Likes Likes:  100
Thanks Thanks:  3
Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 40 of 71
Thread: Escort trike build
  1. #21
    500+ Posts LarryA's Avatar
    Jun 2016
    milnor n.d. usa
    yes...great idea, and goes well with the dustbin fairing.
  2. #22
    40+ Posts
    Aug 2019
    Naples, Id, USA
    This ABS crinkle finish plastic makes great trim coverings.Name:  IMG_1313.jpg
  3. #23
    40+ Posts
    Aug 2019
    Naples, Id, USA
    ligning up rear access panel and vents for releasing heat and cutting down on the suction at the rear of trike.Name:  IMG_1314.jpg
  4. #24
    40+ Posts
    Aug 2019
    Naples, Id, USA
    Turn signal, lights, cruise controls assy. from the car fits pretty good.
  5. #25
    40+ Posts
    Aug 2019
    Naples, Id, USA
    Startin to work on the harness. Trying to cut down some of the unnecesary wiring in the original harness. Name:  IMG_1316.jpg
  6. #26
    Jun 2016
    milnor n.d. usa
    A clever reuse of existing switches and their mounting, will definitely save time when rewiring.
  7. #27
    40+ Posts
    Aug 2019
    Naples, Id, USA
    Got the gas tank mostly welded up. Had the metal cut and bent at the metal shop. Need filler neck and vent.Name:  IMG_1317.jpg
  8. #28
    Quote Originally Posted by goodwrench View Post
  9. #29
    40+ Posts
    Aug 2019
    Naples, Id, USA
    Got the tank all welded , fitted and pressure tested.But I have to remove the pump to slide it in the frame under the back seat.Name:  IMG_1318.jpg
  10. #30
    40+ Posts
    Aug 2019
    Naples, Id, USA
    Flip up fuel door from the escort and the filler tube and vent.Name:  IMG_1319.jpg
  11. #31
    40+ Posts
    Aug 2019
    Naples, Id, USA
    The latch for the left side slide out pannier. Name:  IMG_1320.jpg
  12. #32
    40+ Posts
    Aug 2019
    Naples, Id, USA
    Disasembled the parts off the frame and flipped it over for welding the bottom side.Name:  IMG_1325.jpg
Size:  131.9 KBName:  IMG_1326.jpg
  13. #33
    150+ Posts
    Jan 2011
    Osceola Mills,PA,USA
    Looking good. Lots of work but keep at it. It all adds up to a one of a kind trike when you are done.
  14. #34
    40+ Posts
    Aug 2019
    Naples, Id, USA
    Wire wheeling the frame today and weighed it. Complete frame with front forks is 320 pounds!
  15. #35
    750+ Posts
    Jan 2010
    east windsor ct
    seems pretty light for what you have !!!
  16. #36
    40+ Posts
    Aug 2019
    Naples, Id, USA
    Got the frame painted. What a pain. cleaned and etched the frame with phosphoric solution, cleaned with paint prep solvent, primed with epoxy primer, spray painted the blue with Rustoleum, and brushed on the white as it will be covered with white sheet metal. The blue came out a bit rough even though it went on well and was glossy. But when it dried it deteriorated a bit. Oh well I'm not making a show bike worth $20,000. I've got a bit over $3,000 in it now. Name:  IMG_1333.jpg
Size:  114.4 KBName:  IMG_1330.jpg
  17. #37
    Jul 2020
    Phoenix, Arizona, USA
    Default Wow
    Can't wait to see how it turns out.
  18. #38
    Jun 2016
    milnor n.d. usa
    Same here!
  19. #39
    40+ Posts
    Aug 2019
    Naples, Id, USA
    Got the belly pan on. Forward chunk is fiberglass sheet from home depot The rest is plastic sheet from home depot. Looks like the bottom of the space shuttle!Name:  IMG_1335.jpg
  20. #40
    40+ Posts
    Aug 2019
    Naples, Id, USA
    Installed front shield. Will put rubber sheeting around the moving parts of the forks to keep out rain, rocks and things that could impale me!Name:  IMG_1337.jpg
  1. PGR MISSION EScort.
    By Phill Griggs in forum Trike Travel
    Last Post: 11-01-2015, 10:41 PM
  2. My first Honor Flight escort
    By Thor in forum Military & Veterans
    Last Post: 10-08-2015, 04:32 PM
  3. Reverse Trike - Concept build
    By michaelplogue in forum Home Built Trikes
    Last Post: 01-28-2010, 11:02 AM
  4. New Member, trike build underway
    By pin-hi in forum New Member Introductions
    Last Post: 06-30-2009, 11:49 PM
  5. first step craz trike build
    By cra-ze-trikeman in forum General Discussion
    Last Post: 04-08-2009, 02:41 PM
