Likes Likes:  5
Thanks Thanks:  4
Page 2 of 2 FirstFirst 1 2
Results 21 to 27 of 27
Thread: Love Jugs Wiring Question
  1. #21
    1500+ Posts ShapeShifter's Avatar
    Aug 2018
    SW, Arkansas, USA
    Quote Originally Posted by molokaimike View Post
    I spoke with the service department today and they said that the accessory plug under the side cover is hot when the ignition switch is on and off when the switch is off. It is also hot when the ignition switch is in the accessory position so I could turn the engine off and keep the fans running if I want.
    That's right!! Whenever I return home and my engine is hot, I leave the trike at the front of the carport with engine off and fans running with the switch in the accessory position. Helps to cool it down quicker before moving it to its spot at the rear of the carport where there's less air flow. Plus, the quicker it cools down the sooner I can get it all settled in with the cover on a cool bike.
    2016 Tri Glide Billet Silver w/Pinstripes ["Hi-Yo, Silver! Away!"]
    • "There is so much good in the worst of us, and so much bad in the best of us, that it ill behooves any of us to find fault with the rest of us." ..... James Truslow Adams
    • 2nd BN 33rd Armor "The Tiger Battalion" "1972 - 1974"
  2. #22
    150+ Posts
    Mar 2020
    Surprise, AZ, USA
    Well I talked to two different dealers today and neither one of them could tell me where the damn plug is located. One of them asked me if I had the service manual which I do so he said look it up, WTF. I told him that the service manual just shows the wire color and routing for all of the plugs, it doesn't give the physical location. So, tomorrow I'm riding down there and tell them to pop the side cover off and show me where it is. They both acted like they never heard of Love Jugs before.
  3. #23
    Aug 2018
    SW, Arkansas, USA
    Here's a snapshot from Harley's Installation Instructions explaining and showing an image of it's location behind your right side cover. Not sure if this has any more detail than what's in your service manual?
    They're not being overly helpful because you're taking money out of their pockets by not using HD Parts and their labor rates. ...Wish ya the best on your project. Name:  20200410_191317.png
  4. #24
    150+ Posts
    Mar 2020
    Surprise, AZ, USA
    Thanks for the info. I found the connector but it's a totally different type of connector than what comes on the Love Jugs so I can't use it. Unless Love Jugs comes up with an adapter I might be stuck with cutting off the connector and wiring it directly to the battery. If I do that then LG will come up with the new adapter. I do have an old 4 pin to 8 pin adapter and since they don't have any 8 pin connectors on the TG maybe I'll cut off the 8 pin and use it as an adapter to go straight to the battery. That way if LG does come up with the correct adapter then I will not have cut off the 4 pin connector on the LG's.
  5. #25
    20+ Posts
    Jan 2019
    Praradise valley,arizona,usa
    Call love jugs. Buy their plug adapter. It makes it easy and it works well
  6. DKCustoms postbit
  7. #26
    150+ Posts
    Mar 2020
    Surprise, AZ, USA
    I have their adapter but it's a 4 pin to 8 pin adapter. The accessory plug on the 2020 TG is a 3 pin connector. I used my old 4 to 8 pin adapter and cut off the 8 pin connector to connect it directly to the battery and everything works great. Now, if Love Jugs makes the correct adapter I can replace my jumper with the correct one and go directly to the accessory plug on the TG.
  8. #27
    150+ Posts
    Mar 2020
    Surprise, AZ, USA
    I found the new 3 pin to 4 pin adapter that Love Jugs now has so I ordered one. Now I'll be able to plug into the Harley accessory 3 pin plug. Problem solved.
  1. Anyone using Love Jugs?
    By MB1953 in forum Harley Trike Conversions
    Last Post: 12-18-2014, 01:01 PM
  2. Love Jugs
    By Sully in forum Harley Trike Conversions
    Last Post: 07-20-2014, 01:35 PM
