Phu Cat3cScjhbGeneral DiscussionIs there a TV commercial
Phu Cat3trike ladyGeneral DiscussionIs there a TV commercial
Phu Cat3Phu CatGeneral DiscussionIs there a TV commercial
Likes Likes:  9
Thanks Thanks:  1
Results 1 to 20 of 20
Thread: CSC PowerTrak front Rake Kit $895.00 - What Does that Include?
    Dec 2019
    Travelers Rest, SC
    Default CSC PowerTrak front Rake Kit $895.00 - What Does that Include?
    Going to get a CSC trike kit put on my GL1800 Gold Wing this spring.
    I see in their online price/option sheet that the PowerTrak rake kit is $895.00! Wow!
    Just what does that include? Are they only replacing the triple tree to provide the required rake angle and using your existing front forks. Or, are they giving you brand new front forks/suspension as well?
    Thanks for any advice.
    2000+ Posts trikeman's Avatar
    Oct 2010
    Jackson Tn. Madison Co.
    Triple Tree Only
    Jun 2010
    Indianapolis, In.
    More than the triple trees:
    Power Trak 1800TM = Ultimate Performance
    • 4.5° with 2.1" of trail reduction
    • Triple clamps cast and machined from A204-T4 aerospace quality aluminum
    • Steering stem is completely CNC machined from gun-drilled 1045 TG&P steel
    • Upper and lower tapered roller bearings and seals, exceeding OEM quality specifications
    • You use your forks but, you should get extensions so you can level the trike.
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    Apr 2010
    Shenandoah Valley of Virginia
    Quote Originally Posted by WingMan71 View Post
    Just $895?
    I paid $800 …
    ... 16 years ago
    16 years ago, the 1500 PowerTrak included new triple trees, stem, bearings, and longer fork tubes. The 1500 EZ-Steer included new triple trees, stem, bearings, and extensions that reused OEM forks which was a plus in my mind, just let you drop them down a couple inches to regain lost height (I see that now the PowerTrak reuses OEM fork tubes with extensions too). Prices were near same then. I chose the EZ-Steer 6 degree kit (but had a choice of 4.5 or 6 degrees … but the friend's trike that I had tried had a 6 degree kit … and I loved it). Bought the trike, loved the friends, loved the trike, loved the good rides … and I hated the steering, it was just too much like work in the mountains ... the rake kit put the fun into it.
    40+ Posts Wing'n It's Avatar
    Sep 2019
    Eaton, Ohio, USA
    The OP did not list a year for his Goldwing but the rake kit for the 18 and newer models is a complete new fork assembly as the new bike don't have triple-trees.
    60+ Posts Jimer's Avatar
    Dec 2019
    Lake Havasu City
    Just a personal opinion: "its worth every penny"; get it and you wont regret it.
    Jim
    Jun 2010
    Indianapolis, In.
    Quote Originally Posted by Wing'n It View Post
    Good catch for those with the newer Wings.
    The OP's profile shows he has a 2006 Wing
    Patriot Guard
    Was a LEO
    Bob's Curmudgeon Apprentice
    consitter's Avatar
    Jun 2015
    Ashland, KY
    I would message forum owner Papa Zook about this. He most likely sells these and may be able to beat the price.
    Sponsor
    TrikeTalk Sponsor
    Trikemaker's Avatar
    Aug 2017
    Arrington, VA, USA
    Hi Guys,
    I just wanted to update the info that deputydawg had provided above.
    The Powertrak for 2001-2017 GW1800's has been improved since that picture was taken.
    They are now (since about 2012) forged 6061T6 aluminum and the angle has been changed from 4.5 deg to 6deg.
    I have attached a picture of what is included in the kit. There is some hardware included also.
    Name:  CSC Powertrak (Large).jpg
    Aug 2015
    Decatur
    Default fork spacers?
    Had my fork seals replaced on my 2008 GL1800. I have the CSC Cobra XL kit on it. The tech made a note that trees are raked and have additional spacers for more preload but don't have the extended fork caps. I have a small wobble around 64mph up to about 71mph. I am nor sure what he means about extended fork caps? These in addition to the spacers?
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Quote Originally Posted by keithi View Post
    Had my fork seals replaced on my 2008 GL1800. I have the CSC Cobra XL kit on it. The tech made a note that trees are raked and have additional spacers for more preload but don't have the extended fork caps. I have a small wobble around 64mph up to about 71mph. I am not sure what he means about extended fork caps? These in addition to the spacers?
    Yes the fork extension caps are in addition to any internal preload spacers and most but not all rake kits come (CSC does) with the extended fork caps that replace the stock caps. Not using them, but using internal spacers instead, is sort of a cheap way to maintain ride height. The wobble is more likely to be caused from the steering stem not being sufficiently torqued. It needs to be set at 35-40 ft lbs.
    Aug 2015
    Decatur
    Ok they retorqued the steering stem bearings too, but I don't know what they set them to. I was thinking it was 30 but its been a few years since I have done one. Should I get the extended caps ? Haven't had any ride height issues other then speed bumps, lol.
    Aug 2015
    Decatur
    Checked rear tires today and had some pretty good wear on the inside treads, even some steel belt showing. Put some new tires on and now smooth as silk.
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Thats good news Keith. What tire pressure are you running?
    Aug 2015
    Decatur
    I have been running 24 to 26 lbs. The outside treads looked like they were still good. I have 30 lbs. in the new ones. I wonder why they didn't wear even across the treads? Is there an adjustment for the rear tires to put them both square to the road? Maybe more preload on the rear shocks? Been running the rear preload at 24 when 2 up or towing the trailer.
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Most run about 22 - 24lbs in the rear tires with good tire life, even wear and a great ride.
    Aug 2015
    Decatur
    Thanks!
    10+ Posts WhiteSpirit's Avatar
    Apr 2021
    Fuquay Varina, NC, USA
    Default CSC trike PowerTrac
    I just contacted CSC in Virginia. I found out the trike I just bought does not have the PowerTrac steering option on it. The part is $895.00 and $200.00 to install if CSC does it. Will, the man from CSC said that Powersports dealerships know how to install but I’m not sure I’m comfortable with that. Has anyone else installed the PowerTrac system by anyone other than CSC?
  19. #19
    Aug 2015
    Decatur
    Default Self install rake kit
    I have installed two raked triple trees on my own motorcycles. A 1999 Valkyrie and a 2004 Road Star. The Wings have a few more pieces to get out of the way but the job itself is pretty straight forward. I did each one in about 5 hours accounting for beverage breaks and taking a few photos. Pay attention to disassembly and follow proper torque procedures. I have never had an issue and I know exactly what was done and how it was done.
  20. #20
    90+ Posts Sandman1's Avatar
    Jan 2021
    Palm Harbor, Florida, USA
    Default CSC Power Track
    Any trike dealers that have a CSC certified trained installer is good to go with your install. But you are not that far away (186 miles give or take based off your avitar location) from the CSC facility in Arrington, VA just schedule a install date. But they were pretty busy as I had to about a 90 day wait on my install of their trike kit last week of April. JMHO
  1. Help us name the NEW Powertrak for the ENCORE!
    By California Sidecar in forum California Sidecar Trikes
    Owners Forum
    Last Post: 01-05-2020, 04:14 PM
  2. Rake, rake, rake
    By Ol' Man Jeb in forum Honda Trikes
    Last Post: 05-04-2017, 01:49 PM
  3. Does he need a rake kit????
    By Firea100 in forum General Discussion
    Last Post: 10-28-2014, 08:34 AM
  4. Rake it! Rake it! Rake it!!!!!
    By Okie in forum Honda Trikes
    Last Post: 06-07-2014, 12:18 PM
  5. 50 States which does include Alaska and Hawaii
    By Urlawyer in forum Trike Travel
    Last Post: 02-09-2014, 07:23 PM
