Results 1 to 6 of 6
Thread: Roadsmith questions
    User ID
    29633
    Apr 2019
    Arlington,AZ, USA
    Default Roadsmith questions
    I recently had a Roadsmith conversion done on my 08 Goldwing a have a couple of questions for you Wing owners. I have the aux fuel tank and instead of needing to flip on the switch to pump the fuel over to the main it seems to either be gravity feeding or siphoning. Is this normal? Next up is I had ABS, now the ABS light stays on and I was told that the Roadsmith conversions lose ABS. Any one else having the same issues?
    Thanks, Chuck
  2. Roadsmith banner
  3. #2
    User ID
    30407
    Oct 2019
    Lesho
    Quote Originally Posted by chuckg57 View Post
    Thanks, Chuck
    Can't help with the ABS light; I have a RS conversion and never had the light appear. With the aux tank, function is basically run the main tank down to where the low fuel light comes on. There is a toggle switch that allows pumping the contents of the aux tank to the main tank. If you pump the whole thing, it is about 4.5 gallons (roughly) and when pumping, there will be a red light adjacent to the switch that blinks. Once it stops blinking (I believe it goes solid red), use the toggle switch to stop the pump; I suppose it could burn up if you forgot. You will see appx. 3/4 tank on your gas gauge. Be patient as it is SLOW pumping.
  4. #3
    User ID
    29633
    Apr 2019
    Arlington,AZ, USA
    I know about the switch, I just do not have to turn it on. The bike runs the aux tank dry and the fuel gauge stays full.
  5. #4
    10+ Posts Bama Jack's Avatar
    User ID
    27877
    Mar 2018
    Smiths Station, AL U.S.A.
    I would have that checked out. Just converted to RoadSmith in April and my aux tank works only by the switch not gravity fed.
    I've been around several RoadSmith trikes and never seen that happen.
  6. #5
    2750+ Posts bikerbillone's Avatar
    User ID
    9350
    Sep 2012
    Lakeland, FL
    Yes, that sounds very strange, I don't know how that the fuel could feed to the main tank without the pump being on. I do know that if you forget to turn the pump off and the main tank get full, bad thing will happen.
    750+ Posts
    User ID
    4781
    May 2011
    peru,in,usa
    Default aux tank switch
    sounds like you have the switch in the down (aux) position. mine is a older '93. take the right rear tire off, and look behind the fuel tank. there is where the fuel pump and small fuel filter is.at least thats where it is on mine.
  1. Roadsmith Owners Forum: Post Your Roadsmith Pics
    By Papa Zook in forum Roadsmith Trikes
    Owners Forum
    Last Post: 12-22-2017, 10:35 AM
  2. Replies: 8
    Last Post: 08-11-2016, 03:49 PM
  3. Roadsmith Accu Ride questions
    By hisst in forum Brand Specific Discussion
    Last Post: 07-26-2012, 12:19 PM
  4. roadsmith questions
    By rodeo1 in forum Honda Trikes
    Last Post: 06-02-2011, 07:17 AM
  5. questions about champion exhaust
    By WEB in forum Harley Trike Conversions
    Last Post: 01-17-2009, 04:50 AM
Bookmarks
