ADSavarese6Marc HNew Member Introduct...New member from FL
ADSavarese6ADSavareseNew Member Introduct...New member from FL
ADSavarese6Phu CatNew Member Introduct...New member from FL
ADSavarese6trike ladyNew Member Introduct...New member from FL
ADSavarese6Uncle FesterNew Member Introduct...New member from FL
ADSavarese6rhino 2New Member Introduct...New member from FL
Results 1 to 13 of 13
Thread: To Brake or Not to Brake?
    Feb 2011
    Wichita, KS, USA
    Default To Brake or Not to Brake?
    Need some input...
    Building a custom trike, pretty bare bones; not a VW trike either. Trying to keep it as clean as possible. So here is the question;
    Do I really need a front brake on it?
    I got dual disc brakes and wide rubber on the back. Do you think I can safely get away with not having one? Not going to be racing it or anything like that.
    Input is greatly appreciated...
    Contrinuting Member
    Apr 2009
    greenfield indiana
    Default Re: To Brake or Not to Brake?
    I would put front brakes on it.
    Another thing you may want to check your states motor vehicel laws,they may be required.
    850+ Posts rwhgme's Avatar
    Sep 2010
    Shawnee,Ks
    NO!
    Quote Originally Posted by BELCHER View Post
    Need some input...
    My daughter has a VW trike that came without a front brake. The rear braking is quite good and a front is not necessary for good safe stoppping. I still added the front brake just for the more braking power and when backing the front brake makes control somewhat better. Can you have a safe vehicle without the front brake yes, but more is better for brakes.
    Jun 2010
    Indianapolis, In.
    Check your local laws!
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    One Of The Origionals
    TOI - New England
    John Luciano's Avatar
    Mar 2008
    Conn
    That front brake has a lot of stopping power. The early choppers (see Easy Rider the movie) Didn not have them. Now that the disk is so much cleaner looking than the DRUM most use a front brake
    10000+ Posts skuuter's Avatar
    Apr 2010
    Estill Springs, Tn, USA
    YES.....Front Brakes add lots of stopping power.....more than the Rear Brakes on most Trikes because, unless it is rear-engined, there is more weight carried on the Front..."usually".....
    Feb 2011
    Wichita, KS, USA
    Thanks for the input everyone...
    I'm still on the fence. Like everything else, it will decide for itself as I go along in the build process. Never too late to add it.
    As long as the state law doesn't require it...
    Your state does not require a front brake per 8-1807. as long as it can meet the stopping requirements.
    Jun 2010
    Coram, NY USA
    I've unofficially field tested my Tri-Glides front & rear dual brakes individually and I was suprised how much more stopping power the front had over the back. Except for on snow and ice. Then I only use rear to slow down to keep steering (front too strong on those conditions and locks up). I have a 2-wheel chopper with just rear and have considered adding front many times.
    Apr 2010
    Quote Originally Posted by Bikerbozo View Post
    Yep....I did the same tests when I first got my Gold Wing Trike....would have rather had the rears go out than the front.....
    1000+ Posts Rsw's Avatar
    Sep 2011
    Little Hocking, Ohio
    I wouldn't own one without front brakes. Might just save your life. What front end are you using?
    Apr 2010
    Quote Originally Posted by Rsw View Post
    Yep...For Sure.....
  1. Brake Help PLEASE RS
    By Tripacer1 in forum Roadsmith Trikes
    Owners Forum
    Last Post: 07-07-2012, 12:27 PM
  2. Brake help, anyone
    By Red in forum Honda Trikes
    Last Post: 08-26-2011, 05:05 PM
  3. Park Brake
    By kiorana123 in forum Harley Tri Glide
    Last Post: 03-28-2011, 11:55 PM
  4. Brake pads
    By wics51 in forum VW Powered Trikes
    Last Post: 03-05-2011, 04:48 AM
