Likes Likes:  2
Thanks Thanks:  3
Results 1 to 12 of 12
Thread: Question on rear calipers for Viper
    350+ Posts pwhoever's Avatar
    Jul 2016
    Southeastern Wisconsin
    Unhappy Question on rear calipers for Viper
    So I had ordered Speedbleeders for my GL1800 including ones for the rear calipers. I finally got a chance to install them today. What I noticed was that the bleeders on the conversion rear end appear to be very similar to Speedbleeders but slightly different. Do the Viper standard rear calipers come with some kind of speedbleeder setup or are they just standard bleeders. I will admit I didnt check them out and just replaced them anyway.
    Or if they are normally standard bleeders, is it possible that the builder may have changed them out? Like I mentioned, they look very similar but the speedbleeders have a more pointy bottom and the bleeders I removed were rounded off just a bit. Also, the Speedbleaders had some kind of grey thread lock were the ones I removed didnt appear to have any. I will try to post a photo of both side by side. The speedbleeder is the one on the left and the one I removed is on the right.
    100+ Posts Scott1's Avatar
    Mar 2012
    Cranberry Township, PA, USA
    Standard bleeders you can blow air (by mouth) through them and speed bleeders you can't.
    [SIGPIC][/SIGPIC]
    2008 GL1800 Level 3 W\2009 Motor Trike Adventure IRS Kit
    1999 Valkyrie Interstate W\2001 Lehman Predator Trike Kit
    2021 Can-Am Spider F3 Limited (Girlfriends)
    2009 Vulcan 900 Classic, full dresser (Girlfriends)
    2019 Coachmen Catalina Trail Blazer 30' Toy Hauler/Camper
    Jul 2016
    Quote Originally Posted by Scott1 View Post
    Ahhhhhh, good catch. And I knew that but forgot about it. Now I gotta go out and check them...
    Jul 2016
    Ok, mystery solved. They were just standard bleeders. Thanks for jumpstarting my brain. Its rough getting old. But I must say these new Speed bleeders are amazing. They will make bleeding and flushing a much easier task now. I always did they mighty vac before but really think I'm going to enjoy this new method.
    Mar 2012
    Yes, I have speed bleeders on both of my trikes. I just attach the rubber hose from the catch bag and change the fluid for the front, rear and clutch. Simple one person operation and great for maintenance changing brake fluid. Never get air in the system.
    [SIGPIC][/SIGPIC]
    400+ Posts BrokenBackJack's Avatar
    Feb 2017
    Payson, AZ USA
    Default Speed Bleeders
    Been wondering we have a 2010 Goldwing with the Cobra CSC kit.
    Does CSC kit use the same size bleeders as comes stock on the Goldwing?
    Does anyone know what size or sizes i need to do front, rear, and clutch on our 2010 and how many total??
    Appreciate any help you can give.
    Johnny 7
    God, Family, Country, & Green Bay Packers
    2018 Honda Goldwing DTC Touring CSC Encore Trike Kit & 2021 Polaris General XP G2 Ride Command
    Jul 2016
    As far as the speedbleeders needed for GL1800 trikes, I know that 4 SB8135L are needed and 2 SB8125 too. 2 of the SB8125L are needed for left caliper, 1 SB8125L for top of the anti dive valve and the final SB8125L goes to bottom right bleeder. Space is limited on top right caliper bleeded so that will use one of the SB8125. The other SB8125 would be used for clutch if you choose but many say that the clutch will gravity bleed just fine. I haven't changed my clutch bleeder yet but have the extra speedbleeder if and when I choose to do it. On the back of the Viper, there are 8 bleeders. I installed 8 SB51624 ones. The Viper calipers call for 5/16-24 thread bleeders. I am assuming that the Cobra will probably use the same ones. I ordered directly from Speedbleeder as I didnt find any retailer that sold them any cheaper. I also bought the Speedbleeder bag which came with a decent length rubber hose. It looks small but handled flushing both the front and rear brake systems and I probably could have done the clutch as well but I did it last year so I'm not worried.Here is what I ordered. I didnt know it at the time but each speedbleeder also comes with a cap. I ordered caps separately so I now have more than enough spares...
    One other thing to add is that there are 2 different sized wrenches ( either 6 and 8mm or 8 and 10mm, I cant recall right now) needed to bleed the original brake bleeders. Once you switch over to speedbleeders, only 1 size will be needed for all.
    Jul 2016
    Just to add, there is a specific sequence to follow when bleeding the rear brake system. Here is the instructions from CSC. Read closely as when you reach the rear brakes, do the front bleeders on rear brakes first starting on the outside, then go to anti dive valve, then rear bleeders on rear brakes starting with the outside ones first again.
    https://img1.wsimg.com/blobby/go/196...=1587475977349
    Feb 2017
    Payson, AZ USA
    Default Thanks
    Thank you kindly!
    Johnny 7
    150+ Posts geraldlanc's Avatar
    austin tx usa
    Default Confused
    On the csc instructions it says to push up on the front caliper??
    Gerald
    Jul 2016
    Yes on the front left caliper when bleeding the anti dive valve. It does move. IIRC, you also have to pump foot brake a couple times first before opening anti dive valve and pushing up on left caliper.
    Jul 2016
    One other thing to mention. In post #8, I have the order backwards but since this thread is 2 years old, I can't edit that post. The directions from CSC that I linked to are correct. So I should have posted:
    do the rear bleeders on rear brakes first starting on the outside, then go to anti dive valve, then front bleeders on rear brakes starting with the outside ones first again.
  1. Replies: 7
    Last Post: 09-10-2019, 08:59 AM
  2. Speed Bleeders for 2011 Tri Glide REAR Calipers
    By TomWoodgeard in forum Harley Tri Glide
    Last Post: 03-16-2018, 12:53 PM
  3. Stallion Calipers
    By Trikerchief in forum Stallion Trikes
    Last Post: 02-01-2015, 10:46 PM
  4. Leading link forks,175x15inch car tyre & wheel,4 pot calipers
    By trikerAL in forum Tires, Wheels, Brakes, Front End
    Last Post: 07-31-2014, 06:41 PM
  5. wilwood calipers for trike use
    By BIBS in forum Tires, Wheels, Brakes, Front End
    Last Post: 10-18-2010, 09:08 PM
