Likes Likes:  4
Results 1 to 8 of 8
Thread: HELP, how to remove rust on Brake Rotors
    60+ Posts Red sport.'s Avatar
    Sep 2019
    winfield, Al. Usa
    Default HELP, how to remove rust on Brake Rotors
    Bought a 4 Yr. old FLRT Free Wheeler front brake rotor has rust on it, was told it was garage kept But it has rust here & there like to clean it up.
    I found Rust-Oleum Rust dissolver Gel at WalMart tried a little it works But scared to spray the hold rotor. (spray it on wet surfice wait 30 min. rinse off with water hose) need suggestions what's best. PS: called Harley dealer they don't have anything.
    Thanks in advance for your help.
    Quote Originally Posted by Red sport. View Post
    The rust should after you ride and apply the brakes a few times..
    James, where is the rust? On the face of the rotors or the drilled and stamped holes
    If it is the face of the rotors , Bob is right. Ride it and apply the front brakes a few times, this should clean the faces
    Sep 2019
    winfield, Al. Usa
    That part is shiny, it in the vent holes & surface I'm trying to remove.
    That is going to be a lot of work
    If you have plenty of time keep using the Rustoleum or try, will require lots of rinsing
    Post
    Like jack said......Stick with the Rust-Oleum..... And you'll do all right....
    Yep.With the..>>....A-lot of rinsing .....I have an old jar of Naval Jelly, And i used it on an old axe head i found at an 100 plus year old farm foundation ....And if you don't rinse and brush it well it will leave a white slag on iron...I had to use a wire brush to remove the slag...
    Something you might not want to do on a rotor..And don't let it get on paint, Chrome or Aluminum or stainless steel......
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    Metallic/ semi metallic brake pads can enbed particles into the rotor. This is what you see rusting. Hell I have a new Toyota Corolla and the rotors rust just by sitting a few days. Run the trike hit the brakes no more rust. Until it sits a few days. When it comes time to change the pads there are plenty of options out there.
    I'm gonna address the Elephant in the room ...
    If and when you get the rust removed, you will need to protect the bare metal ... or like all bare metal it will rust again. To do it right, you probably need to get the rust off, remove the rotors, cover the brake surfaces (tape them off) then paint the bare metal. Will that guarantee no more rust??? Nope ... that's gonna be a function of the environment you live in and ride in. Even if you keep it in a temperature and humidity controlled garage, the rotors are gonna rust ... along with just about any non protected metal on the trike ... and that is without ever taking it out of the garage.
  1. Help Remove OEM muffler (2016 Freewheeler)
    By SGMJRamos in forum Harley Freewheeler / Road Glide 3
    Last Post: 02-20-2020, 03:19 PM
  2. Replies: 7
    Last Post: 11-24-2018, 12:24 PM
  3. Help with which panel would be easiest to remove
    By 56chevy in forum Indian Trikes
    Last Post: 10-25-2017, 04:53 AM
  4. larger ? break pedal??
    By jackf1950 in forum Harley Trike Conversions
    Last Post: 03-03-2011, 11:06 PM
  5. break down
    By retdpd in forum General Discussion
    Last Post: 07-07-2010, 04:58 PM
