ADSavarese13ZammyNew Member Introduct...New member from FL
DrCrazyTrain4rhino 2Harley Freewheeler /...True Dual Header
LD-Ordie9ZammyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie9Uncle FesterNew Member Introduct...Newbie from the Mojave Desert
DrCrazyTrain4Ron BaxterHarley Freewheeler /...True Dual Header
Burnerboy10rhino 2Can Am Spyder Trike...How many of you ride a Can Am spyde...
DK Custom Products362PosseRiderHarley Tri GlideWhat did you do to Your Tri-Glide T...
Sunman8PuckoachHarley Freewheeler /...Value of 2015 Freewheeler
dthorn5rhino 2Harley Tri Glide2024 Tri Glide front axle nut torqu...
gfaltersack7rhino 2Harley Tri GlideDK Customs remote oil filter kit in...
gfaltersack7gfaltersackHarley Tri GlideDK Customs remote oil filter kit in...
hardwickbv1hardwickbvHarley Tri GlideGot a Code P0152 Engine Running Ric...
dthorn5dthornHarley Tri Glide2024 Tri Glide front axle nut torqu...
dthorn5Papa ZookHarley Tri Glide2024 Tri Glide front axle nut torqu...
SSpoon14cycle7447New Member Introduct...Hello from VA
Richard D12CorkeykHarley Trike Convers..."Himsl Praying Mantis" Sh...
gfaltersack7ISP-FLHarley Tri GlideDK Customs remote oil filter kit in...
LD-Ordie9ol' schoolNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie9trike ladyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie9GorillaNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie9rhino 2New Member Introduct...Newbie from the Mojave Desert
LD-Ordie9SullyNew Member Introduct...Newbie from the Mojave Desert
ADSavarese13SullyNew Member Introduct...New member from FL
LD-Ordie9Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
ADSavarese13Jack KlarichNew Member Introduct...New member from FL
ADSavarese13woodyNew Member Introduct...New member from FL
LD-Ordie9LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
ADSavarese13hardwickbvNew Member Introduct...New member from FL
SSpoon14hardwickbvNew Member Introduct...Hello from VA
ADSavarese13ol' schoolNew Member Introduct...New member from FL
gfaltersack7TFNCHarley Tri GlideDK Customs remote oil filter kit in...
ADSavarese13GorillaNew Member Introduct...New member from FL
ADSavarese13Marc HNew Member Introduct...New member from FL
ADSavarese13ADSavareseNew Member Introduct...New member from FL
ADSavarese13Phu CatNew Member Introduct...New member from FL
ADSavarese13trike ladyNew Member Introduct...New member from FL
ADSavarese13Uncle FesterNew Member Introduct...New member from FL
dthorn5nucsealHarley Tri Glide2024 Tri Glide front axle nut torqu...
dthorn5TrampasHarley Tri Glide2024 Tri Glide front axle nut torqu...
ADSavarese13rhino 2New Member Introduct...New member from FL
gfaltersack7Phu CatHarley Tri GlideDK Customs remote oil filter kit in...
gfaltersack7Old Road DogHarley Tri GlideDK Customs remote oil filter kit in...
SSpoon14woodyNew Member Introduct...Hello from VA
SSpoon14hogmemberisoldNew Member Introduct...Hello from VA
SSpoon14ol' schoolNew Member Introduct...Hello from VA
SSpoon14Marc HNew Member Introduct...Hello from VA
SSpoon14ZammyNew Member Introduct...Hello from VA
SSpoon14Uncle FesterNew Member Introduct...Hello from VA
gfaltersack7DK Custom ProductsHarley Tri GlideDK Customs remote oil filter kit in...
SSpoon14rhino 2New Member Introduct...Hello from VA
SSpoon14trike ladyNew Member Introduct...Hello from VA
SSpoon14SullyNew Member Introduct...Hello from VA
SSpoon14Jack KlarichNew Member Introduct...Hello from VA
SSpoon14GorillaNew Member Introduct...Hello from VA
SSpoon14SSpoonNew Member Introduct...Hello from VA
DrCrazyTrain4powerhaulicHarley Freewheeler /...True Dual Header
DrCrazyTrain4DrCrazyTrainHarley Freewheeler /...True Dual Header
Likes Likes:  3
Thanks Thanks:  1
Results 1 to 6 of 6
Thread: Triking an ultra
    Aug 2010
    PORT ST LUCIE, FL
    Default Triking an ultra
    Thinking of converting a 2017 ultra limited low. Any help would be welcomed
    Jun 2010
    Indianapolis, In.
    Make sure you check out the Hannigan before making a decision.
    You should converse with Zook, the owner of this sight and the owner of Cut-n-Shoot trikes.
    http://www.cutnshootcustoms.com/
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    13000+ Posts FuzzyWuzHe's Avatar
    +1 on Cut-n-Shoot
    3750+ Posts
    Philip R's Avatar
    Feb 2017
    Noonday, Texas
    +2 on Cut-n-Shoot. Randy is "da man" for trike conversions.
    agree with all Randy will set you straight. it would even be worth the effort to have him do the build you will know its done right
    20+ Posts houronron's Avatar
    Nov 2013
    Houston, Texas
    Rotor
    I am converting my 11 Limited Ultra, using the Roadsmith Daytona kit, Zook is doing the conversion. I have personally been to CUT-N-SHOOT CUSTOMS & visited with him several times before making my final decision to do the conversion. He has spent a lot of hours talking with me & showing me different kits at his shop. He does not mind because the more you know the easier it will be for you to make a final decision. I was originally going to convert my 03 Firefighter ultra Classic and use the CSC kit until i found out that you can only run CSC mufflers because of lack of clearance. CSC mufflers are smaller OD than mine are.
    I run a S&S 124 engine & a Baker 6 speed 129 hp / 139 tq, my mufflers are tuned to my engine and i am not going to use some other mufflers that i know nothing about and have to pay my tuner to re-tune my engine that may or may not have the same results. I am not a hot-rodder i just like to be able to pass when i want to and be able to get out of my own way if i need to. My 11 Limited has a S&S 110 drop on kit with the same mufflers as my 124 and they are also tuned to my 110 engine. The CSC mufflers may be great but i am not going to take the chance with the money i have spent and would have to spend on another re-tune.
    My personal opinion from personally looking at Roadsmith & CSC kits at CUT-N-SHOOT, CSC has the best suspension and by far the best rear brakes of any of the kits. I will tell you this the lead time on the CSC kits are a lot sooner than what Roadsmith are, i placed my order back in early January and the kit has not arrived yet. Zook has kept me updated on all his emails to Roadsmith concerning the kit arrival. Zook is great to deal with and cares a lot about his customers. WOW this sounds like i'm doing a commercial for him but honestly he is really a great guy to deal with and his work is great as i have personally seen it even though i have not got my conversion done yet.
    Hope i have not bored everyone to death with this reply just wanted to share my experience so far.
    Ronnie.
  1. My Tow-Pac 14" InstaTrike Install on Ultra Classic Harley
    By HarleyBob in forum Outrigger Style Trikes
    Last Post: 05-13-2018, 07:28 AM
  2. Roadsmith Releases Striking New Gold Wing Trike
    By Papa Zook in forum Honda Trikes
    Last Post: 03-11-2013, 12:41 PM
  3. Harley Ultra Conversion
    By bdn56 in forum Miscellaneous
    Last Post: 03-15-2009, 07:10 AM
  4. Would you trike a 2000 ultra?
    By Lone Rider in forum Harley Trike Conversions
    Last Post: 01-06-2009, 07:32 PM
