Likes Likes:  6
Results 1 to 13 of 13
Thread: Over heating issue '03 GL1800
    50+ Posts
    Apr 2019
    Fort Myers, FL
    Default Over heating issue '03 GL1800
    Temp gauge climbs slowly. Normally it stays at one line below the 1/2 point but yesterday it got to one line above the 1/2 point. I stopped, bought some coolant and topped off the overflow tank. It didn’t need any but thought I’d top it off anyway. I'm sure most of it spit out from being over full. Rode 30 miles home with the heat gauge still reading high and even climbing just a tad. I let the bike sit overnight and took off the radiator cap this morning. I saw no liquid at all. I managed to get in 5 cups of distilled water before the level stayed. I then started the bike and let it idle for about two min. The fluid level dropped but, more importantly, I saw water dripping under the bike. Okay, so there is a leak somewhere and I’ll pull of the belly pan in the morning and try to track that/those down. However, the overflow tank is still at the proper level!!
    So, my question is, why would I be losing liquid level in the radiator but still maintaining the correct level in the overflow tank? The over flow hose is not blocked. I took it loose at the top and blew through it with no resistance at all. Shouldn’t the radiator be sucking fluid from the overflow tank?
    The best way to check leaks I have found is using a pressure test kit similar to this one, ALWAYS check your radiator cap first ( be careful when testing hot fluid)
    You can some times rent this equipment from Auto Zone and others
    50+ Posts
    Apr 2019
    Fort Myers, FL
    Thanks, I'll check for a pressure tester at the local auto parts place. However, my main question is why the overflow tank is not sucked dry by the radiator.
    Quote Originally Posted by controlu View Post
    A weak radiator cap can do that
    Or ... Could be a plugged/pinched line between the overflow and the radiator AND a leak in the main system ... the plug/pinched line would not rear it's ugly head until the main system started to leak
    Apr 2010
    Shenandoah Valley of Virginia
    Likewise, a hole in the cooling system that lets coolant leak can also let air in during the cool down that provides the vacuum to pull coolant out of the overflow tank.
    The overflow tank isn't there to patch or cover up for coolant leaks, it's there just to save coolant pumped out by coolant heating up and the pressure cap letting excess pressure off. In the old days before coolant recovery tanks were common … you lost that little bit and anytime after first heat cycle that you opened the cap, the level was down. Now, with coolant recovery systems, coolent gets sucked back in on cool down and the level stays up.
    Nothing special. 30 plus years ago,I added a long copper tube to my overflow tube on my '77 F-150, cut a hole in a gallon AF jug near the handle to fit the tube that is long enough to reach bottom, tied the jug next to the radiator with poly rope, it recovers nicely … but there's no leaks in my truck's cooling system
    50+ Posts
    Apr 2019
    Fort Myers, FL
    Well, that 'splains it. I didn't think of a leak filling the vacuum. Duhhh. Good thinking on the Ford truck, too.
    50+ Posts
    Apr 2019
    Fort Myers, FL
    Put a pressure test on the system. Lost 1/2 lb. of pressure in eight min. and got a drip from under where the water pump was just replaced.
    Troubleshooting 101 ... always check the last thing you did ...
    Sep 2016
    Springfield, Mass. USA
    Glad you found the problem that quick......
    50+ Posts
    Apr 2019
    Fort Myers, FL
    The shop did the work. Always check the last thing THEY did.
    So, will they warranty their work?
    50+ Posts
    Apr 2019
    Fort Myers, FL
    They say they will but gave me an appointment for the rework that is three weeks down the road. I'm becoming convinced to never, EVER, buy a used Goldwing. Trying to get one repaired here in South West Florida is damn near impossible. The Honda dealers will not work on anything more than eight years old and anyone else that will work on them, well, you don't know what you're getting.
  1. Gl 1800 Over heating
    By jimmykusmc in forum Honda Trikes
    Last Post: 12-03-2014, 08:00 PM
  2. Over heating problem what to check next
    By skipg in forum Honda Trikes
    Last Post: 11-16-2013, 05:45 PM
  3. Over heating
    Last Post: 09-06-2013, 03:08 PM
  4. VW over heating
    By B-2 in forum VW Powered Trikes
    Last Post: 02-16-2012, 04:03 PM
  5. Over heating 2009 Tri-Glide
    By DONH in forum Harley Tri Glide
    Last Post: 08-18-2011, 03:13 PM
