Speed Bleeders
Likes Likes:  14
Thanks Thanks:  1
Results 1 to 13 of 13
Thread: Photos of brake light bar on freewheeler
    70+ Posts Ronbo's Avatar
    May 2017
    richardson tx
    Default Photos of brake light bar on freewheeler
    i installed the luggage rack brake light from Custom Dynamics on my 17 Freewheeler and thought others might find this helpful. The installation was straight forward and professional looking but you need to read the instructions carefully. No drilling is required. You do have to insert two wires into the connector they provide (get it right the first time), and then it’s just plug and play. You only have to remove your seat. Also be sure you run the wire BEHIND the trunk lining or you won't be able to remove the liner later without disconnecting the wire.
    I chose the smoked lens to match my new tail lights. You really don’t even see the smoked lens light bar until you turn the lights on.
    The luggage rack sets pretty low on a Freewheeler so the visibility is most effective from about 10 ft or more back (assuming the average height of a driver in a car). I chose Custom Dynamics because their LEDs are angled up more than some others making it more visible to drivers behind you.
    The brightness in the photos is subjective due to surrounding light level, camera exposure and angle taken, but you can compare it brightness of the brake light to the tail lights. The photos show both running light level and brake light level. Keep in mind that my tail lights are HD LED lights which are brighter than the stock lights on a Freewheeler. The photos have been cropped but they were all taken from about the same 10 foot distance.
    I feel it was a good investment for $70. Might even put a flasher on it as I do a lot of evening and night rides around the lakes.
    Ron
    CLOSE UP OF BRAKE BAR IN RUN POSITION
    Name:  freewheeler brake light CLOSE.jpg
    BRAKE BAR DISTANCE BRAKE ON POSITION
    Name:  FREEWHEELER BRAKE OFF FAR SM.jpg
    BRAKE BAR BRAKE VS RUN DAYTIME
    Name:  freewheeler brake off SM.jpg
    Name:  freewheeler brake on SM.jpg
    BRAKE BAR BRAKE VS RUN NIGHTTIME
    Name:  freewheeler brake off dark sm.jpg
    Name:  freewheeler brake on dark SM.jpg
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    Thanks for the installation tips. It looks great. I have been waffling on how to do this mod, either like you did or replacing the reflector below the trunk lock.
    As far as flashing, I installed the Custom Dynamics Brake Light Modulator & am very happy with it. It's a very quick & easy install & gives you 10 different flash modes to choose from.
    May 2017
    richardson tx
    Quote Originally Posted by MDO View Post
    Thanks, think I going to do the flasher. If you have a luggage rack this will be much easier than replacing the reflector with lights. Also keep in mind the lower you go the less effective the lighting will be.
    Ride safe bro....
    100+ Posts
    May 2019
    England
    Hi
    looks great. Thanks for showing.
    90+ Posts Saammi's Avatar
    Jun 2018
    CT, USA
    Cool. Can you post a pic of the exposed wiring on the top of the trunk? Thx
    “Knowledge is knowing that a tomato is a fruit, wisdom is not putting it in a fruit salad.” ...Gene Takovic
  6. #6
    40+ Posts
    Jul 2019
    kansas city,mo USA
    Looks cool, what seat is that? Looking for one with wider passenger seat.
  7. #7
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by copbiker View Post
    John, any of the touring line seats fit the Freewheelers
    I have a Roadking seat on mine
  8. #8
    May 2017
    richardson tx
    That's the Harley Sundowner seat. I chose it because of the wider back seat and works with the rider back rest. It also has a nice deep pocket. I take 3 to 6 hours rides with no fatigue, but I'm 6 foot and use my highway pegs about 90% of the time.
  9. #9
    Oct 2017
    St. Louis, MO USA
    Quote Originally Posted by Ronbo View Post
    I got the HD Tallboy Sundowner & love it also! I actually got a good deal on it. 1 of my local dealers had a deal if you spend $300 you got a turn in 1 of those money machines for 30 second a & I grabbed $120.
    Coming back from Durango, CO last year I did a 650 mile day on that seat & it was great!
  10. #10
    Oct 2017
    St. Louis, MO USA
    Quote Originally Posted by Saammi View Post
    There is a video on wiring the light. The wiring runs through the luggage rack. The bolt on the back left side is hollow & the wiring routs through it.
  11. #11
    5+ Posts
    Jan 2019
    Rutland, Mass, USA
    Default Plug and play
    Ron
    Thanks for the info. I am not sure where the plug and play plugs in under the seat. Can you advise me? Thanks Phil
  12. #12
    5+ Posts
    Jan 2019
    Rutland, Mass, USA
    Hi Ron,
    could you advise me as to where I connect the plug and play harness under the seat?
    I have a 2015 but I think it should be the same as your bike.
    thanks Phil.
  13. #13
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by Freewheeler Phil View Post
    Hi Ron,
    thanks Phil.
    Phil, have a look here you will find the plug @ #9 of the instructions
    https://www.customdynamics.com/amfil.../product/2955/
  1. Brake/Running light for Freewheeler Trunk Rack
    By 52edub in forum Harley Freewheeler / Road Glide 3
    Last Post: 01-07-2019, 07:56 AM
  2. Photos of Freewheeler with some mods.
    By Trike4u in forum Harley Freewheeler / Road Glide 3
    Last Post: 08-17-2016, 05:44 PM
  3. Replies: 3
    Last Post: 03-01-2015, 12:16 AM
  4. Freewheeler Third Brake Light
    By Springman2007 in forum Harley Freewheeler / Road Glide 3
    Last Post: 11-25-2014, 06:13 AM
  5. auxillary brake light.,turn signal running light conversion
    By fogrider in forum Harley Trike Conversions
    Last Post: 08-25-2013, 09:24 AM
Tags for this Thread
