Well . . . if you check it out starting and running an engine is definitely not the thing to do. If you can't get it up to operating temperature to burn off / vaporize contaminants you're better off just letting it set. That would concern me for sure. Probably lots and lots of water in the engine oil. Pull the dip stick and see if it has white goo. If it does there is heavy water contamination in the oil.
