Likes Likes:  10
Thanks Thanks:  1
Results 1 to 20 of 31
Thread: Reverse Motor keeps breaking
    Mar 2020
    Bradenton, Fl USA
    Default Reverse Motor keeps breaking
    I have had my Reverse Motor replaced 5 time now. How many others are having the same problems? My last one only put 2000 miles on bike before it went out. I am sick a hell over this. Is HD every going to fix this problem? Your guess is as good as mine.
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    Quote Originally Posted by scubadog40 View Post
    Hi William and welcome to Trike Talk. I've no first hand knowledge having put 24k on my 2018 TG and now have a new 2020 TG but I've heard and read of failures with the reverse motor. But you problems definitely sound excessive even for the 'ordinary' problems. So a couple questions that may help you and many of the others who reply here to identify what is going on.
    What year is your Tri-Glide
    How many miles
    Does the circuit breaker trip. If so how often.
    How do you use reverse? It is only for short spurts - not long term engagement and definitely not for backing up inclines. These things will no doubt contribute to an early failure.
    I try to limit its use when riding two up. I'll back it out before my co-rider mounts.
    And of course it may be possible there is some sort of installation / fitment problem that is contributing to the early failure of the motor. I've never removed / installed a reverse motor but is it possible for some sort of misalignment.
    You definitely need a competent dealer / indy to investigate this it seems to me. This is not normal even by Harley standards.
    Good luck in remedying this problem.
    150+ Posts prariepilot's Avatar
    Apr 2016
    North Ridgeville OH, USA
    First time mine went out ('13 TG), it got replaced with a Motor Trike Mechanical Reverse w/ Safety Lockout. Why? Rebuild the MoCo motor at $295 a pop, and you'll just keep rebuilding it. Replace it with a new one, you have to pay for it at $1700 plus labor and you'll replace it again and again. Spend $1800 plus labor ($2200 total in my case) and it's done! I can back up anywhere for as long as I want and as fast or slow as I want (as long as I can keep it under control). Been running mechanical reverse for about five years now with absolutely no issues!
    2013 Tri Glide Ultra Classic (FLHTCUTG) DK Oil Cooler/Relocation Kit DK Custom Tank Lift Kit DK EBS Kit K&N A/C in Stock Airbox Convertible Comfort Lift Kit w/ 14" Pro Action Shocks
    Vance & Hines Monster Ovals behind OEM decatted header Motor Trike Mechanical Reverse DynaJet Power Commander V
    First ' William Let you welcome you to Trike-Talk.....Second what year is it....
    With my 2011 Tri....I took mine out four times my self before i bit the bullet and put in a Mechanical reverse.....Problem resolved...
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    I do like the idea of a mechanical reverse but I think that could present problems with Harley's factory warranty and some ESPs if installed. I read the installation instructions for the product mentioned and while it looks very well engineered it does involve mods to the trans and the wiring system. Not all have such warranty concerns but for those who do I would consider the implications.
    Dec 2013
    Clarion PA USA
    Default sorry to hear
    Sad you are having so many problems with the reverse motor not wanting to hex myself I believe our 09 has the OEM on it. I have not had any issues with it at all. I want you to know I only use on the level and not for extended periods doing so. I am very fortunate not to need it often, I pick my stopping and parking places very very carefully and will not use it unless it is absolutely necessary. I have heard so many horror stories such as yours I am very careful when and how I use it. Good luck a mechanical may be the best route of your purposes. Travel safe Fred
Size:  162.6 KBName:  DSC01103.JPG
    I cleaned our frame up last year and again this that reverse motor is no fun to get at with the body on let me tell you. the dirty one is 8 years of crudd
    Quote Originally Posted by Fearless View Post
    Actually its not too bad.....But then i had practice at it [4 times]...I disconnected the wires to the solenoid taped the ends and then zipped tied them out of harms way ,Then just unbolt the two bolts holding the motor to the frame....All this was while going in from the right side with out jacking up the trike or removing the rear tire ;
    ;AKA Caveman Style..........
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    I've had 2 or 3 replaced, under warranty, since 2011. I use mine whenever I want. Sometimes days go by without using it, other times I may use it 5 times in one day. I do try and limit backing up hill with it.
    Having 5 failures, with one of them being after 2000 miles...that is not usual.
    Are these replacements new HD units or a 3rd party rebuilt? Is reverse used a lot in going up hill or in sand, etc?
    Might be time to go with a mechanical and be done with it.
    www.DKCustom.com
    Welcome to Trike Talk
    Sorry to hear your problem
    My understanding is HD is only rebuilding the motors now, it sounds like your problem is not being addressed properly
    What do your repair orders show?
  11. #10
    150+ Posts
    Firewrench22's Avatar
    Oct 2014
    Kingston WA USA
Size:  567.1 KBYeah baby...
    Reverse motor for sale
  12. #11
    650+ Posts
    Sep 2015
    Sheboygan, WI
    Welcome aboard, William!
    So far at 29,000 miles, no issues yet. I do Like Fearless, don't use it any more than needed. I watch where I park & let gravity do the work. And short bursts only & never up hill. Hope you get it sorted out, does not sound normal to me, based on your info so far.
    It is what it is.
    16 Tri Glide vivid black
  13. #12
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    May be just lucky. I used mine whenever I wanted. Have slight incline in drive & backed up it many times. Just traded the 16 on a 20. Had 45,000 miles on it & no reverse problems at all. Sorry to see all your troubles. Actually I don't remember ever having the breaker pop either.
  14. #13
    Mar 2020
    Bradenton, Fl USA
    Default Mine is a 2014 with 25000 mile on it
    Mine is a 2014 with 25000 mile on it. I took out extra warranty when I got my bike and it has saved me a lot more then the cost as I am on my 5th one. Mostly use it when taking it out of garage. It has only tripped the breaker a hand full of times. Every time it goes out not doing any thing crazy.
  15. #14
    Mar 2020
    Bradenton, Fl USA
    I have had it replaced at 3 different HD Shops. This thing is driving me nuts as I am disabled and can't push it bake on my own. Good wife pushes me back when it breaks. After warranty is out will find different kind.
  16. #15
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Good to hear you have the warranty...that is what saved me too. But 5 times is far too many. What a hassle.
    www.DKCustom.com
  17. DKCustoms postbit
  18. #16
    Sep 2012
    Lakeland, FL
    I find it odd that scubadog has not answered the questions.
  19. #17
    He did say he will keep on replacing them..[Harley only rebuilds them now]... ''Till' the warrantee is over, So that means going to a mechanical down the road.....
  20. #18
    I would like to see his Repair Orders to confirm exactly what the dealer is doing
  21. #19
    100+ Posts MontgomeryLittle's Avatar
    May 2011
    Murfreesboro Tn. USA
    I agree here. Hard to diagnose online really. I'm just curious if it had a burnt spot in the armature or field coil or both and they throw it on a high amp battery, get it to turn, and reinstall it and call it good. Could be brushes, tap on it and it works again for awhile. But I would get the battery load tested. If they have not already. A dead cell can burn up a starter, reverse motor. And does not really show up on a trickle charge or charger. Everything else may work fine.
    [SIGPIC][/SIGPIC]
  22. #20
    Quote Originally Posted by MontgomeryLittle View Post
    Yes indeed, the tapping breaks the carbon arc just enough to turn the motor over a bit but does NOTHING in the long term health of the motor
  1. Battery keeps draining - help!
    By GYPSYGAL in forum Honda Trikes
    Last Post: 12-05-2016, 03:04 PM
  2. Reverse breaker keeps tripping....
    By consitter in forum Harley Tri Glide
    Last Post: 07-02-2016, 10:38 AM
  3. Gas keeps getting lower
    By KBot in forum General Discussion
    Last Post: 01-21-2015, 02:09 PM
  4. bulb keeps blowing
    By Southern Man in forum General Discussion
    Last Post: 05-10-2011, 10:03 AM
