Likes Likes:  2
Results 1 to 5 of 5
Thread: 19 Freewheeler body removal
    Sep 2019
    Russell
    Default 19 Freewheeler body removal
    Going to remove body to install DK Lift and fix exhaust that two dealers can’t seem to get right, left muffler keeps slipping rearward (Rinehart system). How do the side panels come off? How many electrical connections are there to disconnect? Tried to buy service manual from Harley website with no luck. Thanks in advance.
    Quote Originally Posted by Rakpak View Post
    https://www.triketalk.com/forum/thre...r-Body-Removal
    See post # 3 here, this is a first year Freewheeler tho yours should be the same
    The side covers just pop off, grab hold of them and pull straight out
    Here is a parts view for you
    Sep 2019
    Russell
    Default Thanks
    Thanks again, Jack.
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    You've got 8 bolts to remove. Dont be surprised that the cheapo spot welded nuts on the frame extension snap off. Use lots of blue painter's tape all along the lower body especially around the mufflers.When removing body slide back slightly and tip up to clear the seat extension- use tape here. Gotta tip the front( toward rider) up at a 70 degree angle +- in order to clear the rolled over lower bottom body panels.I suspend the body with 4 ratcheting tie downs then just pushed the trike forward to clear the lower panels. Then lowered the body onto movers dollies. Of course I'm working alone. I think next time I'm gonna buy one of those HF 1 ton shop cranes and remove it that way. Did I mention use lots of blue painter's tape?
    Sep 2019
    Russell
    Default Thanks
    Quote Originally Posted by Old Road Dog View Post
    Thanks Old Road Dog, yes I was planning on lots of painters tape, I’ve seen my handy work before lol. Those instructions will be a great help.
  1. 2008 Honda GL-1800 Lehman Monarch II - Body Removal
    By B25bsaboy in forum Lehman Trike
    Last Post: 08-21-2018, 05:08 PM
  2. body removal
    By mhgoldwing in forum Roadsmith Trikes
    Owners Forum
    Last Post: 07-14-2018, 08:17 AM
  3. Hannigan FLH Body Removal
    By 3rdwheel in forum Hannigan Trike
    Last Post: 05-08-2017, 04:16 PM
  4. Freewheeler Body Removal?
    By Red59 in forum Harley Freewheeler / Road Glide 3
    Last Post: 03-10-2016, 10:47 AM
  5. body removal
    By mikeey22 in forum General Discussion
    Last Post: 11-20-2015, 12:15 AM
