ADSavarese6Marc HNew Member Introduct...New member from FL
ADSavarese6ADSavareseNew Member Introduct...New member from FL
ADSavarese6Phu CatNew Member Introduct...New member from FL
ADSavarese6trike ladyNew Member Introduct...New member from FL
ADSavarese6Uncle FesterNew Member Introduct...New member from FL
ADSavarese6rhino 2New Member Introduct...New member from FL
Results 1 to 3 of 3
Thread: brake fluid check
    40+ Posts
    Mar 2019
    Myrtle Beach
    Default brake fluid check
    whats the best and easy way to check brake fluid on my stallion my brake lite os on in my dash
    Quote Originally Posted by Just BOB View Post
    The fluid reservoir is located on the master cylinder under the trike a little more than half way back. It is inside the frame work more on the left side. You will need to remove your seat and have a long neck funnel if you need to fill it. The reservoir is semi see through so just by shining a flashlight on it you can see the level. It is only a very little visible from above so you have to get under the trike to see it. When you have the seat out it is just to the left of the back rest post receiver but under the trike. Hope that helps you.
    40+ Posts
    Mar 2019
    Myrtle Beach
    thank you for the info
  1. ATTENTION A MUST CHECK * * check Radiator by pass cap
    By Doc7402 in forum Stallion Trikes
    Last Post: 07-12-2019, 09:43 PM
  2. Bleeding the brake/clutch lines to replace the DOT 4 brake fluid.
    Last Post: 10-07-2018, 05:03 PM
  3. Replies: 9
    Last Post: 03-14-2017, 03:44 PM
  4. Brake fluid replacement on Champion.
    By Shimpy in forum Champion Trike
    Last Post: 01-25-2013, 04:10 PM
  5. Replies: 1
    Last Post: 09-18-2011, 01:23 PM
