Likes Likes:  1
Thanks Thanks:  1
Results 1 to 4 of 4
Thread: Fuel pump breaker switch
    30+ Posts
    Oct 2015
    Tucson
    Default Fuel pump breaker switch
    My 2013 Stallion will not start. Have checked every fuse in the beast, but do not know if there is a fuse on the fuel pump system. I have pushed the little reg button under the seat, but no change. If you push on the red button under the seat, should you be able to feel a switch or something changing. I push mine, follow all of the directions but nothing happens. I would think you would hear or feel a change when you push on the red button.
    Does anyone know where they can get a new red topped switch?
    Stallion Number 913.
    Thanks for any help,
    450+ Posts rocket1lf's Avatar
    Dec 2013
    Hot Arizona, USA
    If the button is popped out, you will feel it click when you push it down. Rick
    Stallion #378
    Suzuki Burgman 650
    30+ Posts
    Oct 2015
    Tucson
    Default the red button
    Quote Originally Posted by rocket1lf View Post
    Thanks for the option, my problem is when I push the button down nothing seems to happen, no click or change under the rubber button. Pushing it down and feeling around, finds nothing like a switch or button,
    Dec 2013
    Hot Arizona, USA
    Quote Originally Posted by trikerjack View Post
    That sounds like it's already down. You may have a different problem. Is the steering wheel all the way up? On some Stallions, if the wheel is up all the way, the trike won't start. The engine won't even turn over. Rick
    Stallion #378
    Suzuki Burgman 650
  1. Electric fuel pump pressure
    By Doug D. in forum VW Powered Trikes
    Last Post: 04-21-2017, 08:09 PM
  2. Fuel pump help
    By Nighttrain in forum VW Powered Trikes
    Last Post: 09-06-2016, 10:29 PM
  3. fuel pump
    By samsonone1 in forum Honda Trikes
    Last Post: 06-06-2013, 11:52 AM
  4. Fuel Pump
    By bigjoey38 in forum VW Powered Trikes
    Last Post: 06-12-2012, 12:55 PM
  5. Ok,Gravity or electric fuel pump?
    By warnerrd in forum VW Powered Trikes
    Last Post: 10-15-2010, 10:46 PM
