posts
    Oct 2019
    Houston MS
    Default Racking my brain
    Two months ago I bought a used 2016 Tri Glide 103 ci it had 1208 miles on it when I bought it now it’s got 2300 miles on it. I’ve never had any issues at all since .......... but now to let you know what issue I am having is .......... The other morning I get on it to go for a ride I go about 6 miles and just out of the blue I’m going down the road everything is fine and I give it throttle next thing I know I start here in the motor race up but I’m still going I let off the throttle and then get back in it everything‘s fine but within the next five or six more miles it does it a couple times again just simply going down the road when I give it a lot of throttle I can hear the motor race up. I rode it back home bout 15 miles everything is fine bike is running fine not making any noises at all transmission sounds perfect the fluid in the transmission is perfect and clean since then I have rode the bike a couple times around and it seems like after the bike gets warmed up good then it wants to start doing the issue again but like I said The bike runs fine cranks fine idles fine motor sounds perfect no issues at all other than the fact that when I give it throttle it’s like I’m hearing the motor race up can anyone help me or have any ideas of what my issue may be
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    I had issues with the DBW throttle control. I’d be riding and it would throttle up on its own.
    1+ Posts
    Oct 2019
    Houston MS
    What is a DBW
    1+ Posts
    Oct 2019
    Houston MS
    Mine is not doing it on its own tho It’s only doing it whenever I give it throttle
    300+ Posts
    Mar 2018
    Waelder, Texas
    Clutch slipping? Did you maybe use wrong oil in primary or an additive that was not compatible? Just a thought, good luck.
  6. DKCustoms postbit
  7. #6
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    If the engine RPM increases when you give it throttle, but you do not have an accompanying increase in speed, then it is almost certainly the clutch slipping.
    Either the clutch needs adjusting/replacement or there is a problem with the fluid in the primary (not the engine or trans fluid).
    www.DKCustom.com
  8. #7
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Quote Originally Posted by Tiny0426 View Post
    Like previously stated........Your clutch is slipping.....
    2019 Tri-Glide.......
  9. #8
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Sorry, I understood the problem wrong. DBW = drive by wire throttle.
  10. #9
    10+ Posts andyjr11's Avatar
    Jun 2019
    cheswick, Pa, USA
    The first thing I would do is pull the derby cover off and see if the clutch rod is moving the full stroke when you pull the lever. It could be your clutch slave cylinder is sticking and not releasing completely.
  11. #10
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    What does your clutch lever feel like?
    Have you checked your clutch fluid?
    2016 model should have had the fluid flushed ( HD recommends every 2 years)
    What fluid is in your primary and how much?
  12. #11
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    It's truly amazing Jack how I think it and you ask it!
  13. #12
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by MDO View Post
    I think maybe we are twins
  14. #13
    Oct 2017
    St. Louis, MO USA
    Twin brothers from different mothers.
  15. #14
    600+ Posts ISP-FL's Avatar
    Mar 2017
    Lake Suzy, FL USA
    If you haven't already, start with the fluids as has already been suggested. It wouldn't be the first time a dealer either forgot to put a fluid back in a bike or put the wrong fluid in one before letting it go out the door.
    Current: 2019 Trike (custom 130ci T-Man kit with Darkhorse bottom end)
  1. Brain Cramp
    By Rosy in forum General Discussion
    Last Post: 04-19-2012, 09:24 AM
  2. Update on my wife brain surgery
    By motorcyclemania in forum General Discussion
    Last Post: 03-24-2012, 09:55 AM
  3. Brain's On Overload
    By Beeper in forum New Member Introductions
    Last Post: 04-04-2011, 01:33 PM
  4. Brain's On Overload
    By Beeper in forum General Discussion
    Last Post: 04-03-2011, 02:40 PM
  5. New here, need to pick a brain or two
    By KatsTrikeDreamin in forum New Member Introductions
    Last Post: 07-29-2010, 11:42 PM
