AriNV3Jack KlarichRider Safety Discuss...Maybe silly but serious question, s...
AriNV3AriNVRider Safety Discuss...Maybe silly but serious question, s...
AriNV3cycle7447Rider Safety Discuss...Maybe silly but serious question, s...
Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Likes Likes:  9
Thanks Thanks:  2
Page 2 of 2 FirstFirst 1 2
Results 21 to 31 of 31
Thread: Rear Brakes on my 2020 Tri Glide
  1. #21
    100+ Posts PTR's Avatar
    Oct 2019
    DeBary , fl , usa
    I received the set of FA631HH pads today. They look right. I hope to be rear dut free by the weekend.
  2. #22
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    1
    Quote Originally Posted by PTR View Post
    Great. Looking forward to the outcome.
  3. #23
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Hope they work. Showed up on Amazon,but when I looked up "fit" says will not fit my 2020 Tri
  4. #24
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    1
    Ditto, and I checked several sites including EBC. Very interested to know if these work for you Peter.
  5. #25
    Oct 2019
    DeBary , fl , usa
    Quote Originally Posted by ultrafxr View Post
    I will be putting them on this weekend. I will let everyone know. They look the same.
  7. #26
    Oct 2019
    DeBary , fl , usa
    I installed the rear brakes this morning. They fit just like the OEM and I can't see any difference in them except the pad material. I will see about the dust over time.
    Install notes:
    THIS IS FOR REPLACEMENT OF NEW LOW MILEAGE PADS. IF YOU HAVE A LOT OF PAD WEAR YOU WILL HAVE TO PUSH THE CALIPER PISTON IN WHILE TURN IT COUNTERCLOCKWISE TO RESET PISTON FOR E-BRAKE.
    1 - Chalk front wheel and loosen lug nuts with park brake on.
    2 - Jack up rear from jacking point USE A SAFETY STAND, and remove wheel. DO NOT LEAVE E-BRAKE ON OR APPLY FRONT BRAKES UNTIL COMPLETE REAR BRAKE JOB IS OVER
    3 - Remove the pad pin holding clip and loosen bolt with a T-30 before removing caliper.
    4 - Remove the two bolts holding caliper bracket to axle starting with the top one. they use a 9/16th socket.
    5 - Remove loosened pad bolt from step 3
    6 - Remove outer pad then inner pad. During all this process do not pull on parking brake arm on the back of caliper. This will push the caliper piston out and cause unnecessary work.
    7 - Take vibration plates off of old pads and install on new pads. This will stop vibration and noise.
    8 - Install pad retaining pin and finger tighten with T30 until it stops then install retaining clip.
    9 - Install caliper back on axle. Start with lower bolt first then upper bolt. Tighten ALL loosened or removed bolts to OEM torque spec for you bike. Do not forget to tighten the pad retaining pin.
    10 - Clean off brake dust from rear caliper and wheel. Install wheel and torque to OEM spec.
    11 - Complete the other side, Pump rear brake pedal, TEST BRAKES AT LOW SPEED. If pad manufacturer has a pad break in procedure follow it.
    12 - GO RIDING. BE SAFE
  8. #27
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    1
    That's great news Peter . . . and a great write up. Thanks. Looking forward to your report on how they perform and most importantly the issue of brake dust. I've only got about 250 miles on my new 2020 and now that I'm getting better from my knee replacement surgery I plan to put on my ProAction 14" shocks and install a set of RJS wheel discs - https://rjsoriginals.com/FREEWHEELER...el%20Discs.htm - that should help keep brake dust off the wheels. May want to go with the pads also.
  9. #28
    Oct 2019
    DeBary , fl , usa
    I had 72 miles on mine when I changed them. I don't know how the RJS wheel discs would look on the CVO TG with the open area between spokes.
    I just looked and the RJS wheel discs will only fit the standard 15" wheel. I have 17" on the CVO stock.
  10. #29
    Oct 2019
    DeBary , fl , usa
    I put 120 miles on the EBC brakes and not a hint of dust so far. wheels are as clean as when i cleaned them after the install.
  11. #30
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Have had those wheel discs ever since the 16 was new.. They keep the outside looking very clean. Take the wheel off & the dust on the inside will scare ya to death. I put EBS shoes on shortly after Tri had a couple thousand on it. Not a whole lot better. Just fair. Had to power wash the dust off . Now that Lyndall has started making pads for a trike. I will go back to them. Had them on 2 wheelers years ago. Best pad ever in rain & min. dust the "Gold" series. Someone told me 19's were listed on Lyndall site so maybe 20 will be there.
  12. #31
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    1
    I've been waiting until my new knee is better to install the ProAction 14" trike shocks and comfort lift kit that I took off my 2018. At that time I will install the RJS discs. I could do it now but first I'm wanting to get the TG over to Hog Skins to have that PPF installed.
  1. Tri Glide Brake System 2019 & 2020
    By Koolbreeze in forum Harley Tri Glide
    Last Post: 03-07-2024, 10:07 PM
  2. Rear Brakes on Tri-Glide
    By OlBandit in forum Harley Tri Glide
    Last Post: 08-01-2021, 12:12 PM
  3. Looking for a 2020 Tri-Glide
    By ultrafxr in forum Harley Tri Glide
    Last Post: 02-14-2020, 10:39 AM
  4. Fobo2 tire monitors for H/D 2020 Tri Glide
    By RLBILL in forum Harley Tri Glide
    Last Post: 02-09-2020, 04:20 PM
  5. Tri Glide Rear Brakes
    By trikermutha in forum Harley Tri Glide
    Last Post: 04-05-2012, 12:58 PM
