14TG2TrampasHarley Tri GlideInstallation of a new Fuel Filter &...
14TG214TGHarley Tri GlideInstallation of a new Fuel Filter &...
Likes Likes:  7
Thanks Thanks:  4
Page 2 of 2 FirstFirst 1 2
Results 21 to 26 of 26
Thread: November and still riding
  1. #21
    33500+ Posts
    David357's Avatar
    May 2015
    Hobe Sound, FL.
    Default November and still riding
    Ron and CrystalPistol, the Viper CSC conversion kit on my Wing has a 3.4 gallon auxiliary gravity fed fuel tank.
    As with any gasoline auxiliary or reserve tanks, I feel it's important to keep the auxiliary fuel supply well Stabilized. I do this assuming that I may do multiple short rides in a year and never draw down the main tank far enough to allow the gravity fed auxiliary tank to flow into the main tank. I will top off the main tank after each ride to reduce any condensation as discussed in earlier posts.
    I hope this clarifies the discussions a little better.
  2. #22
    2000+ Posts trikeman's Avatar
    Oct 2010
    Jackson Tn. Madison Co.
    Ethanol free gas is great. At 70 mph with Cruise I get 30 mpg. Yesterday I filled up with ethanol free gas. Rode 175 mile at 70 mph on cruise control and came back the same route to the same ethanol free pump and fill up. Did the math and got 34 mpg. Don’t know if the economy per $ is justified. But the efficiency is.
  3. #23
    Sep 2016
    Springfield, Mass. USA
    Quote Originally Posted by David357 View Post
    YOU ARE SMART
    ,using stabli in your fuel tank... That will eliminate any problems, that "could" occur....
    Ronnie
  4. #24
    150+ Posts
    Jun 2017
    Asheville,NC USA
    Quote Originally Posted by Dave59 View Post
    Hey Pastor Ron, I'll be interested knowing how those gloves work for you. I've looked at a number of them online but haven't ordered any yet.
    I will give details on Sat.
  5. #25
    150+ Posts
    Jun 2017
    Asheville,NC USA
    The gloves they sent had a brand name Goldfox on the top of glove, the measurement they used caused me to get medium ( I usually wear large), to which I should have gotten large, because, they were a little to small for spreading out hand enough for clutch use. With that being said, I used them for approx. 5 hours, ranging from 45-35 degrees on ride up the Blue Ridge Parkway. They worked beautifully, as advertised. The tail on the logo started blinking when it had 15 minutes left on the batteries. I used all settings the higher up the Parkway I went, staying on the high position for about 2 hours.Now, I wanted to order my wife a pair, it was late and I did not order correctly the second time, and instead of receiving the ski type gloves, I received the motorcycle gloves (large) size, WHICH WERE MUCH,MUCH, THINNER THAN THE SKI/SNOW GLOVES also, the logo name was J-JPENI NOT GOLDFOX. However, I tryed the thinner gloves inside my old bike gloves( using them as a liner) and they fit perfectly. The bottom line: these gloves heated right up and keep me toasty throughout the ride. Since they are new, I cannot comment on the longevity of the product. I pray this helps.
  6. #26
    1500+ Posts
    Oct 2012
    Batavia Ohio
    I've never understood why May seems to have 13 days in the month and January has 147. Ugh.
  1. Roadsmith Announces $500 OFF Options and Accessories Through November
    By Roadsmith Trikes in forum Roadsmith Trikes
    Owners Forum
    Last Post: 10-28-2014, 10:50 AM
  2. Breakfast and lunch outdoors in november??
    By screwball in forum Harley Trike Conversions
    Last Post: 11-14-2012, 05:21 PM
  3. November 3rd Bike and Car show Update!!!
    By hbrogan57 in forum Honda Trikes
    Last Post: 11-04-2012, 09:44 AM
  4. Still riding in Pa.
    By denviola in forum New Member Introductions
    Last Post: 05-24-2010, 09:44 PM
