Likes Likes:  4
Thanks Thanks:  2
Results 1 to 13 of 13
Thread: Z Pipe and the Comfort Lift
    150+ Posts
    Mar 2020
    Surprise, AZ, USA
    Default Z Pipe and the Comfort Lift
    I just installed the DK comfort lift kit on my 2020 TG. What is the cure for the Z pipe hitting the swing arm? I'm thinking about modifying the hanger bracket for the cross over pipe so that it will hang down lower. I also remember reading somewhere that you can add a spacer between the muffler and the muffler mounting bracket and use a longer bolt which will drop the mufflers down and thus increase the clearance between the Z pipe and the swing arm. If possible I prefer not to use the alternate mounting holes in the lift kit as I want to have as much lift as possible.
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Quote Originally Posted by molokaimike View Post
    With my 2011 Tri i modified the hanger......But be careful of hitting the belt with weight on the trike...
    2019 Tri-Glide.......
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    welcome mike
    1500+ Posts Ray Paige's Avatar
    Aug 2018
    Bitterroot Valley, MT, USA
    Welcome From Montana
    Dec 2013
    Clarion PA USA
    Welcome to the forum from Western Pennsylvania I think somewhere I saw a fix for this I believe Kevin knows what to do tomorrow give DK Custom a call Im sure they will have an answer. Really good people there. ride safe Fred
  6. DKCustoms postbit
  7. #6
    Dec 2014
    Grand Junction, Co. USA
    If I remember correctly, it's a matter of a larger weld on the 2019 and up swing arm, but, I'm not positive. I would definitely give DK customs a call tomorrow ... in the meantime I'm gonna move this thread to the Tri Glide forum so it gets more notice by Tri Glide owners and Kevin.
    At about 2:40 in this video it talks about the huge weld bead and the fix.
  8. #7
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    Does it hit while the trike is at rest on the floor or only when it is jacked up and the suspension at nearly full extension.
  9. #8
    1000+ Posts
    Aug 2016
    Des Moines IA US
    The alternate holes is only 1/4" in height, if it will fit in alternate holes go for it, 1/4" isn't much and you will never know the difference in the alternate holes or the full lift holes
    All for now Trampas
  10. #9
    150+ Posts
    Mar 2020
    Surprise, AZ, USA
    Quote Originally Posted by Mykneesbehurtin View Post
    It is touching with the bike sitting on the wheels with no load on it.
  11. #10
    1500+ Posts
    Apr 2016
    Dayton Ohio
    As you put weight on the bike the gap between the swingarm and the pipe will increase also when suspension compresses the gap will get even bigger.On my 17 there may be a 1/16 or less of clearance between the weld and the swingarm but i have never heard or felt it make contact with the swingarm.You may try to loosen the clamp where the cross over pipe clamps to the head pipe and see if you can work a little more clearance or try grinding some of the weld down.
  12. #11
    150+ Posts
    Mar 2020
    Surprise, AZ, USA
    I found that I had the pre-load adjustment set too high for my weight. When I set it to the correct amount I looked at the Z pipe and now there is a gap that appears to be between 1/16" to 1/8" which should increase when I sit on the bike.
  13. #12
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    Glad you got it worked out. When you hit a large bump and your suspension Tops out on the rebound, you may hear a little clank. It will not damage anything...might mar the powder coat, but that is it.
    We do recommend that 2017 and up models use the secondary holes. This is because, as Fuzzy mentioned, the weld on the S pipe is obnoxiously large. The only other solution is to grind down the extra welding material at that joint.
    Most folks just use the secondary holes on 17+ models.
    Enjoy your new ride!
    www.DKCustom.com
  14. #13
    1000+ Posts
    Aug 2016
    Des Moines IA US
    If you had read my post and put in the secondary holes you wouldn't have to worry about it anything, you only lose 1/4 inch, as Kevin below your post he said secondary holes for 2017 and up, he even on his 2019 put in secondary holes, your bike do what you want, you want the full lift, fine but 1/4 inch you would never know it, as Kevin you might here a slight bump and power coating maybe coming off, oh might rust later on, who knows, if happy the way it is, good for you
    All for now Trampas
  1. Replies: 17
    Last Post: 10-11-2020, 02:13 AM
  2. Replies: 21
    Last Post: 04-19-2017, 06:22 PM
  3. Z Pipe Issue On My Freewheeler With Comfort Lift Install.
    By Bill G in forum Harley Freewheeler / Road Glide 3
    Last Post: 08-15-2016, 07:13 AM
  4. Replies: 7
    Last Post: 07-08-2016, 03:45 PM
  5. Comfort lift install and results
    By uppercaseJC in forum Harley Trike Conversions
    Last Post: 10-26-2015, 11:46 AM
