Likes Likes:  1
Results 1 to 6 of 6
Thread: Suggestions for more clearance for oil change on Roadsmith Gold Wing
    User ID
    30361
    Sep 2019
    Daytona Beach, FL
    Default Suggestions for more clearance for oil change on Roadsmith Gold Wing
    I just don't have enough ground clearance to get under the trike for maintenance. Can get rear wheels up on a 4x4 ramp but front wheel still too low. Any ideas would be helpful.
  2. Roadsmith banner
  3. #2
    User ID
    28011
    Apr 2018
    Deatsville
    Default oil change
    I put the rear on ramps and have a small aluminum floor jack(harbor Freight) that I set a small board on the lift pad and pick up with jack under engine. Put a block under front wheel and remove jack.
    Jackie
  4. #3
    1500+ Posts
    User ID
    23660
    Sep 2016
    Springfield, Mass. USA
    I had a 10ft 2X10 board.....
    I cut six (6) one foot sections (12") and glued two boards together on top of each other (so now I have three (3) sections that are 4inches high and use a jack and lift the rear up and then place the boards under each rear wheel.................... and then jack up the front and place the third section under the front wheel...So now my bike sits evenly, and it's now four (4in) higher...............and an oil pan fits under your trike, w/o a problem... and this gives you four more inches of extra space to work under your bike, to change the oil and filter................easy peasy!
  5. #4
    1500+ Posts
    User ID
    23660
    Sep 2016
    I had a 10foot 2X10 board............ I cut six (6) 12 inch sections ....I then place the boards that I cut and glued two of them together (so now I have three 12 inch sections that are now four inches high.. I jack up the rear of the trike and place the two sections under each rear tire..... Then jack up the front and place the last section under the front wheel ..Your trike is now four inches higher, which now give you more then enough room to work under your trike, and be able to place a oil pan under it..
    Easy peesy!
  6. #5
    950+ Posts CrystalPistol's Avatar
    User ID
    2734
    Apr 2010
    Shenandoah Valley of Virginia
    Quote Originally Posted by jfred View Post
    Jackie
    I do this usually. I start the trike in neutral, pull the reverse lever, and stand beside the trike on it's right operating the start button to back it empty up onto the ramps, helping it with pressure against the right fender with my left leg ... shut down, reverse off, trike in 1st now so no rolling … then I jack the front with the wood block under front of motor, set block, etc.
    Other times, I jack the rear and set the tires on my wood ramps, then when secure, jack the front, etc.
    Easy peesy!
    Real 2" thick sawmill 2x10s … or … Lowe's milled 1-1/2x9-1/4s ?
    Just curious.
    Simple design, would support a tank too I think.
    They'd be lighter and cheaper to build if just framed around the edges with 2x2 or 2x4 stud material … but then adding a 12" piece of 2x2 across each end on one side only of what you have already would give safe fixed wheel chocks at 4" lift if placed one way, or 6" height if placed the other way, assuming use of 2" stock. I like the idea. Gonna go look at my supplies.
    I have a pair of Rhino ramps (light & secure on hard floor or very dry hard earth) … and a pair of solid wood ramps cut from a old 5x7 beam, but they are heavy for size (old red oak I think) ... but work great even under my truck in the yard.
    And I see that "Edit" is back up!
    1500+ Posts
    User ID
    23660
    Sep 2016
    I do this usually. I start the trike in neutral, pull the reverse lever, and stand beside the trike on it's right operating the start button to back it empty up onto the ramps, helping it with pressure against the right fender with my left leg ... shut down, reverse off, trike in 1st now so no rolling then I jack the front with the wood block under front of motor, set block, etc.
    Real 2" thick sawmill 2x10s or Lowe's milled 1-1/2x9-1/4s ?
    Just curious.
    They'd be lighter and cheaper to build if just framed around the edges with 2x2 or 2x4 stud material but then adding a 12" piece of 2x2 across each end on one side only of what you have already would give safe fixed wheel chocks at 4" lift if placed one way, or 6" height if placed the other way, assuming use of 2" stock. I like the idea. Gonna go look at my supplies.
    I have a pair of Rhino ramps (light & secure on hard floor or very dry hard earth) and a pair of solid wood ramps cut from a old 5x7 beam, but they are heavy for size (old red oak I think) ... but work great even under my truck in the yard.
    O no, a lowes regular 2X10... your correct, I haven't seen a real 2X4 or 2X10 in years
  1. Roadsmith Releases Striking New Gold Wing Trike
    By Trike Talk News in forum Industry & Sponsor News
    Last Post: 11-06-2017, 06:21 PM
  2. Oil Change using a Flo and Go Vacuum Oil Change Kit
    By daf62757 in forum Harley Tri Glide
    Last Post: 03-17-2017, 06:14 PM
  3. More exhaust ground clearance
    By FLTR2008TRIKE in forum Harley Trike Conversions
    Last Post: 09-01-2014, 02:18 PM
  4. Suggestions for a front tire for Gold wing SE1500 ?
    By Texas Jac in forum Tires, Wheels, Brakes, Front End
    Last Post: 10-17-2011, 07:49 PM
  5. oil change clearance
    By clsimmonsjr in forum Honda Trikes
    Last Post: 08-26-2011, 08:04 AM
Bookmarks
