Likes Likes:  2
Thanks Thanks:  1
Results 1 to 9 of 9
Thread: Puzzling issue with rear lights
    Mar 2019
    West Grove, PA, USA
    Default Puzzling issue with rear lights
    Having a lighting issue I haven’t been able to solve. Tail lights, running lights, brake lights and hazards all work properly. However, when I turn on either of the signals they just get bright and do not flash. I’ve practically disassembled it looking for a bad ground. I also replaced the flasher unit. Any wiring wizards around here?
    1999 Tour Glide with Electra Glide Sport front end. Torbleau trike kit.
    I believe the turn signals work off a Turn Signal Module
    Feb 2020
    Jersey City
    Does all the wiring look healthy?
    Quote Originally Posted by Durphey View Post
    Kevin.............Welcome to Trike-Talk..............
    What happens when you remove the flasher unit, do your 4 way flashers stop working?
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    You are correct Jack and if memory serves me correctly its zip tied to the right fork tube behind the fairing.
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    That is also what I remember. Had to replace one many years ago. Rectangular black box on right down tube . turn bars all way left & you should be able to see it. Unless someone moved it.
    Any new info on this problem?
    Mar 2019
    West Grove, PA, USA
    I ended up installing a Badlands module. That solved the problem.
  1. Replies: 4
    Last Post: 04-17-2018, 10:01 AM
  2. Which LED lights for the rear tail/brake lights
    By 470004 in forum Harley Trike Conversions
    Last Post: 11-20-2014, 08:13 PM
  3. driving lights and head lights
    By Dragon in forum Stallion Trikes
    Last Post: 10-05-2014, 09:25 PM
  4. Issue with Martini Lights......
    By hbrogan57 in forum Honda Trikes
    Last Post: 07-09-2013, 07:32 AM
  5. Champion rear brake issue
    By scribe5 in forum Honda Trikes
    Last Post: 05-22-2013, 01:49 PM
