Likes Likes:  3
Thanks Thanks:  6
Results 1 to 12 of 12
Thread: My gearshift will not engage
    Default My gearshift will not engage
    2008 STALLION
    Something broke and just get loose ?
    It stated with that i have to shift to second gear and then to d to engage
    but now it will not engage to any of the gears
    please help
    thank you
    FUN:party:
    I'm betting that there is a bushing of some sort both or at least one end of the shift cable that is worn. My wife is having the same issue with hers but I will not be looking at the issue until later this week.
    Default GEARS
    I STARTED TO TAKING EVERYTHING APART HOPING TO FIND WHERE THAT WIRE LEADS TO
    FUN:party:
    Quote Originally Posted by vmcvr2003 View Post
    Victor i found my wife's problem. The shifter end of the shift cable the bushing was completely gone. The cable end loop stayed over the post but there was about a 1/2 inch of slop so it did not hit the proper gears when moved. The cable could of easily come off making for no ability to change gears at all.
    I made my own bushing out of 1/4 in rubber hose 3/8 in long. Put it on the post on the shifter and then slid the cable loop over the bushing. Because the factory bushing has some kind of locking mechanism to hold the cable on, my repair I had to devise a way to keep the cable from sliding off. I took 2 plastic wire ties and made o loop around the cable securing it to the shifter post. Works great.
    Look under the hood at the shifter and see if the shifter cable has not come off causing your problem. If it is on see if you can push it off the post and if there is slop in the post to the cable end. You might have the same problem. There is also a similar connection at the transmission end but looking at pictures I think it is a little different and might not be subject to the same wear. Keep us advised.
    Default GEARS
    i check the wire by the shift gear and its connected
    i thinking that is by the gear box ? any idea how to get to gear box
    i look under the bike and no luck finding the box or wire
    do you have any photo of what you did ?
    Gorilla
    thank you for help
    FUN:party:
    Gorilla
    thank you for help
    Victor just so we have our terms correct, when you say wire are you referring to the shift cable? The shift cable is a good 1/4 thick end with a loop and the cable itself runs in a sleeve. Sorry no photos
    The cable attaches to a lever that comes out of the side of the transmission. This lever is located on the left side of the transmission. It is right in by the master cylinder. The cable is mount similar to what you see at the shift lever but the connector appears to be more rugged.
    Default Shift pic
    Default Shift pic 2
    Default Gears
    Thanks Gorilla
    With your guidance I was able to track the problem down it was the cable came loose by the gear I put it back and use Loctite and hopefully it won’t happen again
    FUN:party:
    Default Gear
    Sorry I try to put some pictures on of the problem but I had no luck
    Sorry disabled veterans heavy medication so I feel better I’ll try again
    FUN:party:
    300+ Posts
    Signal Mountain Tn
    Ted I appreciate you posting the pictures. I am not aware of a problem right now, but it's good information to have. I was wondering what the white wire is running crossways in the top picture??? Thanks.
    Hidden FM radio antenna I have the Marine Jensen radio installed in the dash where the Sony controller was.
  1. Not new---just checking in. Do not post much mostly just read
    By rdtrkrdr in forum New Member Introductions
    Last Post: 01-05-2019, 12:44 PM
  2. Hello from Wisconsin, not new just have not been on much.
    By slickrick in forum New Member Introductions
    Last Post: 06-04-2016, 01:11 PM
  3. Replies: 5
    Last Post: 05-10-2016, 06:40 PM
  4. It's not a Trike, It's not a Bike, What is it ??
    By Sully in forum General Discussion
    Last Post: 11-04-2014, 11:31 AM
Tags for this Thread
