Likes Likes:  1
Results 1 to 11 of 11
Thread: 60 MPH drone
    10+ Posts STAUSH's Avatar
    Aug 2018
    LAS VEGAS
    Default 60 MPH drone
    Has anyone figured out where the dreaded droning sound is coming from on the freewheeler? Or what could be causing it? At 60 MPH it is driving me nuts.
    150+ Posts GTK's Avatar
    Oct 2018
    Hobe Sound,FL
    Might be good to tell us what year. My
    2019 does not do it.
    Aug 2018
    LAS VEGAS
    Default Drone
    Sorry about that, still early. I'm on a 2019 FW. On my 2016 FW I had the same 60 MPH drone. On cruise control at 60 ( 58 to 62) it has this cycling up and down droning sound.
    300+ Posts
    Mar 2018
    Waelder, Texas
    It's cause your exhaust is mounted vertically. I'm sorry, I couldn't help myself. Seriously, what slip ons are you using? Are you using the same after-market mufflers on the 2019?
    Aug 2018
    LAS VEGAS
    Default Drone
    Bike is bone stock, except for the 14" apes and clip on fairing. Will take off fairing later, could be kicking sound back at me.??
    300+ Posts
    Mar 2018
    Waelder, Texas
    Yeah, maybe that's it. Did you have the fairing on the 2016 also? I've never had one but I reckon it could change or amplify certain sounds. Good luck with your quest.
    Quote Originally Posted by STAUSH View Post
    Any chance little belt dressing might stop the droning..?...Orange's to Kiwi's, But sometimes the belt on my Slingshot will make a ringing sound ...I cured it with a little Dietetic grease on the rear pulley...Just a dab will cure it.......
    Aug 2018
    LAS VEGAS
    Default Drone
    Thanks rhino 2. i'll see about picking some up. willing to try anything. And yes I had the fairing on the 16 also. I'll also try a different gear to change the rpm at 60 and see if that changes anything. Guess I'll go for a ride this afternoon. Well I took it out, not the speed but the engine RPM. 2500 to around 2700 sets up the drone, not matter if in 4th., 5th., or 6th. Might be the fairing, will find out when it warms up. Thanks for the input.
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    Isn't it under warranty. I can tell you that my 2017 doesn't do that, but I know that doesn't help.
    You could be onto something with the fairing. Please keep us informed as I have never heard of this before.
    4250+ Posts
    LadyonaMission's Avatar
    Feb 2015
    San Antonio
    My 2015 Freewheeler purrs at 60, really loves 75. The Vance & Hines slip-ons, dual header, muffler extension, tuner and air cleaner kit really made a difference.
    Apr 2010
    Shenandoah Valley of Virginia
    I used to have a real problem with droning. Changed turn down exhaust to straight pencil tips, that change killed my drone issue.
  1. Drone Fishing
    By David357 in forum General Discussion
    Last Post: 05-02-2016, 08:32 PM
  2. Quad copters (drone)
    By John Luciano in forum General Discussion
    Last Post: 03-20-2016, 04:47 AM
  3. X-47B Drone
    By David357 in forum Military & Veterans
    Last Post: 02-21-2016, 06:49 AM
  4. Drone Display-Synchronized Airshow
    Last Post: 02-20-2016, 08:27 PM
  5. VTX 1800C engine drone on decelleration
    By HonkytonkVTX in forum Honda Trikes
    Last Post: 10-01-2012, 12:23 AM
