LD-Ordie6trike ladyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6GorillaNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6rhino 2New Member Introduct...Newbie from the Mojave Desert
LD-Ordie6SullyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
Likes Likes:  6
Thanks Thanks:  6
Results 1 to 20 of 34
Thread: Intro #2, can you help me help a disabled vet?
    20+ Posts
    Nov 2019
    Plattsburgh NY USA
    Default Intro #2, can you help me help a disabled vet?
    Hi all!
    I'm Becky. I made an intro here in this thread and everyone was SO nice:
    https://www.triketalk.com/forum/thre...d=1#post709659
    I'm trying to find a sidecar to go on a 97 goldwing aspencaid. This is a donor motorcycle from a very sweet man in Arizona.
    Basically, a group of us in our community are banding together for a friend of ours, a disabled vet living on his payments. He's a very nice guy who helps many local vets and the aged in general. They, (he & his wife), rode a ural sidecar, but some local kids got in their garage and held the clutch in as they all ran down the street pushing it. They must have stumbled or something, because we found the bike at the bottom of a long hill with a 20 foot skidmark behind it. We think the sudden stop bent the crank.
    A mechanic friend is looking at it now, but it doesn't look good. So, we found them another bike, and now we need a suitable sidecar for the new (old) goldwing.
    Can everyone please put your feelers out for something? One of us is a mechanic familiar with big bikes, and the vet knows how to set up a sidecar, so we can probably make everything work.
    Thanks folks!
    Becky
    Meme Master
    Jan 2014
    Farmington, NH USA
    Sell off the broken ural for sidecar funding?
    It might be easier to sell the Honda to re engine the ural? Those engines should be fairly affordable?
    The Honda platform is much better reliability and durability wise however, and will run circles around the underpowered ural.
    While it won't be a direct bolt up, the ural sidecar might also be adapted to fit the Honda with some creative frame modifications, and added ballast weight to the hack. The ural driveshaft to the ural sidecar wheel would need to be disconnected.
    Good luck and if nothing else, buy better locks for his garage!
    400+ Posts Smitty901's Avatar
    Mar 2018
    Lowell, WI, US
    Quote Originally Posted by Koalabear747 View Post
    Hi all!
    Thanks folks!
    Becky
    Sidecars are not cheap nor easy to do right . You would be way ahead finding one use, proven and already done. Something like this may be the easiest, fastest and lowest cost.
    https://sidecar.com/forum/topic/band...as-ranger-slc/
    750+ Posts
    Jan 2010
    east windsor ct
    i would look into the ural 1st... if it was in a low gear it would certainly skid the tire... i dont believe anything would happen from that incident..
    what are the symptoms ?? which lead you to think the crank is bent??
    20+ Posts
    Nov 2019
    Plattsburgh NY USA
    Donny talked to Van Le about it this afternoon. Van's a friend of his from another forum, and is a Ural guru. We're pretty sure it's a bent crank, so it's parked for now while they focus on the generous gift of the old goldwing.
    20+ Posts
    Nov 2019
    Plattsburgh NY USA
    Quote Originally Posted by Smitty901 View Post
    The problem is they've already been given the goldwing, so we're all focusing on getting a sidecar for them. Because of his injuries, he can't ride a 2 wheel bike.
    Mar 2018
    Lowell, WI, US
    My point is that by the time you are done the sidecar will end up costing more than a rig ready to go. Used sidecars if found often need more work than they are worth. Mounts need to be purchased and fitted that is not cheap. A larger bike like a Goldwing generally needs a heavier sidecar so a lower cats one my not work out.
    20+ Posts
    Nov 2019
    Plattsburgh NY USA
    OH, ok. I see what you mean. He and a mechanic friend are gonna start taking it apart this weekend, but I really would love to find them something, anything that will work on the white bike.
    20+ Posts
    Nov 2019
    Plattsburgh NY USA
    This bike
    750+ Posts
    Jan 2010
    east windsor ct
    i understand wanting to use the gw but sometime the almighty dollar doesnt let us do what we want..
    but i am guessing you are looking at a minimum of $2500 for a good car
    and depending on what it is close too another 1000 for all the brackets...
    and unless this fellow has the upper body strength of hulk hogan you will NEED to put a raked tree on it so he will be able to steer it which is another 900 minimum about 4200 total
    hopefully you may do better but this is a pretty realistic guess
    probably no body has mentioned the raked trees...unfortunately you cant just mount a car and have it handle well!!
    while the ural is not the biggest power house and is not the best for long distance the front end is already setup the car is mounted
    dollar for dollar ural is the best bet...
    and i would bet dollars to doughnuts the crank is fine.. again what are the symptoms
    750+ Posts
    Jan 2010
    east windsor ct
    did some quick looking around... if u r dead set against the ural... this would be a great deal.. and a even greater deal better than the ural
    https://sidecar.com/680-2/topic/1988...car-friendship
    1988 Honda Goldwing gl1500 with attached California Sidecar Friendship III.
    Bike has 60,500 miles with raked front, trunk light, rack, passenger armrest, new front tire, etc.
    Sidecar has electric lean, brakes, seatbelt, radio, trunk light, detachable top, etc.
    $5,300.
    James at 989-343-6841
    all mounted.... raked trees... ready to go i would be looking at selling the ural and the white bike
    i would be all over this one like white on rice if i was in the market
    and it has electric lean which is nice but not a necessity... it helps compensate for the crown in the road...(the bike will tend to wander some with out it) i bet no one mentioned that either
    20+ Posts
    Nov 2019
    Plattsburgh NY USA
    Hi stace, thanks for that. I'm in the process of trying to log in over there, but it's not working. Ugh! I'm talking with Al in admin.
    They're going to fix the ural. It means a lot to him because it's from an old friend in the military, I think. And I think it would be kinda rude to sell the goldwing because it's a gift. I'll ask them about it, but they're pretty excited about their 22 year old 'new' bike.
    750+ Posts
    Jan 2010
    east windsor ct
    u dont have to log in to see what i posted..
    20+ Posts
    Nov 2019
    Plattsburgh NY USA
    I'm trying, this is what I get
    750+ Posts
    Jan 2010
    east windsor ct
    try
    sidecar.com
    classified
    complete rigs for sale
    about 4th or 5th
    1988 Goldwing gl1500 & California Sidecar Friendship III
    20+ Posts
    Nov 2019
    Plattsburgh NY USA
    Ok, I was finally able to create an account there. Had to use my bf's email because for some reason that forum doesn't work well with hotmail.
    I made a new post there
    https://sidecar.com/forum/topic/some.../#postid-80172
    Now I'll go see if that person in your link would consider breaking up the set.
    Thanks Stacey!
    750+ Posts
    Jan 2010
    east windsor ct
    Thanks Stacey!
    id ty to beat him up a little for the whole thing
    its all there ready to ride even if you get the car for 2500 which i doubt very much... you still need the tree about 900 and 1000 for the brackets and to get it mounted .... still back at 4400
    and he can get on an go
    750+ Posts
    Jan 2010
    east windsor ct
    Thanks Stacey![/QUOTE]
    sent you a pm
  19. #19
    20+ Posts
    Nov 2019
    Plattsburgh NY USA
    I never got it, bummer. I did fix my login here though, sorry I disappeared.
  20. #20
    750+ Posts
    Jan 2010
    east windsor ct
    not sure what happened
    what will you take for the ural?
    pm or sbgo1988@gmail.com
  1. Some help for a disabled vet, please?
    By Koalabear747 in forum New Member Introductions
    Last Post: 11-09-2019, 01:11 PM
  2. disabled Nam Vet
    By Doc7402 in forum Enabled Trikers
    Last Post: 11-27-2018, 07:05 AM
  3. Help for Vet w/Trike
    By Hocky in forum Harley Trike Conversions
    Last Post: 06-16-2017, 02:24 PM
  4. To you Nam Vet
    By Sully in forum Military & Veterans
    Last Post: 12-21-2015, 11:16 PM
  5. Brake modification(disabled triker)
    By trikerAL in forum General Discussion
    Last Post: 02-22-2013, 12:34 PM
