Likes Likes:  1
Thanks Thanks:  1
Results 1 to 10 of 10
Thread: rear axle
    40+ Posts
    Mar 2019
    Myrtle Beach
    Default rear axle
    anyone know what size rear end is in the stallion is it the 7.5 or 8.8 thank you
    450+ Posts rocket1lf's Avatar
    Dec 2013
    Hot Arizona, USA
    If I remember correctly, it's either a 6.5 or a 7.5. I do know it's a 4.10. I tried lowering it to a 3.73 to try to get better mpg, but the trike was gutless and would barely go up a hill. The little 4 banger needs to get the rpm's up. I do know when we pulled it apart, it wasn't set-up correctly and the gears were rubbing on the case. I had it set up on a dyno and got some more horsepower and torque out of it. Fuel mileage went up slightly also. Rick
    Stallion #378
    Suzuki Burgman 650
    40+ Posts
    Mar 2019
    Myrtle Beach
    Quote Originally Posted by rocket1lf View Post
    I live in sc was thinking about putting 355 ratio in it the 4.11 makes the motor turn a lot of rpm at 65 miles per hour
    Dec 2013
    Hot Arizona, USA
    If you want to spend the money, try it. I did and and then spent the money again going back to the 4.10. I got way more for my money having it tuned on the dyno. I picked up 30% more horsepower and torque between 30 and about 90. Mileage went up slightly also. I'm up and down the mountains here in AZ and I average 30-32. That's going from about 1700ft at my house up to anywhere between 4700 and 7700 feet and back. This is all up and down and most of it is at 70mph. Went for breakfast this morning which was at about 5500 feet. 165 miles and I averaged 30.6. I got worse mileage with the 3.73 in it. Rick
    Stallion #378
    Suzuki Burgman 650
    250+ Posts
    Dec 2010
    oly,wa
    Good morning
    my 2 cents is if you want to change gear ratio you have to go tell the computer also, it is expecting to receive information from stock configuration
    Dragon
    40+ Posts
    Mar 2019
    Myrtle Beach
    Default rear axle
    we was planning a trip this year to az but this virus got us shut down now my mom lived in tucson
    Dec 2013
    Hot Arizona, USA
    Good morning
    Dragon
    When we looked at the computer, it was still set up like a Ranger PU would be. Timing was way low and fuel wasn't correct. There is a thread on here about what was done. Rick
    Stallion #378
    Suzuki Burgman 650
    40+ Posts
    Mar 2019
    Myrtle Beach
    Default rear axle
    I looked cant fine that thread
    Dec 2013
    Hot Arizona, USA
    Quote Originally Posted by Just BOB View Post
    https://www.triketalk.com/forum/thre...er-Performance
    Stallion #378
    Suzuki Burgman 650
    Apr 2010
    Shenandoah Valley of Virginia
    Look at rear cover.
  1. Need DNA rear axle dimension.
    By bobscogin in forum Home Built Trikes
    Last Post: 06-25-2016, 09:38 AM
  2. Solid Axle vs Independent Axle
    By vbbuilt in forum Harley Trike Conversions
    Last Post: 09-15-2014, 11:53 AM
  3. short trikes..4wheeler rear axle assy
    By bj tribble in forum VW Powered Trikes
    Last Post: 11-07-2013, 11:57 AM
  4. Rear Axle Rigid Swingarm or 4 Link?
    By mutwagn in forum Home Built Trikes
    Last Post: 03-19-2013, 09:05 PM
  5. rear wheel track ( Axle widths)
    By sophtayl in forum Harley Trike Conversions
    Last Post: 05-14-2009, 08:39 PM
