Speed Bleeders
Likes Likes:  17
Thanks Thanks:  1
Results 1 to 11 of 11
Thread: Back on the road 1999 Valkyrie Interstate
    100+ Posts Scott1's Avatar
    Mar 2012
    Cranberry Township, PA, USA
    Default Back on the road 1999 Valkyrie Interstate
    My Honda 1999 Valkyrie Interstate with a 2002 Lehman Predator Trike Kit, solid axle, shaft drive, drum brakes. I have been working over the winter months restoring my 1999 Valkyrie Trike. 10 years ago (2009), the engine 1520cc, in my Valkyrie Trike suffered a hydro-lock fuel cylinder problem, a common Valkyrie problem, where fuel leaks into one or more engine cylinders, which when I attempted to start the engine, the starter motor broke off a tooth on the intermediate gear between the starter and the starter/clutch gear. I have never done any internal engine work and now I had to remove the engine to repair the broken gear. In 2009 an independent Honda mechanic wanted $2000, plus parts, to repair the engine and he would only work on it when he had free time. He said 3 to 6 months to fix it. It was riding season, so I parked the Valkyrie and purchased a new left-over 2008 Goldwing (level 3) and had a 2009 Motor Trike kit installed. (My current bike)
    Now 10 years later I got out the Honda shop manual, put the Valkyrie on my trike lift and started to remove the engine. I drained the antifreeze and oil, I then removed the seat, fuel tank, air box, radiator pods, radiator hoses, radiator, thermostat, battery, exhaust, starter, alternator, spark plug wires, clutch line, throttle cables, choke cable, and drive shaft. Next, I remove the engine (260 Lbs.), 6 carbonators, the clutch casing, then the clutch. Next removed the back-engine case and now I could see the broken gear. I was told that I had to replace the gears on each side of the broken gear, because they could have been damaged by the broken gear. To remove the gears on each side of the broken gear, I had to grind out 3 locking nuts that were staked on to 3 different shafts that held each gear in place. To work on the engine, I needed to purchase all the special Honda tools listed in the shop manual. Oh, I did find the broken tooth in the bottom of the engine case.
    Time to get the new engine parts and start replacing the 3 gears. New parts were clutch gear, intermediate gear, starter gear, shaft lock nuts, shaft bearings, seals and gaskets. After I replaced the gears and torqued the lock nuts, I reassembled the engine and then installed it and reassembled everything that was removed to get the engine out.
    Next, I had to fix the cause of the hydro-lock problem. I disassembled and rebuilt all 6 carburetors (every part that could be replaced including the fuel rails), replaced (all new parts) radiator hoses, thermostat, all vacuum hoses, fuel line, spark plugs, added a fuel filter and an electric fuel shutoff valve, a K&N air filter, new vacuum fuel petcock, cleaned the rust and dirt from inside the fuel tank and seal coated the inside of the fuel tank, I removed the Smog System Piping and installed the 6 rebuilt carburetors.
    I installed new stainless-steel braided brake lines and clutch line, added dot 4 brake fluid, new antifreeze, oil & filter, drained and filled the rear differential fluid, adjusted the rear drum brakes, rebuilt the front brake calipers, replaced the front disk brake pads. Cleaned the headlight/turn signal switches, added a USB charge port, replaced the battery, added a second fuse block and a second battery in the trunk with an automatic battery isolator, added 3 led light kits (276 Leds total), and added some new safety chrome.
    I started the engine and had to balance (sync) the 6 carburetors, put the rear wheels on and cleaned and polish everything. The best part is that the engine started and runs. With what I replaced I should have "almost" a new bike.
Size:  86.9 KB Name:  0326201236 (2).jpg
Size:  74.0 KB Name:  0326201236e (2).jpg
Size:  68.5 KB Name:  0326201243a.jpg
Size:  66.8 KB Name:  0326201237_01.jpg
Size:  56.2 KB Name:  0326201237e (2).jpg
Size:  58.6 KB Name:  0326201238a (2).jpg
Size:  73.1 KB Name:  0326201239_(2).jpg
Size:  51.3 KB Name:  0326201240.jpg
Size:  65.7 KB Name:  0326201240e.jpg
    [SIGPIC][/SIGPIC]
    2008 GL1800 Level 3 W\2009 Motor Trike Adventure IRS Kit
    1999 Valkyrie Interstate W\2001 Lehman Predator Trike Kit
    2021 Can-Am Spider F3 Limited (Girlfriends)
    2009 Vulcan 900 Classic, full dresser (Girlfriends)
    2019 Coachmen Catalina Trail Blazer 30' Toy Hauler/Camper
    Mar 2012
    Default Pictures continued
    Pictures continued.
    I didn't keep track of what I spent for this rebuild, but I got a show bike that I'm proud of and it turns the heads of the Harley riders.
    Last picture is both of my trikes. WHITE, the GOOD ONE and Black, the BAD ASS ONE.
    Thanks for viewing my post.
    Greg
Size:  61.3 KB Name:  0326201242k.jpg
Size:  68.2 KB Name:  0326201242c.jpg
Size:  57.4 KB Name:  0326201242b.jpg
Size:  66.8 KB Name:  0326201241a.jpg
Size:  62.8 KB Name:  0328201143a.jpg
Size:  53.2 KB Name:  0328201143c.jpg
Size:  45.8 KB Name:  0323201031c.jpg
    [SIGPIC][/SIGPIC]
    550+ Posts Gideon's Avatar
    Dec 2012
    Indianapolis, IN. USA
    Quote Originally Posted by Scott1 View Post
    Pictures continued.
    Last picture is both of my trikes. White, the good one and Black, the bad ass one.
    Greg
Size:  62.8 KB Name:  0323201031c.jpg
    There is nothing like the Valkyrie, great as two wheels, fantastic as a trike!!!
    Dec 2014
    Grand Junction, Co. USA
    Quote Originally Posted by Gideon View Post
    Gold Wing with Attitude!
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    nice trike glad you are keeping in its glory
  6. #6
    20500+ Posts
    Zammy's Avatar
    Jan 2015
    W. Florida
    Wow, lots of work put in and it really shows Greg, great job, she is beautiful.
  7. #7
    2000+ Posts trikeman's Avatar
    Oct 2010
    Jackson Tn. Madison Co.
  8. #8
    Mar 2012
    Yes, 6 carburetors, advanced ignition timing, different cams than a 1500 Goldwing and it does have a deep mean throaty growl to it sound. It has Two Brothers exhaust, 6 into 6 exhaust drag racing pipes, no baffles and I made my own glasspack mufflers that fit into the 2, slip on 5 inch truck stacks with 90 deg. turnouts. It definitely not a Goldwing.
    Exhaust view on my lift.
    .Name:  0301200651.jpg
Size:  42.4 KB Name:  0301200653.jpg
Size:  42.9 KB Name:  0301200652A.jpg
    [SIGPIC][/SIGPIC]
  9. #9
    I have a knife addiction..
    Gone2Three's Avatar
    Aug 2016
    Pflugerville, Tx
    Absolutely beautiful! What a beast, you've done a fantastic job bringing it back to life
  10. #10
    Bob's Curmudgeon Apprentice
    consitter's Avatar
    Jun 2015
    Ashland, KY
    I'd love to hear what it sounds like when running...
  11. #11
    Apr 2010
    Shenandoah Valley of Virginia
    Nice Job Scott!
    It was a huge undertaking, but it looks to have paid off.
    Make Courtesy Your "Code of the Road" too!
  1. 1999 Valkyrie Roadsmith Trike Begins
    By frankj in forum Roadsmith Trikes
    Owners Forum
    Last Post: 04-09-2019, 06:57 AM
  2. Replies: 3
    Last Post: 04-03-2014, 06:27 PM
  3. car tire on valkyrie interstate csc trike
    By trikedaddy in forum Honda Trikes
    Last Post: 03-21-2014, 08:38 AM
  4. Additional rear lights for Valkyrie Interstate Trike
    By lousepulveda in forum Honda Trikes
    Last Post: 11-07-2011, 04:44 PM
  5. Valkyrie Interstate Trike questions
    By r84boomer66 in forum Honda Trikes
    Last Post: 03-12-2010, 07:46 PM
