Likes Likes:  19
Thanks Thanks:  9
Page 2 of 2 FirstFirst 1 2
Results 21 to 38 of 38
Thread: Air Filter Dilema
  1. #21
    Anti Sieze would be a better choice, it fills in the threads BUT makes for easier removal with out damage to threads
    Agreed, especially the environment they live in. I've been a friend of anti seize since my early days in engine rooms. I especially like in in exhaust applications. The end caps on my E Series Slip ons have it on the bolts that hold them on. The exhaust head connection to Head pipe studs get that too.
  2. #22
    Too many folks do not understand how Anti Sieze fills in and lubes the threads allowing for easier removal BUT it helps maintain the fasteners holding abilities, My Dad the best MECHANIC I knew taught me very young. And there is a HUGE difference in mechanics and techs ( I call them component replacement people) where true mechanics rebuild not just replace parts
  3. #23
    Anti seize will also allow you to get closer to actual torque when torquing bolts down. I use it primarily on items that get hot and are exposed to the weather.
  4. #24
    Oct 2010
    USA
    Galvanic corrosion is possible with dissimilar metals. Reminds me of copper pipe and iron pipe.
  5. #25
    The anti seize will help, in this case you have steel screws in aluminum.
  7. #26
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    used for years. good stuff
  8. #27
    150+ Posts prariepilot's Avatar
    Apr 2016
    North Ridgeville OH, USA
    Quote Originally Posted by Fearless View Post
    If you need parts to replace let me know. I removed the football off Old Shiney and stored the parts I have everything but the center of the air cleaner cover. I used that on the Boyeson X force I installed. For the cost of the shipping you can have what you need. Travel afe Fred
    Thanks, Fred! When I make the attempt to get it off and break something, I'll be in touch.
    2013 Tri Glide Ultra Classic (FLHTCUTG) DK Oil Cooler/Relocation Kit DK Custom Tank Lift Kit DK EBS Kit K&N A/C in Stock Airbox Convertible Comfort Lift Kit w/ 14" Pro Action Shocks
    Vance & Hines Monster Ovals behind OEM decatted header Motor Trike Mechanical Reverse DynaJet Power Commander V
  9. #28
    Apr 2016
    They should have no loc Tite. I like to use anti sieze here instead. It fills in the threads but will NOT lock up unlike Loc Tite , I believe the torque setting is 40-60 inch pounds. Keep in mind you will be servicing this filter so be careful with loc tite
    After removing the OEM air cleaner at about 5K miles and replacing it with the K & N, I've never used Loc-Tite on those bolts and they were properly torqued. The K & N came off every 5K after that to be soaked and cleaned. Still, no Loc-Tite. Can't figure out what caused this until I get it apart, unless the indy I had do the front wheel bearings, brakes and fluids change last summer pulled it to check it.
    As I told Fred, I'll know when I start to take it apart and break something!
  10. #29
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    www.DKCustom.com
  11. #30
    100+ Posts Diablo's Avatar
    Nov 2019
    Gun Barrel City, Texas
    Quote Originally Posted by Philip R View Post
    QUOTE=Mykneesbehurtin;741189]Have owned one of these for years and they do work.Try riding it until it reaches a good temp may be enough to loosen the locktite up or using a pencil torch head the head of the bolt head then let it set for about 5 minutes to let the heat to travel the length of the bolt before trying to remove.
    Every toolbox should have one. It was the only way to keep from destroying the points cover screws on my fist Honda.[/QUOTE]
    I somehow ended up with two......that's good in case one goes 10 mm socket on me!
    Larry
    Diablo
    "People are more violently opposed to fur than leather because it's safer to harass rich women than motorcycle gangs." - Dave Barry
  12. #31
    Apr 2016
    Well, seein' as how we've got a wealth of knowledge and experience on this forum, I followed all y'all's advice and ordered the Craftsman Hand Impact Driver and a box of ten #27 High-Impact Torx Bits. They'll be here Friday. Then I'll tackle getting this air cleaner off on Saturday - supposed to rain all weekend.
    I'll let all y'all know what parts I broke early next week!
  13. #32
    Quote Originally Posted by prariepilot View Post
    Good deal and good luck on your project No tool box is complete with out an impact driver
  14. #33
    I had time to check a couple of my shop manuals, I did not see any recommendations of Loc Tite on the air filter bolts, however I still use anti sieze on mine
  15. #34
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    Thumbs up
    For sure.
  16. #35
    Dec 2013
    Clarion PA USA
    the offer still stands. Fred
  17. DKCustoms postbit
  18. #36
    Apr 2016
    Default Continuing the Saga....
    All the tools, Torx bits and crappy weather rolled in over the last week and it's been too cold in the garage to comfortably work.
    This morning I decided enough is enough and went to the cold garage to see how much progress I could make. I quickly found out the Impact driver was just that and snapped off what was supposed to be a high impact #27 Torx bit! So, I put the impact driver down, got my ratchet handle, adapter, and another high impact Torx bit. This one didn't snap! It just twisted like a Dairy Queen soft serve ice cream cone!
    Enough of this nonsense! Grabbed the drill and a bit and went to work drilling off the bolt heads. Pop! Off came number one! Drill some more and Pop! Off came number two! Drill some more and, well you get the picture! With the bolt heads all removed, the bracket and filter slipped right off with no problem.
    Here's where it gets wierd. I was able to wiggle one bolt before I locked the vise grips on it. Tried to turn it with my fingers and it came right out! Tried the other two. Yep, came right out. Just a hint of the white Harley wax thread coating on each one.
    Somewhere between the filter and the bracket, these bolts were bound up so tight it was twisting and snapping the Torx bits!
    Now, as soon as we need to make the "essential" trip for groceries, Lowe's is right next door and I'll slip over there to get hex or allen head bolts to replace the ones I drilled out.
    Thanks to all for the encouragement and suggestions.
    BTW, the only thing I "broke" were the Torx bits and the bolts I drilled out! Amazing
  19. #37
    Dec 2013
    Clarion PA USA
    Great news good to go back together. I have had the same thing happen with scope mounts on rifles. Fred
  20. #38
    Mar 2018
    Lutz Florida USA
    Default Red tite
    Heat up to till it’s red then try
  1. K&N Replacement Air Filter for the OEM Filter.
    Last Post: 12-22-2017, 01:51 PM
  2. Deformed air box, it had a K&N air filter
    By GoldWingrGreg in forum Honda Trikes
    Last Post: 11-10-2017, 11:24 AM
  3. mind melt dilema
    By ratrodney in forum General Discussion
    Last Post: 06-23-2013, 10:10 AM
  4. Stock air filter back on....
    By krooozn in forum Honda Trikes
    Last Post: 05-16-2011, 11:58 AM
  5. Oil Overspray into Air Filter
    By PopDukes in forum Harley Trike Conversions
    Last Post: 08-17-2009, 09:35 PM
