Speed Bleeders
Likes Likes:  6
Results 1 to 15 of 15
Thread: Tire pressures with passenger and luggage
    40+ Posts
    Feb 2020
    Yantis, Texas USA
    Default Tire pressures with passenger and luggage
    What tire pressure are you guys using in the front and rear when you have a passenger and luggage? I hear a lot are running 22-23 in the rear to help lessen bump response but that would seem very low if you had a passenger and luggage. Thanks for input.
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    I run 22-24 in the rear all the time,solo,two up with luggage and pulling a trailer.
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Quote Originally Posted by osudvm View Post
    I ran 25 in the rear solo 99% of the time..........With both my Tri's...
    2019 Tri-Glide.......
    5750+ Posts BillR's Avatar
    Aug 2015
    Gloucester, VA
    My Goodyear Comfortreads like 23 pounds all the time. 39-40 in the front Avon Trike tire, (not the new chrome).
    25 in the air shocks 1 up and 32 if two up.
    Bill
    R I P MANDY
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    There are several things you can do to get a better ride.
    I run 21-22 psi in the rear tires, all the time. Even 2-up and loaded for a 6 week trip. Gravel road, asphalt, tearing thru curves. At first I thought lowering the PSI that low would pop a bead in hard cornering. We've ridden well over 100K miles with no issues.
    Well, I say no issues, BUT the center of the tread will wear out faster at those lower PSI's. But that means 50k out of a pair of tires instead of 60k.
    There are also other tires, the Goodyear Comfortred, that have a softer sidewall and provide a smoother ride. In those I run 23-24, otherwise they wallow too much in the curves.
    Front tires I run the recommended...36 on the OEM and 40 on the Avon.
    In addition you can soften up the bumps some with a Convertible Comfort Lift™ which you can see HERE.
    The best thing you can do is get some Trike Series Shocks™. Shocks that were specifically designed for the Harley Trikes to give the most comfortable ride And a more stable/flatter ride. You can see details on them HERE.
    There is a full report on Rear Suspension that you may find useful HERE.
    Here's just one of the vids we have on Trike Rear Suspension...this shows some testing-
    www.DKCustom.com
  6. DKCustoms postbit
  7. #6
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    Center tire wear is an indication of overinflation.
  8. #7
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Quote Originally Posted by Sidecarbill View Post
    Yep.....But some tires with low Inflation will balloon at high speeds.and the centers will wear faster.....Two come come to mind 'The Spyder and the Slingshot ...
    That said i don't think that can happen with the Tri-Glide tires......
  9. #8
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    And Speaking of PSI.......How do you know if your air gauges are dead on...I have 3 and each one will be off a little from each other...I just use my cordless Ryobi digital inflator ..
    I just punch in the numbers turn it on [Set it and forget it] and hope its accurate ...
  10. #9
    600+ Posts ISP-FL's Avatar
    Mar 2017
    Lake Suzy, FL USA
    I guess I have been around RVs and enclosed trailers too long the last few years so my take on psi on my trike is a little different.
    In my experience a low, even slightly overloaded tire equates to much higher tire temps. Would it make enough of a difference if I kept my rear tires at 23 psi instead of 27 or 28 psi when we are traveling 2-up and loaded? Maybe, maybe not. But when you are on a 2 lane road "somewhere" in Arizona and the temps are hitting 110 it makes me feel much more confident in those rear tires.
    Current: 2019 Trike (custom 130ci T-Man kit with Darkhorse bottom end)
  11. #10
    Just Killing Time...
    paws's Avatar
    Oct 2011
    Kerrville, TX U.S.A
    Yes.. I came to the same conclusion... I gathered up all the “stick” and digital gauges around the garage and in the vehicles - did a pressure test - kept 3 that were closest in readings to each other. Tried to allow for operator error for pressure loss during tests. I even have a new Slime No Pressure Loss Digital Air Gauge - supposedly does not allow any air to escape - dunno...the jury is still out on that...but I kept it anyway.
    Moral of the story? Use the same air gauge every time; don’t worry whether it is exactly right or wrong; and go on down the road.
  12. #11
    1000+ Posts
    Aug 2016
    Des Moines IA US
    I run 36 in front and around 23 in rears on my 2018 and did the same on my 2016, I have one gauge strictly for the trike, it may be wrong and it may be right but it works for me anyway.
    All for now Trampas
  13. #12
    40+ Posts
    Feb 2020
    Yantis, Texas USA
    Kevin, when your shocks are installed I assume the adjustment knob that HD has for the rear suspension is NOT used? Is this correct, and if so, what do you do with the adjustment knob? Is it removed during installation of the 14 inch trike series shocks.
  14. #13
    40+ Posts
    Feb 2020
    Yantis, Texas USA
    I watched your video and got the answer. Thanks
  15. #14
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Yes, you are correct, and that is what really threw me for a loop 8 years ago when I first noticed this.
    Talked to a bunch of tire guys and realized that these are car tires, that are made for a much heavier load.
    They are rated for 1460 lbs each and have an inflation pressure of 44 psi. btw, they have a speed rating of 118 mph
    So, we are using them on a Trike that weighs, with a heavy load, under 2,000 lbs. At the most we are putting 1,000 lbs on each tire, more likely in the 600-700 range most of the time.
    HD recommends a PSI of 26 (which is the lowest they can legally state), but the tire is designed for 44 psi.
    The reason that there will be more wear in the center of the tire is because the sidewalls are designed for a heavier load and to keep the tread flat with the ground at 44 psi.
    When we run a lighter load, and the psi at 26, or 23 or 21, as rhino 2 states, the tread will balloon a bit, which will wear the center faster.
    This will be more pronounced at higher speeds (also from doing burn-outs).
    Mystery explained.
    Yeah, can be a bit of a chore to know if the gauges are dead-on, even the digital ones. I usually check the various ones I have a couple of times a year, and chuck any that are no longer accurate.
    Recently I have been using a digital, usb rechargeable, pump. Set the PSI and push start. It shuts off when it hits the target PSI I set. It makes life MUCH EASIER. You can see it HERE.
    Quote Originally Posted by ISP-FL View Post
    Yes, we use TPMS on Mary's truck and the Toy Hauler and I'm a bit obsessive about keeping the PSI at the max on those tires, AND monitoring the PSI and temps.
    The rear tires on the Tri-Glide and Freewheeler are so over-rated for the load, it is a non-issue.
    www.DKCustom.com
  16. #15
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Yes, we did not get into too much detail in the video...and before we did it we thought it might be more difficult than it was.
    Turned out very easy to remove.
    www.DKCustom.com
  17. DKCustoms postbit
  1. tire pressures
    By headheaded in forum Harley Tri Glide
    Last Post: 09-14-2015, 08:44 AM
  2. Tire pressures?
    By Hocky in forum Honda Trikes
    Last Post: 08-12-2014, 11:48 AM
  3. Tire pressures for h-d anarchy wheels
    By GARYD in forum Harley Trike Conversions
    Last Post: 07-28-2013, 12:10 AM
  4. tire pressures
    By rodeo1 in forum Honda Trikes
    Last Post: 07-11-2011, 09:11 AM
