Results 1 to 2 of 2
Thread: Help With Start issue
    20+ Posts Pappy49's Avatar
    Apr 2018
    San Marcos, Texas, USA
    Default Help With Start issue
    I'm having a problem with the starter on my '02 Classic conversion. I've been getting a click from the starter for a long time but it would eventually kick in an start. Finally died completely. The plunger and contacts in the solenoid were worn so I got a kit and replaced them. Bench tested fine before I installed it. Tied it on the switch before putting the primary chain cover and floor boards back on. No problem. Got everything back together and was going to take a short 'victory' run. Unhook my Battery Tender, turn on the ignition and hit the start button...CLICK. Getting 12V to the wire from the relay. Cleaned the ground posts/wire terminals, applied dielectric compound...still nothing. Pulled the ignition and starter relays and swapped them...no luck. I had the relays I had rep[laced and tried them with the same results. I can run a jump wire from the 12V relay wire connection to the battery cable on the starter, bypassing the relay and the starter works.
    I picked up a new relay but haven't tried it yet. Talked to the service dept. manager and he is confused too. No wiring inside the primary chain area that could have caused the problem. Side covers were off so I am going to check inside them and see if maybe a wire is grounding out but I don't think so.
    Any ideas on anything else to check? I'm running out of options other than take it to Harley.
    Don, do you have battery voltage @ the main lug on starter? Have you jumped the solenoid with ignition on? If you do not have battery voltage @ the solenoid I would be checking the starter relay
    A fully charged battery is going to be your starting point @ 12,7 volts, you should read very close to this @ the starter main lug, it should drop no more than 10.5 volts when it is cranking the engine over
  1. No Start, Can You Help
    By mgwtrike in forum Honda Trikes
    Last Post: 02-28-2020, 11:47 AM
  2. Need help ! (How can I make my trike not start in gear)
    By Gator Monroe in forum VW Powered Trikes
    Last Post: 10-24-2017, 07:36 AM
  3. FRONT Brake issue, need help
    By durango9 in forum Honda Trikes
    Last Post: 07-25-2016, 11:51 AM
  4. Help - my bike won't start
    By GYPSYGAL in forum Honda Trikes
    Last Post: 12-13-2014, 04:11 PM
  5. '85 250r carburetor issue, help!!
    By buffalo bill in forum Honda Trikes
    Last Post: 08-12-2013, 08:54 AM
