Likes Likes:  3
Thanks Thanks:  1
Results 1 to 7 of 7
Thread: Mid Engine
    100+ Posts
    Dec 2017
    Chauvin, La
    Default Mid Engine
    As I am now well into re-triking my bike and triking my wife's bike, I have also dragged out my friends VW trike for rebuilding. Searching the forums hasn't given me the answer to my problem. Building a mid engine trike and moving the engine forward either by DIY mod or adding a second tranny housing, what is needed to extend the transmission shaft to the engine? Anyone have an explanation and or pictures how it was/has been done?
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    There is an entire sticky thread at the top with a full build of a front engine.
    Many many parts can not be bought. But if you do not go to crazy with it there are a lot of buggy parts that can be used. But some items have to be custom machined.
    450+ Posts
    Mar 2018
    Fernley
    Rex is the one to chat with about this build. He did do wonders with his creation. He knows a lot about what can be done and what will not work. Plus it is always good to bounce one's idea's off another's head, so to speak...
    It is a very creative build and we do hope you the best with it. Many things discussed and done on this site..
    100+ Posts
    Dec 2017
    Chauvin, La
    Default Tranny Shaft
    I read through the Tech Tech sticky and saw it covered tranny cases, suspension, engine, and a bit of frame, but either missed the tranny shaft extension or there isn't one. I know any modification will be a DIY but looking for ideas so I don't try to reinvent the wheel. My plan is to obtain a worn tranny center shaft with the spline to place in the clutch and an used clutch disk or two to fit on the existing tranny shaft. Then I can connect the two like a mini driveshaft with a small universal joint.
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Go see the "Anyone Else" thread.
    That does have the shaft and adapter in mine.
    If you are serious about it ..... I have prints.
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Copied some of the thread pics over so you dont have to read the entire thread.
    100+ Posts
    Dec 2017
    Chauvin, La
    So you used an old tranny shaft with an old clutch disk spline hole? I do like the middle "driveshaft" support bearing too. I'm trying to find a used tranny shaft and clutch disks to fabricate the driveshaft. Started reading the Who Else thread and WOW! All I can say is WOW! Even if this was MY bike I just don't have the patience or access to equipment for that kind of meticulous work. Did I say WOW yet? Thanks. Going to keep reading that thread.
  1. Rear-engine vs. mid-engine...pro's/con's?
    By Gruuve in forum General Discussion
    Last Post: 02-08-2019, 04:10 PM
  2. mid engine trike
    By captchee in forum VW Powered Trikes
    Last Post: 04-06-2018, 05:45 PM
  3. VW Mid Engine Trike
    By Rickus Dickus in forum VW Powered Trikes
    Last Post: 01-16-2018, 07:14 PM
  4. Mid engine Trike ?c
    By KennyK in forum VW Powered Trikes
    Last Post: 04-01-2014, 07:34 PM
  5. Mid Engine Trike
    By ralco in forum General Discussion
    Last Post: 09-10-2011, 08:52 PM
