14TG114TGHarley Tri GlideInstallation of a new Fuel Filter &...
BigN693GorillaEnabled TrikersFull length floorboards
Likes Likes:  10
Thanks Thanks:  4
Results 1 to 13 of 13
Thread: Gear Oil Transmission
    1000+ Posts
    nucseal's Avatar
    Jan 2012
    San Antonio, Texas
    Default Gear Oil Transmission
    Tried to search this up, with no luck. How many of you are using Gear Oil in their transmission. Thinking of using Amsoil 75-140W in my transmission vice original 20-50W Oil. Any Pros or Cons to doing this?
    Thanks for the info
    Gear oil always
    I have tried pretty much all of them except Amzoil
    I like Redline
    The plus side is gear oil cushions the gears and bearings better, it has higher shear strength than engine oil
    50+ Posts ole_phart's Avatar
    Oct 2019
    Smithfield, VA, USA
    Quote Originally Posted by nucseal View Post
    Thanks for the info
    I put HD's 80/140 synthetic in my Freewheeler at the 1k service about a month ago. Did the same thing with my Low Rider when I had it. HD came out with it maybe a year ago. On both the bike and trike it made shifting smoother and neutral easier to find.
    FWIW I use Syn 3 in the motor and Formula+ in the primary. I just stuck with HD lube cuz it's easy to get. I'm fairly sure you'd have the same results with Amsoil.
    CWO3 U.S. Army Retired
    Vietnam '69-'70, Grenada '83
    82nd, 101st, 160th SOAR
    ’01 XL1200C, ‘01 FXSTD, ‘02 FLHR, ‘03 FXDL (wife’s), '18 FXLR all sold
    2019 FLRT Freewheeler Bonneville Salt Pearl
    1000+ Posts
    nucseal's Avatar
    Jan 2012
    San Antonio, Texas
    Gear oil always
    I like Redline
    Quote Originally Posted by ole_phart View Post
    Are you also using the gear oil in your Primary?
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Thanks for the info
    Amsoil Severe Gear SAE 75W140
    Amsoil MVPQT-EA Synthetic V-Twin Primary Fluid
    Used that gear oil in my 03 for over 100,000 miles .Will be in the 20 after break in's.
    Pat, you can now run the new H D gear oil in the tranny and primary
    https://www.harley-davidson.com/stor...hetic-gear-oil
    Oct 2019
    Smithfield, VA, USA
    No, I stayed with Formula+ in the primary. Don't ask me why. As Jack said per HD you can use the HD synthetic gear oil in both.
    200+ Posts Wmitz's Avatar
    Jun 2018
    Crossville, TN, USA
    Running the Amsoil 80/140 in mine now. Did it at the 1k service. Using the hd primary fluid in the primary. I think the new hd oil is going to be to heavy for the primary, service manager thought so also. Time will tell... I have run a lot of different gear oils in the trans over the years, some better than others. This is the second bike for the Amsoil, different bikes like different oils, don’t ask me why, lol. I had a 12 RGU that worked better with Bell-Ray than Redline Shockproof, go figure.
    100+ Posts OLBLU's Avatar
    Apr 2018
    Winnipeg
    I have found that Redline full synthetic gear oil has worked best.
    Immediately stopped the inability to find neutral.
  11. #10
    900+ Posts
    Bellville, Texas, USA
    Have been running Royal Purple 75W140 gear oil in my 2015 Freewheeler since I bought it. Have also run Redline in other bikes. Both are very good. Shifts smooth and no trouble finding neutral. I run Mobil 1 V-Twin 20W50 in the engine and primary.
    Sunman
  12. #11
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    Redline Shockproof gear oil in trans for me.
    Been running Syn3 in the primary for a few years now, like how it works. But I am going to try the new HD gear oil in the primary...see how it works for me.
    www.DKCustom.com
  13. #12
    100+ Posts rcappie's Avatar
    Oct 2019
    La Porte
    Will changing to a different brand oils
    do anything to the warranty?
  14. #13
    Quote Originally Posted by rcappie View Post
    As long as it meets Harleys Specks... Your good to go not a problem...
  1. Transmission gear noises
    By Tricycleman in forum Honda Trikes
    Last Post: 09-26-2017, 04:56 PM
  2. Transmission Oil Lever
    By jimdog1356 in forum Harley Tri Glide
    Last Post: 10-17-2016, 12:23 PM
  3. Transmission oil
    By Lakeman in forum Harley Trike Conversions
    Last Post: 08-31-2012, 05:56 PM
  4. Transmission/Primary Chaincase oil
    Last Post: 06-21-2012, 07:49 PM
  5. Oil-Oil-Oil
    By drumdoctor in forum VW Powered Trikes
    Last Post: 01-08-2012, 12:16 PM
