Likes Likes:  4
Results 1 to 6 of 6
Thread: Tank Trigger Shifter
    100+ Posts sonny8l3's Avatar
    Oct 2014
    Livingston (Colyell ), Louisiana, USA
    Default Tank Trigger Shifter
    Hello, I don't know if this is going to work. But it's supposed to be a picture of my trigger tank shifter. I figure some folkName:  20191204_132719.jpg
Size:  22.3 KBName:  20191204_132728.jpg
    may find it interesting. Thanks for your time.
    Quote Originally Posted by sonny8l3 View Post
    Hello, I don't know if this is going to work. But it's supposed to be a picture of my trigger tank shifter. I figure some folks may find it interesting. Thanks for your time.
    Nope.......No Picture.........
    Oct 2014
    Hello, Well adding the pictures didn't come out quite like I hoped. I'm not real sure how I got them on the post, so I'm going to leave it like it is. I was originally told that the shift had to be in a straight line with the tranny, then I saw this on a friends trike. I like it a bunch. Thanks for your time.
    450+ Posts
    Mar 2018
    Fernley
    That is a bit different from the location down on the left side by the left leg. Some move them a bit forward and on the side and others get them in the middle between the rider's legs, but I do have to admitt that fits for a much quicker shifting of gears.
    As far as I can see with mine, the shifting box is welded off to the left side a bit. Maybe 3 feet from the end of tansmission. Now if I followed it upward to the neck area, well that same angle actually pulls the shifter away from center and I see the room for the shifter box up near the tank like that. At least on my frame it would work, but my fiberglass body is not designed for such a set up. I can see it being down with no issues shifting, and I can see where one can mess it up if to much angle is added. Hope you the best on the work, oh and it does look like a piece of reebar was used for the rod from my shifting box to the rear of the transmission. If is not, well it sure looks like it, LOL.
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    What I can see of it....it does look right.
    The shifter box has to stay inline with the shaft. Dead straight inline.
    The shaft works best with no offset bends.
    The vw coupling at the gearbox does not have much give to it.
    If you use a u joint and swing the whole shaft, shift box, shifter as a unit......it will easily work. The H pattern might not be dead straight ahead.
    If you wanted the shifter to be straight you could use a self supporting shifter like a buggy super shifter and a u joint at each end.
    Oct 2014
    Hello, The fella that built this added a coupler about where my shifter was under the seat and added a rod with the elbow on the end. Both of his VW trikes have the same set up, that's where I saw them. It shifts about a 20 degree angel off of center due to the angel of the rod. I did not have a problem with the shifter under the seat. But, I like this set up a lot, not to mention, I think it looks pretty cool. I'm going to flex seal the chrome on the shaft so that it matches the trike.
  1. B&B tank shifter
    By headheaded in forum Enabled Trikers
    Last Post: 04-10-2015, 10:06 AM
  2. I pulled the trigger
    By Smilam in forum New Member Introductions
    Last Post: 10-09-2013, 01:31 AM
  3. Pulled the trigger this morning.
    By MangoMike in forum Honda Trikes
    Last Post: 05-19-2013, 08:45 PM
  4. I'm about to pull the trigger on converting my X
    By Tribe in forum Honda Trikes
    Last Post: 06-06-2011, 03:29 PM
  5. Foot clutch and tank shifter
    By Bruce in forum Harley Trike Conversions
    Last Post: 12-27-2010, 07:13 PM
