SSpoon11hogmemberisoldNew Member Introduct...Hello from VA
SSpoon11ol' schoolNew Member Introduct...Hello from VA
SSpoon11Marc HNew Member Introduct...Hello from VA
SSpoon11ZammyNew Member Introduct...Hello from VA
SSpoon11Uncle FesterNew Member Introduct...Hello from VA
SSpoon11rhino 2New Member Introduct...Hello from VA
SSpoon11trike ladyNew Member Introduct...Hello from VA
SSpoon11SullyNew Member Introduct...Hello from VA
SSpoon11Jack KlarichNew Member Introduct...Hello from VA
SSpoon11GorillaNew Member Introduct...Hello from VA
SSpoon11SSpoonNew Member Introduct...Hello from VA
Likes Likes:  1
Results 1 to 5 of 5
Thread: Indian Chieftain - Is it the battery, or other electrical?
    Jan 2020
    Red Lion
    Default Indian Chieftain - Is it the battery, or other electrical?
    I had gotten sick and hospitalized with some surgery. I was not allowed to ride for 6-8 weeks and realized I never plugged in my trickle charge. When I discovered this and plugged in everything seems dead. I can't even use my fob to unlock the trunk. Won't pick up any charging on the trickle charge either. Any help would be appreciated.
    Welcome to Trike Talk
    Always check the battery first. A fully charged battery should read at least 12.5-12.7 volts
    After charging, let battery sit for 1 hour. Connect a volt meter on the battery. As you turn engine over the volts should not drop below 10.5. You can also do a voltage drop test by turning on the head lights then record the voltage. If the volts drop below 10.5 and continue to drop, the battery has seen better days
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    I have found that some chargers will not start a charge cycle if the battery it is connected to is completely discharged. You may have to hook a conventional non trickle charger to it set at 2 amps and let it slow charge.
    Quote Originally Posted by Rgrove8996 View Post
    Rodney ; Welcome to Trike Talk-,,,.....Your battery is so low voltage wise that a trickle in most cases cant charge it....You will need a regular charger to get some voltage in the battery then your trickle charger will finish the charge....Don't leave the regular charger on too long......Just enough to get the trickle to working......
    Rodney welcome aboard
    +4 on kick starting the battery
  1. SEE THROUGH BRAZ for the Indian® Chieftain® Front Fender
    By SEE THROUGH BRAZ in forum Indian Trikes
    Last Post: 02-23-2017, 09:26 PM
  2. How to change rear tire on new Indian Chieftain Trike??
    By 2ndchance in forum General Discussion
    Last Post: 09-02-2015, 06:46 PM
  3. 2015 Indian Chieftain Hannigan
    By Chazzman in forum Honda Trikes
    Last Post: 08-23-2015, 02:38 PM
