ADSavarese8ol' schoolNew Member Introduct...New member from FL
ADSavarese8GorillaNew Member Introduct...New member from FL
ADSavarese8Marc HNew Member Introduct...New member from FL
ADSavarese8ADSavareseNew Member Introduct...New member from FL
ADSavarese8Phu CatNew Member Introduct...New member from FL
ADSavarese8trike ladyNew Member Introduct...New member from FL
ADSavarese8Uncle FesterNew Member Introduct...New member from FL
ADSavarese8rhino 2New Member Introduct...New member from FL
Likes Likes:  31
Thanks Thanks:  6
Page 2 of 2 FirstFirst 1 2
Results 21 to 36 of 36
Thread: Tank lift kit
  1. #21
    450+ Posts TonkaDriver's Avatar
    Feb 2018
    Bagdad, AZ, USA
    Default Copper Wings
    I put a 1.5" Deluxe kit and sent my wings off for copper plating.
    You will enjoy the upgrade.
    Kurt
  2. #22
    200+ Posts Wmitz's Avatar
    Jun 2018
    Crossville, TN, USA
    Quick question for those who have the 1.5 inch lift. Is there enough room to aim the deflectors more towards the rear cylinder? Thanks.
  3. #23
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    Quote Originally Posted by Wmitz View Post
    I'm running the 1.5" on mine and I think I have my Cooling Deflector Wings in the sweet spot. They catch a good amount of air that does two things-
    1. Stops it from going over the top of the tank
    2. Redirects it over the cylinders and heads.
    They mount on the bottom of the tank lift, so the height of the tank lift is not very relevant...unless you wanted them to be more horizontal...but putting them more horizontal than pictured in the video below at the 4:50 mark, will not catch as much air, and possibly have the tips running into the lower fairing.
    The front cylinder is always going to get more air, but having them catch as much air as possible will push more past the front and over the rear.
    Check out the 4:50 mark in the video to see what they look like with the 1.5".
    Hope that helps.
    www.DKCustom.com
  4. #24
    150+ Posts
    Mar 2020
    Surprise, AZ, USA
    I don't know if they were redesigned after this video was made but mine sweep up on the end.
  5. #25
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Quote Originally Posted by molokaimike View Post
    Sounds like you ordered the Cooling Deflector Wings for No Tank Lift. They are a different design than the ones made to work with a Tank Lift.
    These are for use with a Tank Lift-
    These are for use with No Tank Lift-
    www.DKCustom.com
  6. DKCustoms postbit
  7. #26
    150+ Posts
    Mar 2020
    Surprise, AZ, USA
    In the video it looks like the deflector has the ear with the mounting hole bent in one direction and the tip of the deflector is bent in the opposite direction. In the photo of the two models of deflector the mounting ear and the tip are both bent in the same direction. Or am I not seeing the video correctly.
  8. #27
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    The CDW in the video is the same as the top one pictured above, made for use with a Tank Lift. No changes made.
    The piece with the hole for mounting is pointed down, as is the tip of the wing. (well, down and forward)
    Just went and found one of the Patent Drawings.
    Here's another one-
    www.DKCustom.com
  9. #28
    150+ Posts
    Mar 2020
    Surprise, AZ, USA
    Thanks Kevin, I guess what threw me was in the video I could see the mounting bolt for the tank so I thought that the wing was mounted with the mounting tab pointing up not down.
  10. #29
    400+ Posts
    Feb 2020
    Washington Pa USA
    Thanks for post I didnt know you could do this . Guess I have parts to order and work to do
  11. #30
    150+ Posts
    Mar 2020
    Surprise, AZ, USA
    What happens if you add the tank lift but don't change the CDW's to the tank lift design.
  12. #31
    Dec 2013
    Clarion PA USA
    I can't think it would be anything bad, it would be better than nothing. Email Kevin and ask him certainly worth looking at. ride safe Fred
  13. #32
    10+ Posts
    Jul 2017
    Venice, Florida, USA
    Default tank lift
    If I use a tank lift kit will I be able to change all of spark plugs without taking off the tank each time?
    I have a 2017 Triglide - M8 engine
  14. #33
    850+ Posts Rmitchell55's Avatar
    Dec 2012
    Santee
    Simple answer, NO
    Ray
    2017 Harley Triglide
    Tijuana Border
  15. #34
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by Aquaholictom View Post
    Quote Originally Posted by Rmitchell55 View Post
    Simple answer, NO
    The first problem is getting the 2 RS plug wires off with out ruining them. You will still be hard pressed to get the plug wire tool in there. The second problem will be coming up with the right combination of socket, extension and ratchet so you do not gouge the rocker box. Now you may ask how I know this. When I rode my 17 M8 Freewheeler home I heard a ticking noise. When I found the noise coming from the RS spark plugs I jumped in and found both plugs were loose. I have turned wrenches ALL my life and I got lucky with the correct tools, that said it is NOT difficult to pull the tank to change the plugs. Your out come may vary
  16. #35
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    They still work fine, and the Tank Lift will add a cooling benefit.
    The CDW's made for use with a tank lift have a little large surface area and a resulting slightly better benefit.
    www.DKCustom.com
  17. DKCustoms postbit
  18. #36
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Simple answer, NO
    Rmithchell55 and Jack are both right.
    My experience has been- With the 1.5" Tank Lift you'll be able to get to both fronts and the left rear easily. The right rear, even with the Deluxe option, you will have to lift the rear of the tank a bit to get to that plug. But that is easy enough, just loosen two bolts.
    www.DKCustom.com
  1. Replies: 7
    Last Post: 07-08-2016, 03:45 PM
  2. DK Tank Lift Kit Question
    By cdculbertson in forum Harley Tri Glide
    Last Post: 05-10-2016, 02:20 PM
  3. installed DK Lift kit and tank lift
    By uppercaseJC in forum Harley Trike Conversions
    Last Post: 10-25-2015, 12:35 AM
  4. tank lift kit
    By Big Red in forum Harley Trike Conversions
    Last Post: 01-15-2014, 09:12 PM
  5. Gas Tank Lift Kit?
    By GoSlo in forum Harley Trike Conversions
    Last Post: 12-16-2013, 11:36 PM
