SSpoon4SullyNew Member Introduct...Hello from VA
SSpoon4Jack KlarichNew Member Introduct...Hello from VA
SSpoon4GorillaNew Member Introduct...Hello from VA
SSpoon4SSpoonNew Member Introduct...Hello from VA
Results 1 to 6 of 6
Thread: 2011 trunk is locked on tri glide
    Feb 2020
    Kodiak AK USA
    Arrow 2011 trunk is locked on tri glide
    So about a year ago I closed the truck and could not get it to open again. It seems the key is turned in the right direction but the button does not release the latches. I tried a couple asking a couple dealers about the problem. They claimed they had not heard of such a problem. One dealer in Kenai, Alaska spent over 20 minutes going through every service notice. He found nothing on this problem. They are a great shop to deal with.
    In any event the locked truck has not been more than a PITA until now. But it time to plan my summer ride. I need to open the trunk. I remember very well how the latch mechanisms are released by a cable to the lock. My only thought is to drill a couple of small holes and see if I can release the latches inside the trunk. I hate to drill the holes but I'm really frustrated and need to be sure this is not going to happen on a road trip.
    Any idea has to be worth checking out.
    John
    150+ Posts
    Jan 2020
    Tacoma,WA,USA
    Quote Originally Posted by TOYtriker View Post
    John
    John,
    Just a suggestion.
    Try using some silicon spray all around then edges of the trunk lock and inside the lock itself. I don't normally like putting lubricants down locks as they tend to attract grime.
    Have yourself a break (pour a favorite drink, soda or coffee) or leave overnight.
    With gentle pressure applied with one flat hand on the trunk itself try and use the key to see if you can either open the trunk this way or turn the key.
    I would also call a local locksmith (if you have one available) and ask if they could help.
    You could also try this linky:
    https://www.hdforums.com/forum/tri-g...mechanism.html
    Best of luck.
    Jon.
    John
    XXXX..
    John
    John, Welcome to Trike-Talk..........There isn't a cable ....Its a spade that a small plate drops on the spade and locks in a groove on the spade..
    There are quite a few post's on that lock refusing to open.....
    4750+ Posts
    Mar 2015
    Texas
    I wonder if you could remove all that fancy stuff and replace the lock with one like this...
    On Amazon
    Or this...
    On Amazon
    American Legion Rider
    150+ Posts
    Jan 2020
    Tacoma,WA,USA
    On Amazon
    Or this...
    On Amazon
    Great information so I will take a peek when I get the trike.
  1. 2016 HD Tri Glide Forks LOCKED and would not UNLOCK!!!
    By Rooster57 in forum Harley Tri Glide
    Last Post: 03-06-2018, 05:22 PM
  2. Replies: 5
    Last Post: 09-29-2017, 06:16 PM
  3. Motor trike rear end locked up on interstate!
    By Chappy KC in forum General Discussion
    Last Post: 07-15-2015, 09:54 PM
  4. CSC Viper Trunk locked
    By MMH in forum General Discussion
    Last Post: 07-24-2014, 06:02 PM
  5. Locked Out of Lower Trunk
    By Calman in forum Honda Trikes
    Last Post: 08-16-2013, 08:09 AM
